Projects '31 Model A Coupe Build: "Spooky"
Discussion in 'Traditional Hot Rods' started by brianf31, Aug 15, 2017.
  1. Crusty Chevy
    Crusty Chevy
    Brian, It was good to see you again and check out spooky in person. Thanks for letting me sit in it. I will always probably have the A bug for the "next one" and always been a coupe man but dang that is a tiny little car once you take 4" out of the roof. -Larry
  2. brianf31
    brianf31
    It was good to see you, Larry. You know, if I would have had a better body that wasn't totally rotted on the bottom, I would have ran it unchanneled on '32 rails. That with a mild 2 1/2" chop would give an additional. 5 1/2" of headroom.
    brEad likes this.
  3. brianf31
    brianf31
  4. Crusty Chevy
    Crusty Chevy
    loudbang and brianf31 like this.
  5. loudbang and brianf31 like this.
  6. loudbang
    You need bigger tires or a lighter foot LOL. :)
    1947knuck and brianf31 like this.
  7. Gammz
    Gammz
    from Lincoln Ne
    brianf31 and loudbang like this.
  8. 6sally6
    6sally6
    Suuu-weeet sound'in little Ford! Anxious to see/hear it with all the "stuff" on it!
    6sally6
    PS.......Use to live in Swainsboro, Ga.
  9. Bugguts
    Bugguts
    Great job! The video felt like I was along for the ride and loving it!
  10. brianf31
    brianf31
    Thanks. I wish the kid would have turned the camera sideways. Heck, I wish I would have recorded the grin on his face driving it back. It was his first time driving a stick.
    Gammz and loudbang like this.
  11. brEad
    brEad
    Great video, motor sounds nasty!
  12. brianf31
    brianf31
    Shifter boot bump added to the trans tunnel. I plan to replace the tunnel sheet metal screws with 10-24 machine screws and rivnuts.
    Deutscher, dwollam, Just Gary and 5 others like this.
  13. brianf31
    brianf31
    I used a Ford 10" drum to bend the straight Bratton's drip molding. I made a hammer form dolly from 1/4 plate by cutting a radius to match the drum. A piece of 1/2 tubing was placed inside the molding to keep it from collapsing. The 3 lb hammer provided motivation.
  14. brianf31
    brianf31
    Deutscher, Jet96, dwollam and 7 others like this.
  15. brianf31
    brianf31
    painted.jpg Radiator fan shroud from a couple of turkey roasting pans. 20181201_103036.jpg
  16. Mike Colemire
    Mike Colemire
    That is sweet.
  17. triumph 1
    triumph 1
    That shroud came out really nice, what a great ideas using the turkey pans.
    loudbang, JUNK ROD and brianf31 like this.
  18. brianf31
    brianf31
    I wish I could claim it but I saw that trick right here on the HAMB.
    loudbang and JUNK ROD like this.
  19. csf64ss
    csf64ss
    brian !..I am a gearhead for life...(I just had knee replaced so i'm reading non stop) and I have enjoyed reading every post here !...absolutely loved everything especially the Family aspect...great build !...continued success with it.....charlie
  20. sloppy jalopies
    sloppy jalopies
    Bird pan idea rocks !... consider it stolen...
    I baste my turkeys with Dr. pepper.... for car events I use Wallmart's Dr. thunder...
    ......… I call those "Dr. Thunderbirds" !
  21. brianf31
    brianf31
    The exhaust guy was concerned about overheating the master cylinder so he dropped the pipes down a bit. It's a little lower than I wanted them but I haven't had any ground clearance issues and you can't really notice it unless you squat.
    I'm thinking about adding a crossover pipe to smooth out the Porter shorty mufflers a bit. You can hear 'em 5 miles away when you romp on it.
    Deutscher, mvee33, Jet96 and 11 others like this.
  22. stinson
    stinson
    from alabama
    Primer and Americans on a chopped channeled coupe, what a tough profile. Great inspiring home built work too
    loudbang, brianf31 and Just Gary like this.
  23. grdra1
    grdra1
    Nice work
  24. Mike Colemire
    Mike Colemire
    That first pic there is just bad a$$! Perfect stance and the wheel and tire combo is perfect. Very nice job.
  25. brianf31
    brianf31
    Thanks Mike!
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
  26. Tim
    Tim
    from KCMO
    Looks killer man!
  27. 343w
    343w
    Nothing better than a build with the boys, years of memories for your family. Great job with the build, thanks for sharing with us here.
  28. 343w
    343w
    great idea for bending the drip rails, I will copy for my tudor!
    brianf31, loudbang and JUNK ROD like this.
  29. Tim
    Tim
    from KCMO
    On the note of drip rails, how did you end up attaching them? I keep worrying about water getting between them and the body.
