Technical Need Vin tag help
Discussion in 'The Hokey Ass Message Board' started by Humboldt Cat, Oct 6, 2018.
  1. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    In spare time, started pecking again at a project Chrysler scored last Spring; this tag on the Newport's inner fender is the closest thing I've found. The friend handed it to me with the keys, the paperwork being looked for.
    Is the VIN hidden within here? There is a bald spot on the door jam where I've seen it on other Newports. Thanks for any help. 20180930_194457.jpeg
    Sent from my LG-US996 using The H.A.M.B. mobile app
  2. squirrel
    someone removed the tag you need, from the bald spot. Sounds like a problem, to me.
  3. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
  4. 56don
    56don
    Need to find out if there is a number stamped on the frame somewhere. Someone may be running around with a car with your vin tag licensed to it.
    Humboldt Cat likes this.
  5. greybeard360
    greybeard360
    Vin should be stamped on the core support.
  6. gearheadruss
    gearheadruss
    from Seattle
    I'm no mopar vin number expert but I don't think the bald spot was a vin number.
    it wasn't on these:
  7. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    When I got this project, it had the front wrap of a '66 300 half-bolted on. I was able to swap wraps with a '65 Newp, but as the Newp was technically a runner, I left its core support/radiator alone, kept the '66 300 core sup.
    If worse comes to worse, and that support has a vin somewhere on it...
  8. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
  9. jeepsterhemi
    jeepsterhemi
    This data plate is from a B body (station wagon 3 seats) and has nothing to do with a C body Newport.
    squirrel likes this.
  10. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    The beige plate pic that I posted?
  11. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Your suggestion reminded me of the orig owner stamped card I'd found in the service pocket of the '66 300s core support last Spring...from March 1966 received_1940191402659746.jpeg
  12. jeepsterhemi
    jeepsterhemi
    Beige (with black interior trim) 318 cu. in. station wagon Belvedere/Satellite ....
  13. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    'So that happened'...thank you for the heads up!
  14. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    He is a good friend, but I think there was a mix up...he had bought a different Newp to sell and this one had to go as part of the deal...he knew I'd tried for a Newp before, we friend-traded some projects. Guy he got it from replied earlier that the VIN tag itself went with the paperwork. That can hopefully be found. "We'll see" when my bud gets back from vaca. Thank you for the help here, even so.
