Hot Rods "THE WALL OF SHAME"
Discussion in 'The Hokey Ass Message Board' started by duncan, Oct 8, 2018.
  1. classiccarjack
    classiccarjack
    I wish I took photos of all the nightmares that I have fixed...
    Some of these cars drove fine amazingly. It is truly a great way to get the hair standing up on your neck once you see something poorly engineered.
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
    chryslerfan55 and vetteguy402 like this.
  2. s55mercury66
    s55mercury66
    from SW Wyoming
    No pictures, but we did have an educational experience with a Ford Country Squire that a friend bought 40 years ago for the 390 that was in it. We learned to check for rusted frames (the front torque boxes were shot), weld penetration (the channel that was welded in to repair the torque boxes had none on the rear welds), and torque steer (it crab walked enough to cover the entire lane from centerline to the white line under throttle). Got that home and pulled the motor and trans together, and learned about wheel chocks (the tripod we were using tipped over with the engine/trans hanging from it when the car rolled away). Next, we learned about the FE unibody bolt pattern for exhaust manifolds, and immediately afterward, learned that people used self adhesive flashing for patches (when my friend kicked the fender on his still non-running Torino GT). All of which is not HAMB friendly, except the shamefulness of it all.
  3. deucemac
    deucemac
    Went to look at a '56 Nomad that was "just restored and painted. Turns out the car had been rolled on the driver's side. Bond was used over every dent and twist. What really got my attention was the styling groves across the top. From the drip rail to center roof, some one made new grooves with a rat tail file? A wobbly grove too!
    chryslerfan55, brad2v and loudbang like this.
  4. LOST ANGEL
    LOST ANGEL
  5. Holy **** !!!
    1927graham and 6inarow like this.
  6. Lost Angel, just seven more of those pics :eek: and you could print an alternative style calender for 2019.
  7. RICH B
    RICH B
    Accidentally saw this great fab work by a professional RR builder on the interweb; makes ya cringe that people would think it is OK to promote this ****.
    el-cheapo-building-a-rat-rod-for-1500-episode-11-backpedaling-2018-04-23_16-44-52_558691-960x720.jpg
  8. iwanaflattie
    iwanaflattie
    Is this @Nads work?
    Steve Ray and chryslerfan55 like this.
  9. 41rodderz
    41rodderz
    from Oregon
    Simply WOW , just WOW:eek:
  10. 41rodderz
    41rodderz
    from Oregon
    Your father-in-law gets a p*** because of quick thinking and a real time fix. He sounds old school and good person to know. If you had a problem, he likely had an answer.
    chryslerfan55 and brad2v like this.
  11. topher5150
    topher5150
    professional Rat Rod builder......???? That's kind of like calling a lot lizard a professional physical the******.
  12. HOTRODPRIMER
    HOTRODPRIMER
    The way Ford made the bracket that attaches to the engine side of the firewall there is a pretty strong return spring. HRP
  13. akoutlaw
    akoutlaw
  14. flt-blk
    flt-blk
    from IL
    4 splices and 3 gauges of wire in a 12" section going to a fuel pump with 1/8" fittings in and out. and there was about 18" of slack in the wire. go figure.
  15. hotrodA
    hotrodA
    Here are a few examples of the caveman engineering that I found on my old hot rodded 32 sedan.
    Bubba boxes the frame then realizes that he still needed to mount the steering box
    That rear crossmember is wedged in TIGHT, it don't need welding!
    Time to patch that hole in the firewall.
    1/4" ought to be strong enough.
    Need some clearance for those rear shocks? No problem.
    And lastly, if a little filler is good, more is better. So what if it's still uncured after 20 years.
  16. Now we're rolling. Great stuff, and all this time I've been using my hammer to make pedals. Apparently I've been doing it all wrong.
  17. Atwater Mike
    Atwater Mike
    Friend of mine had me drop around to a young guy's house to 'look over' his wiring installation. A '50 Ford with SBF/C4 ****** had been 'rewired' with a Painless kit, but the wires (which went to specific stations, per the instructions) ...were all left the original lengths, as they came out of the bags.
    There were loops and bundles, underhood and dash...and under the car, gathered and tie-wrapped, wired around the frame rails...
    Plastic insulated ends were crimped, neatly; just 3 to 10 feet too much wire length!
    "Why didn't you trim and fit them?"
    The kid answered, "What is it you don't understand about changing wire resistance by cutting lengths off?"
    Must be something.....
  18. wackdaddy
    wackdaddy
    Got some rotted out corners on your model a? No problem ... just weld some 1/8 inch plate across them and fill it with mud. All those belt lines and body lines are overrated anyways eh?? fullsizeoutput_3c3.jpeg
  19. I have seen more bodged and mangled wiring then anything else in my years fixing stuff
    Fuses wrapped in cigarette foil
    Marrettes, different gauges of wire, wire too long, wire too short
    Power wires to nowhere and live
    Stacks and stacks of ground wires
    What I call “ terminal cancer”. Where any new run of power or ground comes directly off the battery post, battery ends up looking like a Rastafarian with his dreadlocks in pig tails !!
    Like I say, and also do.... if you don’t know ask questions , we live in a time of google and YouTube EVERYTHING is on the internet now-a-days just stop looking at **** for a minute and do a search!!!
    Still say the car elpollacko fixed a few years back with pipe wrenches in the steering system and rebar used in the suspension takes the cake !!
  20. 56don
    56don
  21. cshades
    cshades
    from wi
    I had a new customer come in back in the fall of 2009 with a newly purchased '32 5 window coupe. He wanted some updating done because it sat too high, had 13" wheels and just looked wrong. It had been hot rodded by the PO who basically bought a '76 v8 mustang II and used pretty much everything he could off it he could. Including the 4 bolt wheels, wire wheel covers, steering column, wiring and trim. The license plate actually said "32tang" He did buy an aftermarket must II crossmember and weld it in. As I was going through the car I noticed the steering shaft looked like junkyard parts cobbled together. I removed the conduit clamp that was being used as a support bearing and the shaft fell out of one of the joints on to the floor of the shop. The joints are cobbled onto the shaft and the one shaft is actually a ratchet handle that has 2 flats ground into it and welded to a joint. I showed it to the customer and he said "good thing it didn't fall off when I was doing 70 with my BIL in the car". The old guy that he had bought it from stopped in one day later on when I was doing some other things to it. He gave me some of the history on it since he had purchased it in 1949, including telling me how he had stopped at a hot rod shop back in the 80's to see about getting the mustang II stuff installed. He looked at what the guy was doing and decided it was easy and the guy was charging too much for what he was doing. I didn't want to get into a fight with a 90 yo man so i just let it go. steer shaft 001.JPG steer shaft 003.JPG steer shaft 001.JPG steer shaft 003.JPG
  22. Cliff Ramsdell
    Cliff Ramsdell
    New meaning to hammered behind the wheel... I’m just saying.
    Cliff Ramsdell
    VANDENPLAS likes this.
  23. Bleach
    Bleach
    Sounds like something I would do to my own beaters back in the day but none of that would have lasted long enough to sell to anyone but a junk yard. :p
    It probably still stinks from the dead vermin that crawled behind the rocker panels. That roof patch pretty much keeps everything free from pests. ;)
    Now if it has duct tape on the wiring splices and tinfoiled or paper clip fuses, it could be something I made.
    mgtstumpy, junkjunky, BigO and 4 others like this.
  24. Cliff Ramsdell
    Cliff Ramsdell
    Had a customer come in to the garage in New Hampshire back in the mid 70’s for an inspection sticker. Rear frame rail was rotted out on his mercury comet if I recall and the spring was poking thru the floor of the car.
    Told him no way, gotta fix it first. Came back a few days later with a 2x4 lagged into the remains of the rear frame rail with the shackle thru it an a piece of plywood for a floor board.
    Turns out he wasn’t a mechanic (you think??) he was a carpenter and he figured if it holds up a house it should hold up his car, true ****.
    Cliff Ramsdell
    mgtstumpy, BigO, brad2v and 1 other person like this.
  25. 62rebel
    62rebel
    Cliff, that sounds like every Mustang I saw during the late-70's into the mid-90's. One had 18" of angle iron welded to the trunk floor in a vain attempt to keep the springs from coming through. Not MY work. I DID weld a different pair of tie rod sleeves together after slicing them in half but ONLY to put the steering together to move the car around. Got rid of them as SOON as I got the right parts together and driving that car ALWAYS gave me ****hole pucker syndrome
  26. 4wd1936
    4wd1936
    from NY
    I think Lost Angel wins the trophy with 2nd and 3rd close behind. WOW
  27. Cliff Ramsdell
    Cliff Ramsdell
    Frame I bought for my Model A. Had a flattened 32/34 rear cross member in there but when I measured the frame for square it was way out and one side was longer than the other by 3/4”
    Cliff Ramsdell
    889A0866-A865-4021-9884-1912DEC78BBB.jpeg DD31AE74-4EDD-4A71-A03A-CF41EF71CAEC.jpeg
    mgtstumpy and brad2v like this.
  28. Bleach
    Bleach
    Busted spring, NO PROBLEM!
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ They also make good retainers for holding compressed springs.
