Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    The interesting about that Chevrolet engine is that many folks think Chevrolet introduced their first V8 in 1955.
    I remember seeing one of those in the Crawford Auto / Aviation museum in Cleveland.
  2. redo32
    redo32
    This was over on the old pictures thread. 4 exhaust pipes per side but I only see 2 spark plugs.
    loner2, Stebo27, loner1 and 9 others like this.
  3. Desmodromic
    Desmodromic
    That's a real puzzler! My best guess is that it's a flat (boxer) 8 cylinder, with common combustion chamber over each pair of cylinders. Shared combustion chamber was used on some twin cylinder motorcycle engines, although I think these were 2 strokers, and done as a clever way to optimize port/piston timing. Could be a flat four with 2 exhaust ports per cylinder (old Jawa singles had 2 exhaust ports, were called "Twingles"). I tried ****yzing the head stud pattern to resolve whether it covers 2 or 4 cylinders, but my brain started hurting!
    Ron Funkhouser and loudbang like this.
  4. Desmodromic
    Desmodromic
    What was the purpose of these covers? Some say it was just for looks, others claim it was to keep plugs dry externally, primarily for marine applications. ???
    1947knuck and loudbang like this.
  5. Jalopy Joker
    Jalopy Joker
  6. 1947knuck
    1947knuck
    Bohnalite high compression aluminum cylinder heads for flathead Ford. Speedway-SmithMuseumOfAmericanSpeed-BE.jpg
    TBirdGirl26, loner2, Stebo27 and 11 others like this.
  7. 1947knuck
    1947knuck
    Ford Model T conversion head. It utilized rows of ball bearings within the curved tubes to subs***ute for pushrods and rocker arms. Speedway-SmithMuseumOfAmericanSpeed-LC.jpg
    TBirdGirl26, loner2, Stebo27 and 14 others like this.
  8. 1947knuck
    1947knuck
    TBirdGirl26, loner2, Stebo27 and 8 others like this.
  9. drtrcrV-8
    drtrcrV-8
    "Turnip"(Triumph) heads & Barrels on a fabricated crankcase using a V8-60 Crankshaft It's a midget motor in the Speedway Museum.
  10. 1947knuck
    1947knuck
    I found a few pictures I've had for awhile but no idea what they are. 17iw1abu6dqxzjpg.jpg
    TBirdGirl26, loner2, Stebo27 and 9 others like this.
  11. 1947knuck
    1947knuck
  12. 1947knuck
    1947knuck
  13. FrozenMerc
    FrozenMerc
    KNUCK, Your first picture (Yellow motor) is a Detroit Diesel 24V-71T. 24 cylinders of 2 stroke Diesel goodness. It is not HAMB friendly, but check out Mario Racicot's V24 Detroit powered Freightliner Argosy COE if you want to see what one of those motors is capable of.
    Your 2nd picture is a early 30's Marmon V16. Marmon was an early luxury car maker, but had to merge with Herrington to survive the depression. After the merger, they got out of cars and focused on the heavy truck and bus game initially with vocational conversions and then complete truck production. They lasted into the 70's.
    Marmon- Herrington 4x4 conversion
    Marmon COE
    The 3rd picture I have no idea.
  14. FrozenMerc
    FrozenMerc
    The V8-60 was kind of a weird motor to begin with, but with a set of Smith Jiggler F-heads on them, they are even odder.
    loner2, Stebo27, loner1 and 7 others like this.
  15. XXL__
    XXL__
    Marmon-Herrington is actually still around. They do a lot in the heavy equipment and military space, and they still do a lot of 4x4 conversion stuff.
  16. FrozenMerc
    FrozenMerc
    Good to know. I had it in my mind that they folded up when they got out of making complete trucks in the late 70's. I see that they are now part of Mr. Buffett's holdings.
  17. Fordors
    Fordors
    It is Italian, an Isotta Franschini and if I had to guess I’d say mid to late ‘20’s.
    I had no idea but the I S logo on the side cover tipped me off.
    loudbang and 1947knuck like this.
  18. 1947knuck
    1947knuck
    Graham Supercharged Falthead 6 cylinder. cd5734836e60f701e18e0a54809cc4a9.jpg
  19. 1947knuck
    1947knuck
    Rotary Valve Head. The head has one round bar-like "valve" timed to the crankshaft via a chain. The head is a cross flow type and each of the four valve cuts acks as both intake and exhaust. 50-0057_1_orig.jpg rotary-valve-cutaway-left_orig.jpg 50-0057-1_orig.jpg
  20. 1947knuck
    1947knuck
    Popp 90ci 4 cylinder SOHC with winfield carbs built in Texas for Midget racing back in the early days. 92-0027-5_orig.jpg 92-0027_1_orig.jpg 92-0027-7_orig.jpg 92-0027-8_orig.jpg
    TBirdGirl26, loner2, Stebo27 and 10 others like this.
  21. 30tudor
    30tudor
    mg v83.jpg mg v8 6.jpg mg v82.jpg mg v8 4.jpg mg v8 5.jpg mg v81.jpg Built and raced during the 1955-'57 european motorcycle compe***ion. 8 cylinders, 8 carburetors, 8 sets of points. Total displacement of 500cc or 30 cubic inches V8 Moto-Guzzi.
    fredeuce, loner2, Stebo27 and 8 others like this.
  22. drtrcrV-8
    drtrcrV-8
    30tudor: Is that an MV Agusta?
  23. loudbang
    American LaFrance
    loner2, Stebo27, loner1 and 4 others like this.
  24. 1947knuck
    1947knuck
    All the information I have on this engine is that it is a Delage Type-S 8331980-3x2-940x627.jpg
    TBirdGirl26, loner2, Stebo27 and 5 others like this.
  25. 1947knuck
    1947knuck
    TBirdGirl26, loner2, Stebo27 and 4 others like this.
  26. 1947knuck
    1947knuck
    1913 Peugeot 4.5 Liter ran at Indianapolis 500 in 1916. 1510578389_170_the-100-year-old-racing-.jpg
  27. rdynes01
    rdynes01
    from colorado
    Huh??? Wha????
  28. Ned Ludd
    Ned Ludd
    If I remember correctly – imagine something like an open diff, with an engine crankshaft driving one axle shaft, a turbocharger turbine driving the other axle shaft, and the driveshaft yoke driving a centrifugal blower. The more restriction there is in the exhaust, the more drive the blower gets from the crank. The more load there is on the engine, the more drive the blower gets from the turbine.
    Now imagine that the gear ratio between the two axle shafts isn't 1:1 – either because the differential gears aren't the same size or because there is a reduction gear on the turbine side, as there is likely to be because the turbine spins an order of magnitude or so faster than the crankshaft. The thing is obviously to figure out what the gear ratio ought to be for best performance. In all probability this can be computer-simulated today. It couldn't be worked out on slide rules etc. in 1953 or whenever it was.
  29. loudbang
    Boeing Gas Turbine
    loner2, Stebo27, loner1 and 2 others like this.
  30. 28dreyer
    28dreyer
    from Minnesota
    Well this obviously was a '30's midget and should be posted on the Cageless Midget thread to see if any one recognizes it.
    Riley did build a horizontal, I believe 4 cylinder, that I have never seen a picture of, but know that Speedway Motors acquired a number of the blocks when they bought the remaining Jim Ash collection in the early to mid, 1990's, which I did see.
