Projects Do you replace the wood in the floors with metal ?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Oct 15, 2018.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Or do you think if it was good enough for Henry it's good enough for me? HRP
    3W JOHN, dana barlow and olscrounger like this.
  2. Tim
    Tim
    from KCMO
    Good enough for me
  3. I replace it
    I hate wood
    wish my house was welded together
  4. HOTRODPRIMER
    HOTRODPRIMER
    I kept the original wood in the deuce, all the sheet metal is original and the wood was perfect so it is still in place.
    <------------- HRP
    no wood
    Henry was cheaper than me
  6. Al's.C.D.T
    Al's.C.D.T
    Danny as you now the Center Door has loads of wood in it.
    I have only replaced where necessary so my option if it's okay leave well alone, however if it looks suspect and you can tell with wood, replace where necessary.
    I did replace the flooring.
    Steel is real and Wood is good. :D
    3W JOHN and HOTRODPRIMER like this.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Yes sir, He had his suppliers build wooden boxes to his spec and when taken apart they fit the floors perfectly.HRP
    WC145, 3W JOHN, dana barlow and 4 others like this.
  8. oldsman41
    oldsman41
    I replace the wood with metal in the As. But that’s because i never got one nice enough to have good wood in them lucky if they got a floor at all.
  9. Russ B
    Russ B
    Wood. It is everywhere in my cabriolet, sub-rails, cross-rails, B-pillars, doors, top, etc. the body was skinned over the wood structure. It took me several years to fit and replace it all.
  10. cederholm
    cederholm
    I'm not a fan of wood in general, but it's staying!
  11. Rocky
    Rocky
    Classified Editor
    Joel W, 3W JOHN, williebill and 3 others like this.
  12. Frankie47
    Frankie47
    from omaha ne.
    I heard he did the same thing with the larger truck cab before he started making the Cabs out of metal.
  13. lucky ink
    lucky ink
    Wood here it's still good never really thought about replacing it.
  14. Kiwi 4d
    Kiwi 4d
    Good oak ,a clear finish, no carpet works for me.
  15. tombstone
    tombstone
    from sk.canada
    Have done both, Wood probably insulates noise/heat better but with all the new insulation out there I tend to lean towards steel, I personally can work with steel better than wood . I guess it all comes down to what one prefers....... floor in a 32 fordor we just did .....
    3W JOHN, williebill, 54reno and 2 others like this.
  16. T&A Flathead
    T&A Flathead
    I use the wood every chance I get.
  17. jaw22w
    jaw22w
    from Indiana
    26 T coupe. IMG_1386.JPG Replaced all the wood in the floor with steel. Roof wood and window wood replaced with new wood. IMG_1388.JPG
  18. tb33anda3rd
    tb33anda3rd
  19. Atwater Mike
    Atwater Mike
    That steel floor...Man, it's great. The Coupe? It's "A flivver no more"!
    I'm still debating about wood or steel in my '27 Hiboy tub. Steel has it, but the wood floor inserts are Sooo sound insulating. (like you'd notice in an open bathtub with big H-P!)
  20. Rickybop
    Rickybop
    No wood floors?
    Oh well...no more ice-fishin' in the car...
  21. 41rodderz
    41rodderz
    from Oregon
    My 31 from years ago , had 3/4 wood for flooring. I look back and I guess it was okay. I bought it like that. That was the only one. I prefer overkill and plenty of safety. 27 T is all new metal as in subframe, floor and frame. Solidfy is my motto.
  22. stanlow69
    stanlow69
    Was planning on putting wood back in the floors of my project. Took a measurement this past weekend.
  23. jaw22w
    jaw22w
    from Indiana
    Thank you. That car is solid as a rock. No squeaks or rattles with that steel floor all welded in. I have that peel and stick roofing material over the steel. Then 1/2" carpet padding, then carpet, then pads over the carpet. It is surprisingly quiet for a 92 year old body.
    HOTRODPRIMER likes this.
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Rot or Rust, that is the question.
  25. missysdad1
    missysdad1
    Depends on the car and the configuration. My newest project, the Arin Cee Roadster, shows how well an all-wood floor can be built into a '28 - '29 Model A highboy roadster. Wood like this exterior grade 3/4" plywood is relatively light weight and requires no substructure for rigidity. It also requires no soundproofing and is easily removed for repairs and/or frame and running gear modifications. Won't work for everybody in every case but this is the second Model A I've built this way and I like it.
    cederholm, 3W JOHN, GuyW and 4 others like this.
  26. The 39 guy
    The 39 guy
    Well a 40 ford does not have much wood but I did choose to glue some 1/8 inch aluminum to the bottom of the front floor boards and the top of the trunk tool box covers.
  27. Tim
    Tim
    from KCMO
    Now that must have been a wonky looking box! Anyone have photos?
  28. Deuce Daddy Don
    Deuce Daddy Don
    Replaced mine in 1994, with 16 ga. sheet, works great.
  29. Justin in PA
    Justin in PA
    That is a myth.
    3W JOHN, HOTRODPRIMER and Tim like this.
