Hot Rods Build #2 I 30 Model A"Coupe" AKA Phoenix
Discussion in 'The Hokey Ass Message Board' started by jackalope, Oct 3, 2016.
  1. jackalope
    jackalope
    Going with the 59 caddy. I figured a little less is actually more. The caddy ones take up the small space between wheel and body and mimic exhaust.
    In the pic they are not level as they are sagging. I am painting and then going to level ‘em out.
    chop job, Stogy and loudbang like this.
  2. mkebaird
    mkebaird
    Good call, wicked coupe!
    jackalope likes this.
  3. chop job
    chop job
    from Wisconsin
    How is the trans tunnel attached to firewall ? Looks like tacks only.
  4. jackalope
    jackalope
    There is a double layer of sheetmetal that sandwiches the 1” square tube. The inside layer (layer exposed to element on underside of tube) is fully welded. Top layer (inside cab on top of tube) is tacked. The pic you show received more tacks but fully welded is unnecessary as it will be covered with Dynamat. Hope that explanation made sense.
  5. jackalope
    jackalope
    Dino 64 likes this.
  6. chop job
    chop job
    from Wisconsin
    Nice job thanks for explaining looks real good.
  7. jackalope
    jackalope
    I actually don't like the way I did it but I really didn't have a choice. I needed the tubing structure for subframe support because the span where the trans is was just too much to leave unsupported. The tubing reduces any flex in the body up front. Unfortunately, to clean it up on the outside and inside they both needed to be skinned.
    Stogy and chop job like this.
  8. jackalope
    jackalope
    Here are the tail lights mocked up. [​IMG][​IMG]
    I think one per side looks better than the two I was planning.
  9. ty johnson
    ty johnson
  10. jackalope
    jackalope
    Unable to attach a video but got this girl fired up on first turn of the key!!! After a quick adjust to the carb the engine runs like a top!!!
    loudbang, Dino 64 and Aaron D. like this.
  11. Dino 64
    Dino 64
    from Virginia
    That’s great!! Bet it’s LOUD
  12. jackalope
    jackalope
    Yes it is loud. No doubt, but it sounds really friggin good. I thought it would sound more stock car like. I’m pleasantly surprised.
    Dino 64 likes this.
  13. jackalope
    jackalope
    Did some tidying up the other day and after a couple days came back to the shop, fired it up and there was more exhaust popping.
    Finally had a chance to get into the shop after being out of town and found the culprit was my ground strap wasn’t completely cinched back down tight. Basically barely any contact. Did that and then made new fuel lines and she fired up and sounded great. I adjusted TV cable and if it weren’t ****ty outside I would’ve driven her.
    [​IMG][​IMG][​IMG]
  14. jackalope
    jackalope
    And, yes, I knew the exhaust would be roaching the skin when I was building the headers [emoji6]
    ty johnson, Dino 64 and loudbang like this.
  15. jackalope
    jackalope
    Also had a chance to make some pull knobs so that everything matched. [​IMG][​IMG]
    loudbang, chriseakin and Dino 64 like this.
  16. jackalope
    jackalope
    Drove it around the shop and made a few adjustments. Probably the next time I post anything on this build will be a pic of the top when I get around to it. Poser shot until then. [​IMG]
  17. Dino 64
    Dino 64
    from Virginia
    You nailed it !!
  18. autoworx1
    autoworx1
    from kansas
    I just went through your entire build. Incredible job man! Nice use of the LS motor. Much respect!
  19. jackalope
    jackalope
  20. jackalope
    jackalope
    Already have a Coupester that was hacked into roadster waiting in the wings. That’ll be my next project. [​IMG]
    Dino 64, ty johnson and Just Gary like this.
  21. ty johnson
    ty johnson
    I see its grown since Sunday. Lol has doors now
    Sent from my SM-G950U using The H.A.M.B. mobile app
  22. jackalope
    jackalope
    Yep! When I bought everything I didn’t know the doors and back half were all from the same car. That’s a bonus. I’ll probably drag all these parts into the shop before long to build a sub floor to get it all tied together. Can’t just let it sit out in that dark building ....[emoji12]
  23. jackalope
    jackalope
    A couple pics of the coupe that finally made it home on the ONE decent day we had. [​IMG]
    Also got a start on the next project. Build #3 I need to find a name for it. It’ll be a separate build soon to come.
    And the buried coupe that I drove all the way to Colorado for has perfect patch panels.
    [​IMG][​IMG]
  24. jackalope
    jackalope
  25. Andy Velders
    Andy Velders
    Grant, that was such a cool build! Very inspirational, totally cool! I'm chomping to get on with mine now!
