1934 FORD RUMBLE SEAT CABRIOLET ALL FORD STEEL, VINYARD GREEN, SILVER GRAY PIN STRIPE, APPLE GREEN WHEELS WITH 17 INCH TRIM RINGS,& WIDE WHITES, HAS LOCKING SPARE TIRE COVER, LEBARRON INTERIOR,WOOD GRAINED DASH, & GARNISH MOULDING, ALL ORIGINAL GAUGES WORK, ADDED UNDER DASH OIL PRESSURE,& TEMP GAUGES, VACUUM WINDSHIELD WIPER WORKS. ENGINE IS 276 C.I. 1946 FORD FLATHEAD, STILL 6 VOLT, 59 AB, BORED125ths,4 INCH MERCURY CRANK, ISKY MAX-1 CAM, OFFENHAUSER HEADS, & DUAL INTAKE, WITH TWO MATCHING STROMBERG 97'S CARBS. REDS HEADERS, WITH CUSTOM MADE DUAL EXHAUST, WITH SMITTY'S. TRANS. IS DUAL DETENT 1939 FORD, REAR END IS STOCK 1934, WITH 354 GEARS. BRAKES CHANGED TO 40 FORD HYD, WITH STOCK BRAKE, & CLUTCH PEDALS. PAINT IS GOOD, BUT DOES HAVE A FEW SCRATCHES, & CHIPS. EMAIL sues56@myfairpoint.net WITH INTEREST, OR PICTURES, THANKS ED SOLD
