  1. olio mattore
    olio mattore
  2. olio mattore
    olio mattore
  3. olio mattore
    olio mattore
  4. olio mattore
    olio mattore
  5. BigO
    BigO
    Bowtie Coupe and chryslerfan55 like this.
  6. olio mattore
    olio mattore
  7. olio mattore
    olio mattore
  8. olio mattore
    olio mattore
  9. Mart
    Mart
    Sleepy afternoon in a small town.
    Havana 1958
  10. 'Mo
    'Mo
  11. JD Miller
    JD Miller
    Oh my god ! a motorcycle ! :eek:
    loudbang, redo32 and chryslerfan55 like this.
  12. ramblin dan
    ramblin dan
    loner1 and chryslerfan55 like this.
  13. ramblin dan
    ramblin dan
  14. 47chevycoupe
    47chevycoupe
    from Finland
  15. noboD
    noboD
    Those tail lights should have been standard equipment on T-birds.
  16. EMD567
    EMD567
    from Wichita
  17. EMD567
    EMD567
    from Wichita
  18. EMD567
    EMD567
    from Wichita
  19. EMD567
    EMD567
    from Wichita
    V-8 conversion kit that Chevrolet offered over the counter for the Chevy II B5563539-B336-44F0-B337-D81F48931F41.jpeg B74AEC98-56CA-4749-B265-698A2E85F88B.jpeg
  20. EMD567
    EMD567
    from Wichita
  21. 1947knuck
    1947knuck
  22. 1947knuck
    1947knuck
  23. JD Miller
    JD Miller
    What, no Big Block V8 Motor? ? ? Come on !
    What is the shroud thing below the radiator, to the right of the sway bar?
  24. 1947knuck
    1947knuck
  25. Scarebird
    Scarebird
    Alliance Vendor
    from Moita, PT
    looks like a spring pocket reinforcement
    dan c, loudbang and chryslerfan55 like this.
  26. EMD567
    EMD567
    from Wichita
    Tower for the floor shift. I suspect the kit came with a template to mark the transmission tunnel to cut the hole (they just used a torch at the factory) and to locate the tower to rivet or tack weld it to the floor.
    47ragtop, Bowtie Coupe, dan c and 2 others like this.
  27. DDDenny
  28. dan c
    dan c
    darryl worked a lot more, but dwayne was in two high-profile series, "bob ***mings show," and "dobie gillis."
