Technical Vacuum Question 350 Chevy
Discussion in 'Traditional Hot Rods' started by PeggySue, Oct 1, 2018.
  1. PeggySue
    PeggySue
    Thanks was wondering about the valve on the canister and then going to one on the booster, will do some re-hosing tomorrow and see what happens
  2. PeggySue
    PeggySue
    When I did the front disc brakes from Speedway, I also got the pedal ***embly and booster/dual master from what the tec told me. Going to try redoing the hose hook up tomorrow and check vacuum at the manifold, if that doesn't have some results I look into a bigger booster.
  3. PeggySue
    PeggySue
    Just did some rethinking, the hose from the manifold going to the canister is connected with a open L fitting so there would be vacuum going in the canister. The hose coming out of the canister going to the booster has the valve in it were it connects to the canister.
  4. PeggySue
    PeggySue
    Just did some more research hose from manifold connects to valve connect on canister, then open L fitting on canister goes to valve on booster. Is this what your referring to?
  5. greybeard360
    greybeard360
    Yes. The hose connection on the valve is the vacuum side. That should go to the manifold.
    PeggySue likes this.
  6. bobss396
    bobss396
    I like big stock boosters and I get them with a matching master if possible. The 7" ones that one size doesn't fit all are problematic. Have you hung a vacuum gauge on it yet? I'd be curious what you have at idle.
  7. PeggySue
    PeggySue
    OK Thanks
  8. PeggySue
    PeggySue
    Going to put a gauge on this morning and go from there
  9. Elcohaulic
    Elcohaulic
    Find out what the vacuum is at idle.. Under 18" your not going to have any booster work right.
  10. Terrible80
    Terrible80
  11. PeggySue
    PeggySue
    Hei from Summit
  12. PeggySue
    PeggySue
    (Up date) Put the gauge on the manifold , slight wiggle up and down 14 to 15" with motor at 140 degrees. Going to re-route my hoses right and see what the brakes do.
  13. PeggySue
    PeggySue
    Up date run the vacuum straight from the manifold to the booster, big difference Got power brake now!
    squirrel, upspirate, bobss396 and 3 others like this.
  14. bobss396
    bobss396
    Nice going. I side-stepped the power brake option on my car due to the cam and fitting the booster in the allotted space. It stops great with manual brakes.
  15. PeggySue
    PeggySue
    Thanks everyone for the help, sure made it go smooth!
    upspirate likes this.
  16. squirrel
    simple is best!
