Steering set-up
Discussion in 'The Hokey Ass Message Board' started by Farmfind, Jan 17, 2007.
  1. Farmfind
    Farmfind
    from Boise,ID
    Hey-
    Anybody out there know what will work for a traditional steering set-up besides the f100 or reversed corvair box? Thanks-
    :confused:
  2. cheap-thrills
    cheap-thrills
    according to speedway, a late 60s' mustang works. havn't tried it myself but am considering looking into it.
  3. A Late 70s Mustang I Think 76/78 Works I Used One In A 34 Ford Sedan And You Can Positon Where You Want It More And Use A Lot A Differnt Columns Tim
  4. flathead okie
    flathead okie
    early mustang/falcon
    dana barlow likes this.
  5. litemupok
    litemupok
    Richard D(i think) said a manual mopar muscle car box will work w/o reversing it for cowl steering. that is what im going to try....
  6. Kevin Lee
    Kevin Lee
    Super Moderator
    Any Ford box (truck or car) from '28 - '48. ('37 brought the rolling sector but I've seen the earlier parts used with success.)
    Early GM boxes could be somewhat big but work well.
    Schroeder or similar sprint car box from that era.
    Old Jeep or other off brand parts - lots of smaller companies used
    "Ross" steering boxes. Delivery trucks - Divco or similar.
    Possible adaptation from a boat (check Franco's Goldenrod now owned by the HAMB's El Jefe.)
    Suspect some early farm equipment might hold a viable solution thought I can't recall a specific example.
    My opinion: Corvair, Vega, or Mustang boxes - while they might work well - are not traditional.
    What are you trying to accomplish exactly?
  7. Might ad that Studebaker used a ross box in '53. It was even set up with a drag link.
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I built an early coupe years ago and used a '55-'59 Chevy truck steering gear.
  9. 2manybillz
    2manybillz
    Early econoline - up to '66 or '67 maybe - don't know about availability though.
  10. enjenjo
    enjenjo
    from swanton oh
    Hudson was popular back in the day.
  11. HotRodFreak
    HotRodFreak
    You mentioned most options....Don't forget the early VW bus box that doesn't need to be reversed...that's traditional also !!!
  12. HotRodFreak
    HotRodFreak
    The 55-59 chev pickup box and column is nearly a bolt in for 32-34 frames and gives options for cool GM or Vette wheels. The later column is shorter because the stock wheel was dished.
    cody1958 likes this.
  13. ibcalaveras
    ibcalaveras
    Dooh! I just sold two of thoses boxes for s**** metal last week. I had been draging them to swap meets for the last three or four years.
  14. hammeredt
    hammeredt
    Does traditional mean mounted forward of the firewall with the drag link running parallel to the frame?
    Early mustang boxes are used often, but not a great solution. The pitman arm sticks up and so throws off ackerman. Street rodder published a series on ch***is set up a few years back (i'll look for the issue) gives the pros and cons of different straight axel setups. Specifically refered to the mustang set up, and when and were to use it ie: good for four link with tube axel; bad for split bones and i-beam (or bones and tube axel).
    I have a mopar box (early 70's duster or similar) in my T coupe-set up for cowl steering. Works great. Would definitely use it again!!
    I've been looking into 48-52 big truck boxes F5-up. No one really makes parts, some are interchangeable, some not. The big problem is the pitman arm is specific to those boxes, F1 will not work.
    In scouting info on the F5 stuff I found that a 79-84 Toyota 4X4 box is a common replacement for the F1(upgrade conversion, not a direct replacement). There is info on the web about this conversion.
    Good Luck H-
  15. "The pitman arm sticks up and so throws off ackerman."
    The pitman arm has absolutely nothing to do with ackerman....nothing !
  16. hammeredt
    hammeredt
    Yes Johnnyfast, you are correct, I did speak incorrectly. The pitman arm does not have anything to do with ackerman. Its position does however greatly affect steering quality with regard to bumpsteer. I incorrectly grouped the need to have the pivot points of the pitman arm/draglink and the radius rods close (so as to have a similar arc), with ackerman.
    Going forward it may be more helpful to all, to include the corrected information rather than just telling someone (and all reading) that he/she is wrong. Knowing one is wrong is only half of the needed information, the corrected information is the other.
    Thanks for pointing out my error.
  17. Sorry if I offended you....it wasn't my intention. The ackerman and bumpsteer principles have been discussed many times on this forum so a simple search should easily locate this information for anyone who is interested.
  18. cody1958
    cody1958
    from wichita ks
    Any other tech articles on here about this set up. I've been searching this for a little bit no luck.
    Texas Webb likes this.
  19. Texas Webb
    Texas Webb
    You get Lone Star in Kansas?Cool.
