Projects 1964 Falcon B/FX Build Thread
Discussion in 'The Hokey Ass Message Board' started by fiveoh108, Nov 29, 2011.
  1. fiveoh108
    fiveoh108
  2. loudbang
    OUTSTANDING, CONGRATS you "youngster" :)
    1947knuck and fiveoh108 like this.
  3. powrshftr
    powrshftr
    That’s so cool Mike!Congratulations!
    Scott
    fiveoh108 likes this.
  4. bigmikes50chevy
    bigmikes50chevy
    Congratulations Mike.
    loudbang and fiveoh108 like this.
  5. saltflats
    saltflats
    from Missouri
    Congratulations Mike!!!!!
  6. loveoftiki
    loveoftiki
    from Livonia,Mi
    Man that’s a *****in car...hopefully I’ll get a chance to see it out there
  7. loudbang
    Roy would be busting your balls unmercifully about hanging with those Street Rod Builders LOL. :)
    1947knuck and porkshop like this.
  8. fiveoh108
    fiveoh108
  9. Johnboy34
    Johnboy34
    from Seattle,Wa
    fiveoh108 and loudbang like this.
  10. fiveoh108
    fiveoh108
  11. mad mikey
    mad mikey
    Outstanding car. :)
  12. fiveoh108
    fiveoh108
    Thank you very much! I had my helmet done today
    [​IMG][​IMG][​IMG][​IMG]
    juan motime, Gammz, loudbang and 2 others like this.
  13. mad mikey
    mad mikey
    Nice brain bucket.;):)
  14. Johnboy34
    Johnboy34
    from Seattle,Wa
  15. loudbang
    Helmet needs a Blue Oval :)
    1947knuck, deathrowdave and fiveoh108 like this.
  16. fiveoh108
    fiveoh108
    Agreed!
  17. fiveoh108
    fiveoh108
    Shifter and parachute lever mounted![​IMG][​IMG][​IMG]
    saltflats, loudbang and Gammz like this.
  18. fiveoh108
    fiveoh108
    First Pull on the Dyno today
    [​IMG][​IMG][​IMG]
    mgtstumpy, OahuEli, loudbang and 2 others like this.
  19. Gammz
    Gammz
    from Lincoln Ne
  20. DDDenny
    Mike
    As always great detail work, I can tell you buy into the "less is more" approach.
    Saw the car run at the CHRR with small block power, I bet it will be an eye opener first time out with the big block.
  21. loudbang
    And we have a WINNER folks. :)
    1947knuck, Johnboy34 and fiveoh108 like this.
  22. seb fontana
    seb fontana
    from ct
    What a Torque Curve!!
  23. fiveoh108
    fiveoh108
    Not really a curve when you have 500ft lbs at 3000 RPM lol!
  24. loveoftiki
    loveoftiki
    from Livonia,Mi
    Damn...that’s gonna be fun!
    loudbang and porkshop like this.
  25. fiveoh108
    fiveoh108
    How do I put dad's 427 in my car?[​IMG]
    powrshftr, mgtstumpy, OahuEli and 4 others like this.
  26. saltflats
    saltflats
    from Missouri
    Is 30 degrees of timing all it would take or is that just a number to fill in the blank?
  27. fiveoh108
    fiveoh108
    We ended up setting it at 32, if I want to put better gas in it and go to 36, it would probably go over 600hp. Gives me room to grow!
    powrshftr, Johnboy34, Gammz and 2 others like this.
  28. saltflats
    saltflats
    from Missouri
    That sounds good.
    I am real deep into a 468 inch FE, new experiences for me. Thought maybe they were pron the detonate and that had something to do with the low timing.
    powrshftr, Gammz and loudbang like this.
  29. fiveoh108
    fiveoh108
    It's back in again! Me and my helper got it installed in 43 minutes. Helps with the removable core support!![​IMG][​IMG][​IMG]
  30. loudbang
    Nope not easy to detonate LOL. My FE guru Ed Prouty kept after me to bump it up 2 degrees make a run and check the time on my Super Cobrajet that started off at 38 all in and don't bother looking at a timing light.
    Well needless to say I was a bit leery but he did hold several national NHRA records so I kept at it. Bump 2 degrees check the ET and MPH. It took a few weekends to get that many runs accomplished but finally ET and speed dropped off a bit. He asked any detonation and how do the plugs look? Plugs looked fine and no signs of detonation.
    He said if you want to throw a light on it do it now.......... I was shocked to find it ran BEST at 52 all in mechanical and vacuum. Ran it like that for the rest of the time I had the car and never a detonation problem but it was on Sunoco 260 leaded fuel that was everywhere back in the day.
