Projects Do you replace the wood in the floors with metal ?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Oct 15, 2018.
  1. woodhawg
    woodhawg
    Mine wood (sp) fall apart without wood. Floor, body supports and nice trim on top of panel behind seat.
    3W JOHN and HOTRODPRIMER like this.
  2. Ned Ludd
    Ned Ludd
    Wood actually wasn't "good" enough for Henry. He would replace every accessible, vernacular technique or process with an exclusive, capitalization-dependent one as soon as he himself was technically and financially able. Thus he was resolutely headed to more sheetmetal presses and fewer carpenters.
    Most of the technological history of the automobile is about making it impossible for ordinary people to make cars. The technological history of hot-rodding is about pushing back against that, especially as regards making fast cars.
    Personally I'd like to see even more wood in a car than was common c.1930.
  3. bowie
    bowie
    On a Hot Rod I prefer steel. With a stock subframe and a flatty or a banger, I ‘m sure wood is fine. In my channeled 3W and my zee frame “A” coupe , I used 3/16” plate bolted in place in the p***enger area and welded in the trunk area. Kinda my idea of a blow proof floor. They have both been in place since the late 70’s/early 80’s with no troubles .
  4. patzfab
    patzfab
    from Canada
    My 30 A Cab still has all the wood subframe, but everything else is steel. Replaced the door wood with steel, and covered most of the subframe with 18ga steel.
  5. ct1932ford
    ct1932ford
    I keep it as it was! :cool: I like wood, just wish I had more at my age.:rolleyes:
  6. greg32
    greg32
    from Indiana
    Wood is quiet and doesn't transfer heat. Leave it.
  7. F&J
    F&J
    a car brand that has lots of wood framing just sounds and rides so differently. ...in a great way.
  8. Blake 27
    Blake 27
    In a early car I prefer wood. I used Baltic Birch, 1/2"-9 ply. It's strong, stable,and reduces heat transfer. HPIM0902.JPG HPIM0903.JPG HPIM0904.JPG DSC02597.JPG DSC02596.JPG
  9. HOTRODPRIMER
    HOTRODPRIMER
    3W JOHN likes this.
  10. jazz1
    jazz1
    I would use wood floor. It’s quieter and safe. Company I worked for had 1” plywood installed under floor boards of our COEs after a clutch exploded and drivers foot near severed
  11. Just Gary
    Just Gary
    I replaced my '28 Tudor's floors with metal; the wood was too hard to weld. :rolleyes:
  12. 3W JOHN
    3W JOHN
    Wood for me.
    HOTRODPRIMER likes this.
  13. Packrat
    Packrat
    HOTRODPRIMER and 3W JOHN like this.
  14. Barn Hunter
    Barn Hunter
    My 29 came with a *****in floor and firewall. It's staying that way.
  15. Never2old
    Never2old
    from so cal
    Didn’t on my deuce or my A. Saw no need to.
  16. GuyW
    GuyW
    Exterior plywood / stain / epoxy for floor. Structural stuff - prolly replace with steel.
  17. paul55
    paul55
    from michigan
    We use wood in our early Chevys of course, but we skin the underside with sheetmetal and paint for a smooth, clean look.
  18. Torkwrench
    Torkwrench
    I had an all steel floor installed in my 34. However, Henry didn't build it.....Alfred P. Sloan, and William S. Knudsen did. The rest of the wood is still there. About 90% of the original wood was still very solid. The bad parts were all in the floor, sub-rails, and door bottoms.
  19. Slopok
    Slopok
    When the metal floor rusted out in a '59 Chevy Wagon I had years ago, I repaired it with wood!:eek:
  20. Pewsplace
    Pewsplace
    Henry used so much wood in the 33-36 roadsters/phaetons that is very expensive to replace in wood. I use steel and like the ease of working and welding the doors and cowl areas. Wood deteriorates in open cars as steel does not.
  21. Rocky72
    Rocky72
    from Pa.
    I put a wood floor in my 36 Chevy pickup and I talked to a guy about spraying it with bed liner to seal it .
  22. raymay
    raymay
    In the 70's when I worked at Kodak we had a wood salvage where I found all kinds of great pieces for car and home projects. Our favorite was the pieces of PlyMetal (plywood with sheets of metal on both sides). It was easy to work with, strong and ended up becoming the choice for floor pans in some of the streetrod projects we worked on.
  23. jazz1
    jazz1
    Wood is even popular in OT vehicles. I found 12" diameter piece 1" plywood sealing a hole and while acting as a rear body mount on a nissan truck. I was not overly surprised:D
  24. cederholm
    cederholm
  25. Blue One
    Blue One
    from Alberta
    Since I'm a welder and there was absolutely nothing for a floor or even subrails in my T body when I started I went with all metal.
    And I also made the floor panels and part of the transmission tunnel removable for service.
  26. HOTRODPRIMER
    HOTRODPRIMER
    Wow Larry, your work is beautiful.. HRP
    3W JOHN and Blue One like this.
  27. HOTRODPRIMER
    HOTRODPRIMER
    I also replaced some of the floor wood in the cargo area but kept the wood on the back of the rear seat where it folds forward to extend the cargo area in our Ranch Wagon
    It was originally covered by a heavy rubber mat but we decided to go back with carpet. HRP
  28. 3W JOHN
    3W JOHN
    I had wood in the floor of my tub.
  29. HOTRODPRIMER
    HOTRODPRIMER
    We replaced the wood with steel in the old Deuce pickup. HRP
