Projects Jack stands that will go under the tires
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Oct 10, 2018.
  1. junkyardjeff
    junkyardjeff
    I need to get my 55 sunliner up in the air to go over it for the Florida trip,since its a convertible it does flex alot and since I do not need to take the tires off I would like to put something under all four tires so I can open and shut the doors easily. So are there any stands available that can be put under the tires so the car can sit on the suspension and yes I can put stands under the suspension but can get in the way while working under the car.
  2. lothiandon1940
    lothiandon1940
    Do you have a set of ramps? Or can you borrow a set from someone and buy a set for yourself if you don't already have a set? That way you can drive the car up on one set, then jack the other end up and place that end on the other set of ramps......Done!
  3. slowmotion
    slowmotion
    Run it up on ramps in the front, jack stands under the axle in back. Don't skimp on quality of either.
    54vicky, Just Gary and lothiandon1940 like this.
  4. lothiandon1940
    lothiandon1940
  5. lothiandon1940
    lothiandon1940
    .........Good idea, but I think he wants the car to sit on the tires.
    lothianwilly71 likes this.
  6. lothiandon1940
    lothiandon1940
    You can even turn the ramps around on one end (the end you jack up) so they aren't in your way when under the car.
  7. verde742
    verde742
    gee, problem solved, well, ALRIGHT !!!!
    lothiandon1940 likes this.
    Forklift stands
    About $300 Canadian for the set
    I have an old set at home in my garage work great!
    dwollam, swade41, nunattax and 7 others like this.
  9. s55mercury66
    s55mercury66
    from SW Wyoming
    Be careful if you use ramps front and rear, point them in opposite directions so the car CAN'T roll off of them.
  10. Sheep Dip
    Sheep Dip
    from Central Ca
    Don't know how high you need it but many moons ago us money poor teenagers used spare tires....made pulling ******'s/clutches etc. much easier.
    54vicky likes this.
  11. Mr48chev
    The do make some ramps that you can remove the ramp part to just have a stand under the tire.
    20 bucks or so worth of lumber would make some solid stands too. You could make them what ever height you wanted within reason. 2x4 under car stand2.jpg
    dwollam, kbgreen, Racer29 and 17 others like this.
  12. lothiandon1940
    lothiandon1940
    .................I like that "within reason" part.:D
    slowmotion and Hnstray like this.
  13. junkyardjeff
    junkyardjeff
    I like this idea and looks like time to make some.
  14. slowmotion
    slowmotion
    The problem with stands under the tires is jacking the car high enough to make it worth while. It can take some finagling using standard garage fair floor jacks with a rise of 18-20 inches or so. Be careful. It's the reason I suggested the stands under the axle in back....;)
  15. lothiandon1940
    lothiandon1940
    I'm with you.:)
    slowmotion and 54vicky like this.
  16. chopped
    chopped
    I kept four rims for this.
    tb33anda3rd likes this.
  17. rockable
    rockable
    I'm going to build some of these to go with my 2 post lift. No problem in jacking it up and gives a great way to work on the car with the suspension loaded. Exhaust system and suspension development come to mind.
    What length of boards do you recommend? Looks like about 16".
  18. junkyardjeff
    junkyardjeff
    I think I am going to look for four junk deep offset rims to use as stands for now until I can make some out of wood,if I can get it up 8 to 10 inches it will be enough for me to slide under it.
  19. lothiandon1940
    lothiandon1940
    ..................Man, you need to eat more pizza!:D;)
  20. rusty1
    rusty1
    ,,,I made these boxes to use when I'm building a project, work great
    dwollam and lothiandon1940 like this.
  21. I put the front on ramps, and the rear axle is supported by jackstands. Suspension is loaded that way, no flexing.
    High enough to R/R transmission. (From experience)
    54vicky and lothiandon1940 like this.
  22. Blue One
    Blue One
    from Alberta
    You could always build something like I did from 3/16” steel plate.
    12” high,they work really well.
    47EF3BFC-2D46-40CE-B585-460FE0929485.jpeg 0CC31A02-0104-436F-81FE-CBBBF3A4D0A7.jpeg 314245B0-B532-48EB-8997-871A45B564A6.jpeg 7A87679D-226B-4555-8F10-F734E83528AA.jpeg 03951C99-287B-4B68-B3C0-B7D1EAED4FCD.jpeg F8841896-9510-41C5-BA1B-97BC4E2450D5.jpeg
  23. lothiandon1940
    lothiandon1940
    ^^^^^Very nice work^^^
    lothianwilly71 and Blue One like this.
  24. khead47
    khead47
    Something is fishy if the frame flexes that much ! I worked at the FoMoCo frame plant for years. Convertible frames are more stout than sedans or hardtops.
    FrankenRodz likes this.
  25. jimmy six
    jimmy six
    Love the "correct V8" on the light bar....
    I use some 6x8x18" cut cribbing blocks I left my last job with.
    Blue One likes this.
  26. Finn Jensen
    Finn Jensen
    These or similar would really come in handy for checking rear-end pinion angle -- to get the car level with all weight on the wheels.
    lothiandon1940 and Blue One like this.
  27. flynstone
    flynstone
    my dad would curb one side, ramps the other.. then change
    the oil
  28. junkyardjeff
    junkyardjeff
    It flexes enough that the doors will not open right if jacked up on one side so when on stands I try to keep it even,if a the tires do not have to come off I want to put something under each tire if possible.
  29. Blues4U
    Blues4U
    from So Cal
    Not sure I'd do that with soft pine from the local Home Depot, I'd trust them more if made with hard wood. Some pallets are hardwood, might be a better source of material if you can find them.
    Boneyard51 likes this.
  30. Boneyard51
    Boneyard51
    I think the way Mr48 Chevy design it, soft wood should be strong enough, BUT, for added strength a layer of 7/16 plywood could be installed under the top boards. This would give some insurance.
    That pallet wood is often very hard to work with and is sometimes dimensionaly challenged. Ask me how I know! Lol
    Bones
