Hot Rods Radiator height relative to thermostat height?
Discussion in 'The Hokey Ass Message Board' started by cktasto, Oct 5, 2018.
  1. cktasto
    cktasto
    Is there a rule of thumb for how high the top of the radiator cap should be above the thermostat in my bbc? Should I measure from top of radiator to top of thermostat instead?
    I'm replacing my cheap ebay radiator/fan set up in the 55' with a new Griffen radiator/fan and want to put it as low as I can between the rails to get as much airflow across it as possible.
    appreciate it
  2. bigdog
    bigdog
    It really doesn't matter as long as you have a fill point at the highest point in the system so you can get the air out. If the radiator is lower you can put a cap in the top radiator hose as a fill. Moroso has one available, I'm sure other manufacturers do too.
    KJSR likes this.
  3. gimpyshotrods
    gimpyshotrods
    scrap metal 48 likes this.
  4. cktasto
    cktasto
    Ah, this is perfect. Thanks guys, i had no idea this existed.
