History 1933 - 1936 Willys, picture thread
Discussion in 'Traditional Hot Rods' started by WillysRule, Dec 5, 2010.
  1. 1934coupe
    1934coupe
    Steve it was good seeing you in person. I'm tired right now will gather up my thoughts tomorrow.
    Pat
  2. The hinges are missing the bracket part, did you get those also? The handle in a curved "T" is rumble seat and the other is correct for a trunk. The short side goes toward the bottom, long side up. The tail light bucket and license plate bracket is also correct
  3. drumyn29
    drumyn29
    I knew that you would have the answer. Now I need to find the missing tail light parts.
  4. '34 Terraplane
    '34 Terraplane
    from Western PA
    some old photos of mine I found while looking for something else....
  5. drumyn29
    drumyn29
  6. steveo3377
    steveo3377
    image.jpg Need help identifying these headlite rings and lenses,,,, mid 60's Volkswagen?
    1947knuck, mgtstumpy and Bowtie Coupe like this.
  8. drumyn29
    drumyn29
    does this tail light only need the glass lenses or does the red lens need a metal band to secure it.
    mgtstumpy and loudbang like this.
  9. Just a red lens for the stop. Its a bear to get in without chipping the edges but just takes a little practice and patients. That spring steel piece pushes out the lens. A white lens goes on top to light up the license plate, there's two small screws and brackets to hold that in.
    1934coupe and loudbang like this.
  10. loudbang
  11. willys36
    willys36
    I tried early Chevy and VW rims but neither fit very well. I final bought a set of repro glass lenses and made my own rims from 1/4" aluminum with a jig saw, router to roll the edges, and polisher. I also made the headlight bucket by breaking the front out of a standard sealed beam and making a male mold of the parabola. I then laid up fiberglass buckets off that mold and had them chrome plated. Work pretty well! That green blob is the Willys headlight bucket mold propping up the fiberglass mold for my Mysterion clone.
  12. flatheadgary
    flatheadgary
    from boron,ca
    in my o/t car i used a funnel for the mold. just glassed them in. worked great.
  13. willys36
    willys36
    got pictures?
  14. flatheadgary
    flatheadgary
    from boron,ca
    i have to get my computer fixed as it will not attach anything. it fried once and after the rebuild it still had problems. this is still one of them. i haven't had the money to pay for the fix.
  15. willys36
    willys36
    Bowtie Coupe and loudbang like this.
  16. quick85
    quick85
  17. willys36
    willys36
  18. Adam Fitting
    Adam Fitting
    Last picture with the 377" small block at 9.56 et Going with a new set up next year. The old 377 only went 13 years without freshening and will go in the daughter in laws 57 bell air LOL govcup2018.jpg
  19. Adam Fitting
    Adam Fitting
  20. Adam Fitting
    Adam Fitting
    Holy Moly I just took a time warp. Great memories with that car in Brisbane!!
  21. Adam Fitting
    Adam Fitting
    Yes it is. But with a blown 350. The other Willys is Bill Fittings that will be back out on the road in a few months.
  22. loudbang
  23. quick85
    quick85
    Sioux City Dragway, June 1970...A Justin Lewis photo:
  24. quick85
    quick85
    I'm not positive but this might be at Indy, 1995.
  25. loudbang
    Ohio George Malco gasser draining the coolant.
  26. Oldtin77
    Oldtin77
  27. Oldtin77
    Oldtin77
    mgtstumpy and chryslerfan55 like this.
  28. loudbang
    mgtstumpy, chryslerfan55 and enloe like this.
  29. 1940Willys
    1940Willys
  30. @Oldtin77 tell us more about it. Do you own it now? What are your plans for it, are you planning on taking it back to as raced? How about some more pics and details as eng/trans, rear end wheels and such.
