Projects Street rodded ‘40 Ford pickup freshening
Discussion in 'The Hokey Ass Message Board' started by TudorTony, Sep 29, 2018.
  1. TudorTony
    TudorTony
    from NJ
    Bought Street rodded ‘40 Ford pickup a few weeks ago. Good advice here got brakes straitened out (portioning valve issues) . Moved to engine 383ci Mopar in storage for 23
    Yrs & fired up today. Brings me to now, knowing Engines good now moving on to ch***is body issue. I Know ch***is is an F1 ‘48 -‘53. Cab & bed sitting higher than stock ( looks like a lifted 4WD) & want to lower. Found 2”X 3”X24” milled oak, (very square & perpendicular all faces)at all mounting features spacing the bed & body on the ch***is. Very solid. Could tell it was hard wood so cleaned up a section 2 check & is oak. This was done 25 yrs ago when built? Trying to figure if early attempt at lift for the look or done for some tech reason? All look 2 B fairly easy to remove & use shorter mounting bolts to get lower. Gotta check all clearance going down 2”. ***uming steering u/joint will take it? Anyone have Model A pickup cab/bed F1 tupe ch***is? Any insight before I start to remove oak spacers?
  2. goldmountain
    goldmountain
  3. HOTRODPRIMER
    HOTRODPRIMER
    40 pickup with a 48-53 cab & bed? we need photo's. HRP
  4.
    57 Fargo likes this.
  5. TudorTony
    TudorTony
    from NJ
    “I Knowch***is is an F1 ‘48 -‘53”
    Sorry about that, missed period between ’53 & bed. It’s a ‘48 -‘53 frame under a ‘40 F pickup
  6. Blue One
    Blue One
    from Alberta
    I'd be pull the body and sell the rolling ch***is with the powertrain and get a proper 35-40 ch***is and go from there.
    In fact that would be the only way I would have even considered buying that truck in the first place, knowing that would be the plan.
    Of course the price would have to be right for that to happen.
  7. 40FORDPU
    40FORDPU
    Are you familiar with the factory cab and bed mounting wood?..they may have retained it (check on Bob Drake or Macs website and check them out).
    I completely agree with Blue One, locate an original ch***is, less head ache in the long run..they aren't that hard to find.
    Good luck with your project, and keep us updated.
  8. TudorTony
    TudorTony
    from NJ
    Impractical & too expensive to modify ‘40 frame to accommodate BB Mopar in it.
  9. TudorTony
    TudorTony
    from NJ
    Thx, will check Drake Catalog to check on whether there was stock wood interface between cab, bed & frame. I bought this as modified street rod. Not interested in stock ch***is for this project. It has a modified BB Mopar which would rip stock ch***is apart. ‘48 & newer frames much stronger & will withstand torque better. I have a mainly stock ‘35 Ford Tudor, different animal. Fun 4 parades & shows but not fun to drive! The only way I’d change frame would be to buy an aftermarket “Fatman” type frame for high Perf. V8 which would be prohibitively expensive. Same holds true 4 stock ‘40 frame by the time U boxed & strenthened, put different rear, Drive shaft, modified the X, modern brakes to accommodate modern V8. Will stay with this & replace wood mounts with rubber body mounts I’m gonna lower suspension after checking all clearance issues.
  10. Blue One
    Blue One
    from Alberta
    I guess you missed the part where I said sell the rolling ch***is with the powertrain and go with something better than the BB Mopar.
  11. HOTRODPRIMER
    HOTRODPRIMER
    Having built several 40 Fords I would suggest selling the complete running ch***is and find a 35 to 40 Ford frame, there is some work involved but I can't see any way to get the truck to sit low without doing it correctly. HRP
  12. TudorTony
    TudorTony
    from NJ
    Blue One, to each his own. Not what I want as same would hold true for Hi-perf V8 anything in stock frame! Hey U like stock go stock. As soon as U perf up a ‘32-‘41 ford with stock frame w any hi horse power power plant u gotta do a lot (big big buck$’s) to handle it & make it safe enjoyable to drive. Yea U could put a low horse Sb Chev or Ford. Under 200 HP but still have the X frame mod , brakes, rear, on & on. As said I have a stockish ‘35 ford same frame as would be on a stock ‘40. Just juice brakes cost me $4K doing work myself. Mod’s to X & wish bones u need to put any modern V8 even SB chev will be another $3K, then the rear & driveshaft change another $4K. Then there’s suspension change on rear end to accept new differential. Now if u don’t give a **** about handling, safety, or performance just do the X & modify the drive driveshaft to rear mods & ur still at $3K to $5K. I heard U just don’t agree!
  13. Terrible80
    Terrible80
    Can't tell , but would think they stuck the wood in there because the frame contours don't fit the body. I think you'd have to just raise up the body off the mounts , remove wood and see how far off you are at each mounting point.
    loudbang, cactus1 and Bandit Billy like this.
  14. Blue One
    Blue One
    from Alberta
    Totally up to you of course but like I said, the only way I would have considered buying that truck would be knowing that the rolling ch***is and powertrain would go to a new home.
    Then I'd start with something like this from Pete and Jakes.
    Or something like this from TCI
  15. HOTRODPRIMER
    HOTRODPRIMER
    Less than 5 years ago we built a entire rolling frame for a 4o Ford coupe using ch***is engineering parts and a salvage yard rear axle, disc brakes and needing noting but a engine and transmission for less than 2 grand.
    I would have to say drive it like it is and get use to the 4 wheel drive look. HRP
  16. the-rodster
    the-rodster
    Ewwwwww.
    That thing will always look like a turd in a punch bowl unless you get it on the proper frame.
    Rich
  17. 392
    392
    As most have stated without changing ch***is etc it will look ........ cartoonish. Save up a few bucks and do it right with a new foundation. You won’t regret it. If body is solid your way ahead of the game.
    Blue One likes this.
  18. TudorTony
    TudorTony
    from NJ
    Checked & seems to be exactly what builder did. While I believe it to be a replacement set they R the wood body/Bed mounting blocks & what’s pictured online catalogs, they’re in perfect condition so will leave as is. Ordered aluminum lowering blocks from speedway that lower axles @ shackle leaf mounts. 2 Kits has 8 shackle plate u bolts & different thicknesses aluminum blocks allow 1/2” to 4” lower.
  19. upspirate
    upspirate
    Interesting how folks ask for advice, then when they get good advice, they get ******* in a wad
  20. Normal lowering blocks won't do it. The rear end is underneath the rear springs, I'm pretty sure the fronts will be the same. IF you want to do some fabrication work, you could move the axles to the top of the spring packs, that will get you lower. You'll have to watch for frame clearance, and ensure everything welded and bolted properly and safely.
  21. paintman27
    paintman27
    from new jersey
  22. TudorTony
    TudorTony
    from NJ
    Checked & seems to be exactly what builder did. While I believe it to be a replacement set they R what’s pictured online catalogs, they’re in perfect condition so will leave as is. Ordered aluminum lowering blocks from speedway that lower axles @ shackle leaf mounts. Kit looks like different thicknesses allow 2” to
    Thinking I don’t want to go extremely low like this one that’s probably 2”-4” lower than stock https://www.google.com/amp/s/www.pinterest.com/amp/pin/496381190154267194/ but right now mine is 4”over stock. Realizing the ‘40 sheet metal onnthe ‘48 ch***is sits higher than the ‘48 sheet metal would giving the high appearance. If I could get down to stockish looking height would be fine. 48’s R lowered all the time, this ia ‘48 frame/suspension so why not? Not getting why ppl think it can’t get lower? I’m gonna check clearance see if anything majors in the way (looks like just the exhaust which can be reconfigured). Reversing where the leafs r & putting under rear housing w 1” spacer drops it 4”s & change out front I with 4 “ dropped I should work?
    loudbang and Luke stone like this.
  23. TudorTony
    TudorTony
    from NJ
    OK then
    Tkx
  24. 57 Fargo
    57 Fargo
    Well you came to place with an awful lot of knowledge building cars and asked a question then got pissy....if it’s so easy to lower and solve your issue then great go for it, no need to ask questions. It’s never going to look right on that frame but I’m a fan of the big block dodge.
    saltracer219 and upspirate like this.
  25. flamedabone
    flamedabone
    I have to disagree with you on that one. People have been putting bigger engines in '40 Fords since 1940. Mopars, Caddilac, Olds, Pontiac, you name it, they will fit with a minor amount of effort.
    I have even heard of some people putting small block Chevvies in 'em.....
    That little truck is going to be tall forever with that frame, if you don't mind that then don't worry about it. But, if you want to get it normal hot rod height, an original frame would be the way to go.
    Good luck either way and we'll always here to help.
    -Abone.
  26. Anderson
    Anderson
    I dig the **** out of it as is.
    Everyone wants to preserve history of “old hot rods,” well here one is. I don’t get wiping out the history of a car/truck like this just to replace it with the same look thousands of other “traditional” versions have.
  27. Corn Fed
    Corn Fed
    If your BB Mopar is so hipo that it would tear up a non-boxed 40 frame, arent you worried that it will be too much for a rear end connection that utilizes lowering blocks?
  28. I think it's groovy AF as it is!
    brad2v and loudbang like this.
  29. Bandit Billy
    Bandit Billy
    I think you underestimate Henry's little truck frame. That said, roll your own and I'll be along to imbibe if you post your progress.
  30. Petejoe
    Petejoe
    from Zoar, Ohio
    Years past, your **** would be puckering from all the *** chewing you would have received with that statement.
    That truck is not an old Hotrod.
    It some 1980’s redneck version of getting a truck back on the road.
    It’s terrible on top of that frame.
    But on a positive note has great potential.
