Projects The bucket of ugly! A de-uglifying thread...
Discussion in 'The Hokey Ass Message Board' started by need louvers ?, Aug 14, 2013.
  1. jmikee
    jmikee
    from washington
    Very good news.
  2. GASSERBOB
    GASSERBOB
    from USA
    Good for you Fred. Hope everything works for you. Bob..........
  3. RodStRace
    RodStRace
  4. brEad
    brEad
    Congrats & good luck with the new job, Fred!
  5. nobux
    nobux
    I changed out the wheels on my bucket. 44112936_10215035998271666_697465064956887040_o (1).jpg I liked the steel wheels and hubcaps, but as I said before, the plan always was to run a 5 spoke wheel for a mid 60's look.
    gonzo, Stu, AHotRod and 21 others like this.
  6. Jim Bouchard
    Jim Bouchard
    brad2v, loudbang and chryslerfan55 like this.
  7. 26 T Ford RPU
    26 T Ford RPU
    Looks good but I preferred the others as im not a mag guy, but that's me and its yours so enjoy....it does look cool.:cool::cool: JW
  8. tfeverfred
    tfeverfred
    VERY nice!
  9. brEad
    brEad
    @nobux your car looks great with either set of wheels. As previously stated, it just has the right look. I really like the color, too. I think that it puts it right in the era you were targeting.
  10. gonzo
    gonzo
    What a great car.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    The new wheels look great , I've always liked the minimalist look it had , that's why
    I liked it better and the painted wheels fit the look better , painted early 60s , mags late 60s , when the world went to hell in a handbasket..
  12. AndersF
    AndersF
    Problaby the second "T-bucket" ever built.
    This is TV Tommys hotrod after he sold it to Bill Rolland.
    Dannerr, gonzo, brad2v and 3 others like this.
  13. RodStRace
    RodStRace
    chryslerfan55, GuyW and loudbang like this.
  14. RodStRace
    RodStRace
    Or if you really want an old school T...
    https://sfbay.craigslist.org/scz/cto/d/1923-ford-model-roadster-hot/6738500788.html
    Nice all steel 1923 T roadster on a model A frame and running gear with a new rebuilt hopped up fleathead 4 cylinder . Isky cam, Thomas intake , Strindberg 97 Thomas high compression head. New radiator, rebuilt steering box, new 12 volt alt. Running driving hot rod . Not registered but clean ***le in my name. $6000
  15. nobux
    nobux
    I get it. I liked the steel wheels (I can always swap back and forth ).
    The car was like a blank canvas or a white wall before . It needed something.
  16. 2OLD2FAST
    2OLD2FAST
    from illinois
    This is NOT meant to be criticism, with the painted wheels it's the girl you took home to see the parents , with the mags , it's the girl you took to the motel .....
  17. gonzo
    gonzo
    I think I'll just start quoting random pictures that I like from this thread in the hopes that it will inspire more activity. What a cool car.
  18. gonzo
    gonzo
    @AndersF Can you tell me where these dropped tie rod ends came from?
    Edit: Never mind I just saw the link you posted to the Ford 1948-1964 Pickup tie rod ends.
  19. gonzo
    gonzo
  20. RICH B
    RICH B
    Maybe I'm missing something; but how does the drop tie rod end allow enough "swing" room between the steering arm and wishbone.
    When the steering is at full lock the eye on the steering arm is usually right close to the wishbone; from the picture it looks like the drop portion of the rod end would run into the wishbone and limit steering range.
    Compare the dropped tie rod picture with the the of steering of dropped steering arm at full lock.
  21. RodStRace
    RodStRace
  22. tfeverfred
    tfeverfred
    Wow! That's pretty close to what I'm aiming at.
  23. gonzo
    gonzo
    I've never used this set up before, but I have seen people use something similar. You may not be able to mount split wishbones on the frame rails, or maybe you just lose some turning radius.
  24. 26 T Ford RPU
    26 T Ford RPU
    From memory they would work to clear the spring and hangers on a spring behind the axle setup, not to clear the radius rods and would still need the steering arms to be dropped. JW
  25. RICH B
    RICH B
    Just fooling around with some a friend has :); when the "latest and greatest trick part" didn't work on his '33 with split '40 bones, due to the travel; compared the travel on my car with minimum split to the bones, still same stop to stop concern. Just seems easier to heat and bend the stock steering arms; or if not in your skill range; get some bolt-on arms. Figure the best application for these ends would be the F series trucks they are intended for.
    chryslerfan55, loudbang and gonzo like this.
  26. AndersF
    AndersF
    The pic with the steeringarm is on a car that come to sweden.
    We are not allowed to bend steeringarms here so this was used instead .
  27. RICH B
    RICH B
    Thanks for the update and further information.
    Interesting; maybe it is just the picture itself that does not show the clearances well and the tie rod does have enough range of motion.
    Maybe it was the set-up we had, roundback spindles on a 46" SuperBell and split '40 bones on a '33 that was incompatible.
    Question on that picture tho; if you can't bend steering arms over there, how do you get them to even swing fully on an original axle that has been dropped. Wonder how the axle can be heated and dropped but not the arms. Not trying for drama; just curious.
  28. AndersF
    AndersF
    I dont know why its ok to drop a axle but not a steeringarm.
    On my build its the steeringarm that limits how much i can turn my wheels.
    But it seems to be enough for decent steering radius.
    loudbang, 26 T Ford RPU and RICH B like this.
  29. Blue One
    Blue One
    from Alberta
    Got my windshield on with gl*** :cool:
    75DAF0B8-7CC4-4128-9E47-355B4D4D70F0.jpeg CD8FFEB9-23E1-46A6-ADD7-6407CF4F5283.jpeg
  30. gonzo
    gonzo
