Hot Rods School me on Buick Nailheads please.
Discussion in 'The Hokey Ass Message Board' started by lothiandon1940, Oct 24, 2018.
  1. I think you will like the nailhead for your hot rod. These engines are workhorses and are bullet proof. Seems like the guys in Virginia figured this out already.......HA! DSCN0590.JPG DSCN0591.JPG
  2. lothiandon1940
    lothiandon1940
    ....Thanks, Jason.
  3. lothiandon1940
    lothiandon1940
    Love the truck, hotrodart. Feel free to post up more pictures.:)
    lothianwilly71 likes this.
  4. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    You are right, I was thinking they went to the B-O-P with the 400 trans but it was not until the nailhead went away in 67 that update came about. You mentioned the 300 Buick, that was also a great engine, I ran one in my first 65 Skylark over 150K with no problems ever. We are building a 300 for my son's factory 4 speed 65 Sport Wagon with a mild cam and worked over heads.
    302GMC likes this.
  5. LM14
    LM14
    from Iowa
    What are options for a manual******* behind a nailhead? I have a project that may get a nailhead with a 3 speed behind it.
    SPark
    lothiandon1940 likes this.
  6. So would a th400 our if a jaguar bolt up to a nailhead?
    Or am I reading this wrong ?
    The series 3 jag used a th400 just a different case
    That would open up a lot of options for us
  7. Hamtown Al
    Hamtown Al
    An update: I am now the proud owner of 2 65 Rivieras! One is real Gran Sport; the other was on the way to being a clone car and has all the GS trim and the 2 4s but on a 401 and not 425.:( But it runs!:)
    Started right up after sitting for two months. Little gas in the tank and some juice in the carb and it was running.
    Now, to get them here and really see what I've got.
    Maybe I should get Don to come down and help unload.:D:D
    Maybe Jason, too.:D
  8. 264 C.I.D 1954-1955
    322 C.I.D 1953-1957
    364 C.I.D.1957-1961 .25 taller deck height longer connecting rods Valves increased to 1.875" Intake 1.5" exhaust
    401 C.I.D. started 1959
    425 C.I.D. 1963-1966
    Information from the book-
    Ultimate American V-8 Engine Data Book 1949-1974
  9. Gman0046
    Gman0046
    LM14, sure you can use a standard transmission. What engine and transmission do you have in mind? Bear in mind torque tube issues.
    Gary
  10. Raunchy
    Raunchy
    364 uses a different intake they are harder to find speed parts for but I always thought they ran cooler. I have a 364. They are long and heavy but lots of torque and coolness. This is worth taking a look at for more opinions http://centervilleautorepair.com/
    Gman0046 and lothiandon1940 like this.
  11. lothiandon1940
    lothiandon1940
    .........................I have been thinking about taking a ride down your way.
    lothianwilly71 and Hamtown Al like this.
  12. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    Sorry, I don't know anything about Jags
  13. Hnstray
    Hnstray
    from Quincy, IL
    I only know for sure Jaguar had a TH400 which was not a BOP bolt pattern and the case pattern ‘resembled’ the nailhead style case. It may, or may not, be the same. I dimly recall reading a discussion of that question somewhere within the past couple of years, but cannot remember the place where I saw it or the conclusion of the discussion. Sorry...I wish I could answer your question one way or the other.
    VANDENPLAS and lothiandon1940 like this.
  14. I like what you are thinking Don.
    I don't know much about them except that they look sweet and I want one. My ultimate dream of my 37 would be a 4x2 or 6x2 401 or 425. I didn't hit the lottery so its still a dream at this point.
  15. Don if you don't mind, here are a few pictures I have saved on my phone... 5603a00ed26831e3cd6e65c8755f7982.jpg FB_IMG_1478605033676.jpg DSC374584.png FB_IMG_1490399060673.jpg
  16. lothiandon1940
    lothiandon1940
    ^^^^I don't mind at all, Matt, in fact I appreciate them. Thanks for posting them. They do indeed make for a beautiful engine.^^^^.........................Don.
    lothianwilly71 and Hnstray like this.
  17. From what I could find a 57-64 Buick nailhead
    Will bolt up to a 77-90 xjs or xj12 th400
    Different things for 53-56 from the bottom bolts and dowels being the same and redrilling the upper bolts to the 53-56 bellhousing being about 1” wider in circumference.
    Only reason I mentioned this after hnstray posted is because these jags are a dime a dozen once they need work and can be had cheap
    And the internals are the same as any Chevy th400 so nothing out of the ordinary to rebuild
  18. The torque convertor and starter ring gear is likely going to be the problem , even if the transmission will bolt up.
    Nailheads are hard enougb to mix and match parts amongst themselves.
  19. Gman0046
    Gman0046
    The look of the Nailhead signature straight up valve covers is hard to beat.
    Gary
  20. Hnstray
    Hnstray
    from Quincy, IL
    If this is accurate for thru '64 nailheads, it seems to me it should also be applicable to the '65/'66 models which, so far as I know, are the same block pattern as the years you mention.
  21. Nailhead Jason
    Nailhead Jason
    Say when and I'm there! id love to have another Rivi! maybe I can talk you out of one......
    Hamtown Al and lothiandon1940 like this.
  22. If the bellhousing bolts up, should not be a huge deal to fabricate and adapter and spacer so the torque converter lines up.
    The bendstens adapter I have had a simple aluminum spacer for the back of the torque converter and a triangle plate to mount a th350 trans torqu converter to my 322 nailhead ( its a used one so things may have changed or been modified
    Just looking at different and more cost effective options here is all.
    I’m not saying what I found is 100% fact but it’s been stated on more then one website so take it with a grain of salt I guess
    lothiandon1940 and wood remover like this.
  23. I get it , just wish it was easier, and cheaper LOL .
  24. patterg2003
    patterg2003
  25. building the motors isn't to much of a problem ,it is transmission and flywheel choices that***** , you can buy most
    adapters and flywheels to make them all work from bendtsen , but prepare for your wallet to be a 1000.00 lighter !!!!
  26. finding manual bell housings and flywheels for the 64-66 401 and 425 is really tough as most of the cars they were used in were luxury cars
    I have an Offenhauser adapter to go from 401-425 to narrow case ford . I have been also lucky enough to find 2 flywheels with clutch's
  27. Dan Hay
    Dan Hay
    The 322 in my 56 Super moves pretty good despite the car being 2 tons + and having the worst automatic transmission in the world behind it. They must be a rocket in a light car with a manual trans.
    Also, go to nailheadbuick.com and read. There is a lot of great nailhead info on that page.
  28. I will let you know in another year LOL
  29. Have a 33 chev 3 window ,
    The plan …
    401 buick , manual
    have a ford 3 speed w od late 70 s
    ford 3 speed with electric od 50s
    toploader 4 speed 64
    toploader 4 spd 67 dual pattern
    leaning toward 3 speed with electric overdrive 50s ford
  30. K13
    K13
    I****ume the transmissions that came in the cars originally equipped with Nailheads were not great.
    Dan Hay and lothiandon1940 like this.
