Technical Do you ever use your stickwelder anymore?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Oct 17, 2018.
  1. jazz1
    jazz1
    I only work on autos. Have no need for stick. Stick welder had been taking up space the past 15 years. Never even used it to weld in top hats or crossmember. We are not welding pipe or tubes or mystery metals. I know that stuff, my boy is boiler maker. When he was at trade school they only used stick
  2. dan31
    dan31
    Sure I use it,I can fit about 6 or 7 empty coffee cups on mine.
    49ratfink and jazz1 like this.
  3. Boneyard51
    Boneyard51
    Alan, some guys on here might not know about welding boiler tubes. I worked a shut down in Kethecan , Alaska, some years ago, and watched my brother in law doing tube welds. And let me tell you, I was impressed! If your a successful boiler tube welder. You go to the head of the cl***. Lots of people can weld pertty good under excellent conditions. But welding under the boiler conditions and p***ing X-Ray, that’s skill!
    Bones
    alanp561 likes this.
  4. jazz1
    jazz1
    Yes they are talented however welding tube remote in nuclear facility also requires exceptional skill.. I can’t imagine having to weld perfect bead and no going back to grind and redo
    Myself I do everything twice if not more:D
    Boneyard51 likes this.
  5. toml24
    toml24
    Back in my freshman year of high school in 1970, one of my cl***es was metal shop, and try as I did, I never mastered the art of stick welding. I felt like a jerk because I could not successfully do it. Otherwise the cl*** was OK but I must have gotten a big fat "F" on stick welding.
  6. That stick welder is a great power supply for scratch start TIG.
    alanp561 and Rich S. like this.
  7. Boneyard51
    Boneyard51
    Tom, come to Oklahoma, bring a case of beer, I’ll have you stick welding before the beer is gone.
    Bones
    Lucky667, Hollywood-East and alanp561 like this.
  8. Bleach
    Bleach
    I use a stick welder because that is all I have. I also have an O/A set but I ran out O2 years ago.
  9. morac41
    morac41
    Wouldn't weld anything over 1/8 with a mig on home voltage...thats where the stick wins all the time...any frame welds should be stick or Tig.......
    Rich S., alanp561 and caseywheels like this.
  10. I use Mostly the Stick
    (a big old top-crank Miller-300amp...3-400#s...copper wound ..I'm pretty sure that thing could weld the GoldenGate bridge)....
    I barely even use the (old Century brand) wirefeed...just for thin sheetmetal & exhaust...
    morac41 likes this.
  11. alanp561
    alanp561
    Better yet, with all these guys who have stick welders in their garages that they're not using, one of them would probably be more than happy for you to buy his just to gain some space in the shop. Of course, the minute you offered to buy the machine, it would become extremely valuable. Hell, they might even give it to you.
    morac41 likes this.
  12. Heck i almost forgot...I got an old Lincoln tombstone last summer...with 2 cans of 1\8" 6013... For only $20.oo ! (F.y.i. yard sales Rule!)...I suppose I should plug it in someday an try it out ?
    GuyW and G-son like this.
  13. Rich S.
    Rich S.
    What ever you use, you need full penetration. I have buzzed off some very pretty welds with an air chisel . And I’d never get rid of the stick welder, it reliable and does too many things. Sometimes in narrow areas your only option is Stick.
    morac41 and caseywheels like this.
  14. Rich S.
    Rich S.
    morac41 and warbird1 like this.
  15. Marty Strode
    Marty Strode
    Yes I did.
    Rich S. likes this.
  16. Rich S.
    Rich S.
  17. warbird1
    warbird1
    My Lincoln tombstone sits by the garage door so I can run the leads outside if needed; it gets used several times a year. The years spent stick welding as a millwright make it my go to machine for anything over 1/8" thick. My MIG has developed problems so it's buried in the back of the garage. Still trying to talk myself into buying a TIG machine...
    RidgeRunner likes this.
  18. PHIL COOPY
    PHIL COOPY
    I've got a Miller Econotig....(tig /stick).....replaced a trailer hitch last week..used the stick. Haven't had a mig for years now.
    Phil
  19. Terrible80
    Terrible80
    True that, saw a guy weld a pipe against the wall , laying in freezing water with a mirror. Bent the electrodes and welded it up.
    Sent from my LG-TP450 using The H.A.M.B. mobile app
    Lucky667, Rich S. and alanp561 like this.
  20. I've welded brackets up where I couldn't even see what I was doing; did it by sound. No idea what the finished weld looked like, but they didn't fall off when I whacked 'em with a hammer... LOL.
    Lucky667, Terrible80 and morac41 like this.
  21. Terrible80
    Terrible80
    Did some motor mounts in an El Camino that way, guy didn't have a helmet.
