Technical Positive or negative ground?
Discussion in 'The Hokey Ass Message Board' started by nickleone, Oct 20, 2018.
  1. nickleone
    nickleone
    My buddy got an AA truck. 6 volt no battery in place. Previous owners, a charity,did not know if it is positive or negative ground. It was rumored to have been converted to negative ground. How to test without frying something?
    Nick
  2. tubman
    tubman
    Check the coil. It may be marked "+" and "-" on the primary terminals. If they are marked, the one going to the distributor is the ground polarity. This is ***uming the guy who put the car together knew what he was doing.
    If it is an "AA" truck, there is little to fry by trying it both ways.
    Hnstray likes this.
  3. Hollywood-East
    Hollywood-East
  4. greybeard360
    greybeard360
    Old shop forman used to ask that question... What happens if you hook up a positive ground system as negative ground. Will the horn still blow or will it ****?
    catdad49, egads, Bleach and 3 others like this.
  5. It just goes, "KNOH"
    GeezersP15, BJR, RMONTY and 3 others like this.
  6. Bleach
    Bleach
    If it sparks when you hook the battery up to pos gnd then switch it around.
  7. Fun fact. Positive ground vehicles have less body rust but more risk of electrical system corrosion! I prefer pos ground and a solid electrical system with lots of dielectric grease.
  8. noboD
    noboD
    If you hook the coil up backwards the spark jump from the ground electrode to the center electrode on the spark plugs.
  9. woodiewagon46
    woodiewagon46
    from New York
    Does the car have the original wiring and all the stock components in place?
  10. Hotrodmyk
    Hotrodmyk
    If it is stock, it is POSITIVE ground.
  11. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    Check your battery able ends + is larger & see where/what it is connected.
    Frame or solenoid.
    rwrj likes this.
