Hot Rods "THE WALL OF SHAME"
Discussion in 'The Hokey Ass Message Board' started by duncan, Oct 8, 2018.
  1. 56don
    56don
    Seriously? Can you post a pic of it, thats hard to believe.
  2. treb11
    treb11
    I went to a "body shop" once and a guy was taking out the road sign+rivets+ bondo quarter repairs and replacing them. With unformed a/c duct tin....... and rivets....... and bondo..... Car was a 55-57 T-bird.
  3. Deere boy
    Deere boy
    I don't know about anyone else but I'm feeling a lot better about my "skills" after viewing this thread.
    bobbytnm, 1953naegle, indyjps and 4 others like this.
  4. dumpster floor patch
    mgtstumpy likes this.
  5. 392
    392
    Funny stuff.
  6. loudbang likes this.
  7. 62rebel
    62rebel
    That drag link mod is actually fairly common; scary as hell, but common
  8. BamaMav
    BamaMav
    from Berry, AL
    Wheel doesn't fit? Just burn some new holes in it! 100_1720_zps431075e5.jpg 100_2721_zps4fid1kdw.jpg
    Don't worry about phasing the U joints, it'll work with them any old way
  9. vetteguy402
    vetteguy402
    from omaha, ne
    Where did you pry that from? Inner rocker and floor?
    Sent from my SM-G955U using The H.A.M.B. mobile app
  10. classiccarjack
    classiccarjack
  11. yep. I think HURST made them but looked a lot better
  12. Xtrom
    Xtrom
    from Forman, ND
  13. topher5150
    topher5150
    I had an OT car with aftermarket wheels on it and the center whole opening was about a couple of millimeters bigger than the hub and that had a significant shake to it. I can't imagine that car being derivable at all.
  14. '51 Norm
    '51 Norm
    from colorado
    Augh! You guys are giving away all of my secrets!
    GuyW, pitman and loudbang like this.
  15. wicarnut
    wicarnut
    It appears that not all car builders are craftsmen, I am amazed by some of the welding in the Pic's, WOW !
  16. 62rebel
    62rebel
    SWWWEEET Jeeebus. Some folks ought not have access to tools and torches, nor sharp objects. It's against the common good.
    loudbang and vetteguy402 like this.
  17. Boneyard51
    Boneyard51
    I can’t believe some of these welds, they don’t look like they would hold for a minute. At least the dropped tie rod had heavy material and pretty good welds.
    Here on the HAMB I keep hearing about “ no welds” on the steering. Then I read about a guy cutting a steering box in two and welding it back together and that’s ok.Then I see these “ manufacturered “ couplings that are way weaker than a good weld being accepted.
    Then I go to the Indianapolis 500 Museum and see the weld on the steering on one of the Unsers race cars.
    Kinda hard to figure 4FA61741-DDD4-43C1-874A-17A2FC335E73.jpeg 9B849085-3652-43FD-A11B-C184C5543F28.jpeg 57CB0C88-EC2E-40D8-86F3-E2B38AB1F8C6.jpeg what’s right and what’s wrong with all this.
    I figure if it’s safe enough for an Indy car, it ought to be safe for a street car.
    Just my .02.
    Bones
  18. goldmountain
    goldmountain
    I Don't have a picture, but I know about a car that had its frame boxed with wood that was molded in with bondo.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  19. Kerrynzl
    Kerrynzl
    Most of those comments here, relate to steering components below the steering box , not the steering column shown in your post [which usually has a 16:1 mechanical advantage]
    If you ever do a Brinell test on a weld, you will notice that most welds are stronger than the parent material. Also the material next to the weld is usually softer than the parent material.
    Most welders kid themselves that their welds are stronger than the job they're welding, but don't realize their welding is actually weakening the parent material next to the weld
    The proper fix [usually at the high-end fabrication level] is to anneal the whole piece then heat treat it again.
    I had a cut and welded countershaft in a M22 that was done this way [I fed 650ft/lbs through it]
    I've also had a welded pitman arm on my old Road Race car , It never bothered me at 170+ mph.
    In the spirit of this thread, I'll add this
  20. jeepsterhemi
    jeepsterhemi
    KKrod, mgtstumpy and brad2v like this.
  21. topher5150
    topher5150
    I get the feeling that if that person were to take the rail road tracks a bit to fast the coil springs might end up in the trunk
  22. 62rebel
    62rebel
    I never thought I'd say this, but there's something to be said for whipping out your checkbook and paying someone else to do stuff for you, now that I've seen the extent of jack***ery that has gone before and continues today!
    Nicholas Coe, loudbang and LOST ANGEL like this.
  23. GuyW
    GuyW
    LOL - well several British sports cars from the '30s into the early '50s came with OEM wood frames!
  24. 56don
    56don
    When I was building my 34 pickup, the frame was rotted in two in a few places and every part attached to it was such solid rust and pits that I could not use any of it. I found out that I could buy a built frame that was built on a jig for roughly the same money as me buying the rails and crossmembers and doing it on my garage floor. So I went with a professionally built frame.
    Unfortunately, I found out later that it was less than correct, but still workable.
    Check every measurement on a pro built frame before you start putting your suspension components on it....lesson learned.
  25. XXL__
    XXL__
    Oh, Unilugs.
    Maverick Daddy and loudbang like this.
  26. verde742
    verde742
    Its Only temporary,,, Unless it works.....:rolleyes:
  27. brad2v
    brad2v
  28. brad2v
    brad2v
    My wall hanger likely belongs on a different thread, as it's simply an example of a part that wished very much to remain where it resided for decades. smashdrum.jpg
