Projects The Brooks Special - louisb’s 29 lakes roadster build
Discussion in 'Traditional Hot Rods' started by louisb, May 11, 2018.
  1. louisb
    louisb
    Spent some time shortening the 32 pedals 1” to fit the 29 body.
    Clutch pedal is a little off so I will adjust it with the heat wrench later. Still need to weld on the brake arm. Making progress one step at a time.
    Thanks,
    —louis
  2. louisb
    louisb
    Also got the front brake drums bolted on. I would have done the rears too but apparently I ordered the wrong bearings. The right ones, and the left one ;) , are on the way.
    Original 40 juice brakes all the way around. Took a while to find a full set of original drums that would turn within specs.
    Thanks,
    —louis
    deluxester, Stogy and brEad like this.
  3. Aaron D.
    Aaron D.
    Nice man. It's coming together nicely.
    louisb likes this.
  4. IowaMercMan
    IowaMercMan
    louisb likes this.
  5. louisb
    louisb
    Got the wheels sandblasted and painted. Turns out one of the 16x4s was heavily pitted so I am hunting for a good replacement.
    44E94ACF-7EA1-465A-A000-C91B7E355153.jpeg D974E0C0-716A-4B92-97D4-7FC15254DE52.jpeg C584D218-3249-4A50-8C62-517C00B2815E.jpeg 576B6A27-03D0-45B0-8025-09760550EEBD.jpeg 8C70B104-6199-4922-8322-877DD1B7D461.jpeg 1CF0D361-65D3-4EDC-803F-DEA70A256F8B.jpeg
    Thanks,
    —louis
    deluxester and Stogy like this.
  6. louisb
    louisb
    I has originally planned to use a late 40’s solid drive shaft but scored this ‘34 shaft last week from a fellow HAMBer. This is actually the second ‘34 drive shaft I have bought for this project. The first one is lost some where in a FedEx sorting facility in Utah. Probably sitting next to the Ark of the Covenant.
    I need to find a place to have it shortened. None of the shops within a 3 hour drive will touch it.
    Thanks,
    —louis
  7. louisb
    louisb
    @NealinCA sent me a few pics of my finished F100 column. Looks really good but that is to be expected of his work.
    B995EEBA-A14F-48BB-96CA-7A5CD6F23725.png 4A3C030F-E446-484A-8098-C55C464C8640.png 63E50731-ED85-4763-8BD2-37EA8AFB60A8.png 419B3BE7-8BCF-44BA-BB17-7718AB777F5B.png
    I currently have an F3 column jacket but I am keeping an eye out for a good ‘39 jacket. If you have one, PM me.
    Thanks,
    —louis
    Outback, deluxester, Stogy and 2 others like this.
  8. louisb
    louisb
    Got a hurricane heading this way so I needed to make some room in the garage for the wife’s late model Fordor. This required moving the hot rod which was the perfect excuse to get her rolling.
    8C33A4A5-4362-4DA9-B086-7570BC4012EE.jpeg FF8807A1-1E54-4C87-BCD2-3CB9315BEFAF.jpeg 582B5CF2-78BB-4E29-86AA-8C87CBFC66AB.jpeg
    We are all hunkered down for the storm. To everyone in the path of the storm, be safe.
    Thank,
    —louis
    deluxester, slv63, Texas36 and 3 others like this.
  9. NorthManCad
    NorthManCad
    Very nice project! Be safe for the storm, all the best for yours.
    louisb likes this.
  10. gdaddy
    gdaddy
    from nw fl.
    I live just south of Marianna Fl. , so the storm is suppose to come right over top of us .
    Outback and louisb like this.
  11. 1-SHOT
    1-SHOT
    from Denton
    You are in my thoughts and prayers. It looks like a Cat4 now
  12. IowaMercMan
    IowaMercMan
    Good luck brother and make sure your insurance agent knows about the roadster.
    louisb likes this.
  13. Retroline
    Retroline
    This reminds me of my build, just getting it done with the basics, no fuss. Hope the storm cleared up and you were spared form any damage. Looking forward to updates.
  14. fortynut
    fortynut
    1. I was wondering if you had any problems due to 'the hundred year phenomenon'. Sure pray that you and yours were spared the kind of destruction seen on the internet. I have always advocated concrete domes as a precaution against wind driven weather in locations where it occurs seasonally. But, even so, I live in an old brick house like the third pig, I grew up in Mississippi with a choice of Babbitt Chevys and rattling connecting rods and Flathead Fords with cracked blocks, that were always a ****shoot to build. Then, along came Oldsmobile and Cadillac overhead donor engines; and then we recieved God's proof he loved hot rodders--- the small block Chevy. Yes, I know you are smiling, because you are building a period correct rod; but, even you have been faced with the cracked block syndrome. Again, hope all is well and power will be restored, and no damage.
    Outback, Atwater Mike and louisb like this.
  15. louisb
    louisb
    Thanks for the well wishes and prayers. We are fine but had some damage to the house from a falling tree. Still without power.
    Thanks,
    —louis
    Stogy and slv63 like this.
  16. brEad
    brEad
    Glad to hear you are all fine. Hope everything works out regarding the damage.
    louisb likes this.
  17. fortynut
    fortynut
    I have seen a lot of fallen trees, in pictures of the aftermath. They are a blessing in summer, and make nice smelling smoke in the fall. The ground gets soaked and the winds play havoc. Worse part of no electricity is worrying if your candle stash, and the fuel for your Coleman stove holds out. Sure hope none of the damage was to the space where your project is stored. Glad you and yours survived. Stay safe.
    louisb likes this.
  18. louisb
    louisb
    So we had a tree down on the corner of the house but we still have a house unlike my friend who had a house at Mexico Beach. And by "had" I mean it's not there anymore. Nothing, nada, gone, goodbye, fin. She now owns an empty lot with a few posts where her house used to be. Puts things in perspective.
    So back to building hot rods. Spent the weekend ticking off see small stuff that needed doing. Made the upper shock mounts from some F1 mounts. Redid a headlight bar I originally made for a Model A frame, dropped (fancy way of saying bent) a steering arm, finished modifying the brake pedal for juice brakes and started on the rear shock mounts.
  19. louisb
    louisb
    First the Headlight Bar. I originally built this from an original '32 V8 bar to fit a Model A frame which is wide than a '32 frame. So I needed to heat and bend the arms in some to fit. Then I decided to welded on the "feet" from a '30 Model A bar I had.
    IMG_20181013_134153.jpg IMG_20181013_142612.jpg IMG_20181014_145056.jpg IMG_20181014_145121.jpg
    I went ahead and mocked it up with some Guide 683-Cs I had on hand but I am looking for a set of smaller 903-Js to run.
    Thanks,
    --louis
    Outback, Stogy, brEad and 2 others like this.
  20. louisb
    louisb
    Next up are the front upper shock mounts. I had a set of F1 mounts already on the ch***is but they were to long for the shocks I wanted to run. So I shortened them about 3" and then bent them out a little to better clear the headlights. (I don't see how anyone can build a traditional hot rod without an O/A torch)
    IMG_20181013_121619.jpg IMG_20181013_125138.jpg IMG_20181013_125151.jpg IMG_20181013_170345.jpg IMG_20181013_170636.jpg IMG_20181014_145056.jpg
    Some of these pics may be repeats. I was working on all this at the same time. Do a little then do something else while I wait for it to cool, etc. Last pic you can see the "dropped" steering arm. It only took 5 tries to get it to clear everything. It's not perfect but that's how you know it is homemade. That is my excuse and I am sticking to it.
    Thanks,
    --louis
    Outback, rpm56, deluxester and 3 others like this.
  21. louisb
    louisb
    Rear shock mounts. Got the top mount welded in but waiting on the right bolts for the bottom. Going to use a couple of radius rod ends.
    Thanks,
    --louis
    Outback and Tim_with_a_T like this.
  22. louisb
    louisb
    Last is the brake pedal. Needed to relocate the arm from the top to the bottom to work with the '40 juice master cylinder.
    And yes there is a **** load of weld there. Thank goodness for the all purpose hot metal glue gun. Plan to get the pedals re***embled and then make the linkage from the pedal to the MC.
    Thanks,
    --louis
  23. Aaron D.
    Aaron D.
    Nice progress, and looking good. I like doing the small fun projects like that.
  24. louisb
    louisb
    Up till today it was mostly getting small stuff done in between some home renovation projects I promised the wife would be done by the holidays. (Happy wife, happy life) then this weekend I started getting the body mounted and the rear subrails installed. A while back someone suggested the @Steadfast mfg subrail kit and I poopoed the idea. But after giving it more thought I decided to order a set and I have to say I am glad I’d did. Really nice quality and it’s one more thing I can check off my list.
    DBEEEF73-8663-48FC-BCC2-BF4E28111490.jpeg 47C6D451-D25F-470D-A4E5-F8B32AC81504.jpeg C18B7478-B6AE-41A1-ABF7-0FD33B584C7F.jpeg 4D7BDECF-84F8-4776-B619-571E2A7D256D.jpeg E0A2968F-D180-413A-B2E7-24AC8B248C80.jpeg
    Another thing I changed my mind in was using wood shims to fill the body to frame rail gap. After some “encouragement” from a few friends I ended up cutting the cowl. Wasn’t as bad as I thought it would be and sits right on the frame now.
    Engine Update: After going through five or six blocks it looks like we have a good one to build. Just waiting on Dan to sonic test the block. It’s a prewar 221 but that’s okay. Should get 255 with the mercury crank.
    Thanks,
    —louis
    deluxester, brEad, Stogy and 5 others like this.
  25. Aaron D.
    Aaron D.
    5 or 6 blocks! Damn man. But hey, forward progress is key right?
    looking awesome Louis.
    louisb likes this.
  26. louisb
    louisb
    A couple of shots at the 2 blocks we are looking at. All have tested out, just waiting on a final decision by Dan.
    Screenshot_20181127-092600.png Screenshot_20181127-092618.png Screenshot_20181127-092631.png
  27. Chris
    Chris
    This is a great thread! I have an original 32 frame and 31 roadster body I want to marry together
  28. louisb
    louisb
    Thanks, I have enjoyed several of your threads as well.
    --louis
  29. lodaddyo
    lodaddyo
    looking good man! glad you found a good block
    louisb likes this.
  30. 1-SHOT
    1-SHOT
    from Denton
    IMG_4189.JPG Are you going to notch the sides of the grill shell so it lines up with the cowel better, like I did mine
