Event Coverage The LaSalle Adventure
Discussion in 'The Hokey Ass Message Board' started by squirrel, Oct 23, 2018.
  1. 37 caddy
    37 caddy
    from PEI Canada
    The water pumps are being reproduced now,not sure if you want to put one on,Speedway has them listed for about 225.00,maybe try loosening the rad cap to lessen the pressure on the system,i do that with mine as i have a small leak in my rad,but i dont drive 3-400 miles a day;).Myself i would try a bottle of bars leak,if you can find it. Good Luck Harvey
  2. Very cool Jim. Best of luck to you & David.
    This reminds me of one of several cross country (CA to MD) drives I did 30+ years with variety of vintage cars.
    One was with a '60 Buick that had myriad of cooling problems, including some corrosion created pinholes on the timing cover/water pump housing, clogged radiator, etc, not to mention I was pulling an old VW on a tow-bar (L.A. to Roanoke) and had a tight schedule. Having to stop every 20-30 miles to cool the engine off a bit and refill with water, which by the second day I carried several gallons of, sure made that +/- 2500 mile distance seem very long and tiring.
  3. squirrel
    Thanks for the suggestions. It's still soggy out. We have five gallons of water with us, and it's usually no problem getting more, when the gas station clerks see the car.
    The motel room in Vandalia.
    We have been trying to stay in dives, as it seems more fitting to have a real metal room key.
    Sent from my Trimline
    Willy_P, kiwijeff, Bleach and 26 others like this.
  4. squirrel
    This morning we can see that a heater hose was leaking. Moved the clamp and tightened all the rest of them. I bought a mirror on a stick, so we can inspect stuff more easily.
    Willy_P, kiwijeff, Okie Pete and 12 others like this.
  5. classiccarjack
    classiccarjack
    Was that the cause of the woes?
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
    Stogy and chryslerfan55 like this.
  6. patterg2003
    patterg2003
    I am enjoying your ride and your ingenuity. I think you secretly enjoy overcoming the challenges to keep the interesting old rides on the road along the travels as much as the journey. It is good to get out with the brother as well. My brother moved to the west coast and does not travel so it is up to me to do the drive.
    I know this is nothing new to you and you can bark at me. :) A pc of card board in front of the rad with a pie sized hole where the fan sits will bring the temperature up. Adjust the size of the hole to get the temp where it should be. I had a 76 Ford truck that I could not get warm so I had the same card board that I slid in every winter with a 10 inch hole. It gets to 40 below here so the card board went in when it snowed and it comes out easy when it is warm.
    Thanks for sharing. Happy travels!
    chryslerfan55 and kidcampbell71 like this.
  7. J. A. Miller
    J. A. Miller
    from Central NY
    I guy called and tried to sell me a coffin; I told him that's the last thing I need.
  8. Los_Control
    Los_Control
    from TX
    Seems squirrel is tough and does not need a warmer heater :p
    I wonder if raising the cars temp with cardboard would allow the engine to run smooth enough to blowup? Or maybe slow down the intake leak
    Same time, I know Jim is ten staeps ahead of me and simply say, have fun and am enjoying the ride along.
    chryslerfan55 and belair like this.
  9. Ebbsspeed
    Ebbsspeed
    Jim, I looked through my stash of FlatCad gaskets, the only manifold/exhaust gaskets I have are on my engine. You mentioned that it's one of the exhaust crossover gaskets, so a pretty basic shape. Could you fold over a sheet of aluminum foil a dozen times to build some thickness, then chisel the bolt and exhaust holes through it? It should be a bit compressible and might work out for you.
    However, given your huge brain, you've probably already thought of the pros and cons of all the possible roadside options.
    Best of luck on this adventure!
    Willy_P and chryslerfan55 like this.
  10. MMM1693
    MMM1693
    I'm sure a man of your talents and engineneweteee will prevail!
    Stogy likes this.
  11. Latigo
    Latigo
  12. bobss396
    bobss396
    Solder Seal Block Saver is another good one. A few packets of that sliver stuff may hold it.
  13. BJR
    BJR
  14. R A Wrench
    R A Wrench
    from Denver, Co
    What PATTERG2003 said. I was raised in North Dakota, a sheet of cardboard is a good friend. Adjust the temp by cutting larger holes is it. And, I am enjoying this trip as much as the build & the drive with the Barracuda.
    doug j and chryslerfan55 like this.
  15. pumpman
    pumpman
    getting 9 to 10 mpg.
    Hope you have a big gas tank in that beast.
  16. tb33anda3rd
    tb33anda3rd
    i have seen gaskets "fixed" with strands of copper wire. i took a motor apart one time and found the wire embedded in the gasket, in the pitted areas of the mounting surface.
    kiwijeff, brEad, czuch and 1 other person like this.
  17. I like the way you approach vintage travel. ;)
    While I've been known seek out "old school" over night accommodation during "vintage-style" road-trips, I prefer "old world" luxury over "dives" but sometimes one has no choice. :rolleyes:
  18. belair
    belair
    "vintage travel"- I like that.
  19. classiccarjack
    classiccarjack
    Not only are the vintage Motel/Hotels better, the price is right too... My wife and I do this sort of thing when we travel.
  20. 36cab
    36cab
    Why does this LaSalle have a 1936 Ford grille on it? :D
    wheeldog57, brEad, scott27 and 20 others like this.
  21. BamaMav
    BamaMav
    from Berry, AL
    czuch, chryslerfan55 and VANDENPLAS like this.
  22. squirrel
    Made it to the hotel in Joliet. Yay.
    And a couple pics of the heat cross over gaskets. IMG_20181026_163124.jpeg IMG_20181026_165350.jpeg IMG_20181026_165355.jpeg
    kiwijeff, Bleach, Okie Pete and 10 others like this.
  23. Ebbsspeed
    Ebbsspeed
    @squirrel Ah, THAT exhaust crossover. I thought you meant the one in the photo below. Yeah, that one on the bottom of the intake is a little more difficult to make a gasket for. Maybe some of that high-heat exhaust silicone stuff?
  24. flatford39
    flatford39
    I am sure Loc***e has a temporary cure for that if you have enough time for it to set and dry.
  25. squirrel
    the car runs and drives ok, so we can live with it.
    Okie Pete, Stogy and low budget like this.
  26. flatford39
    flatford39
    Sounds like you are going to make it. Have fun man...have fun.
  27. blowby
    blowby
    from Nicasio Ca
    Bet that thing feels pretty comfy after the last trip. You should have some magnetic door signs made up, might pick up a side job along the way.
  28. squirrel
    Moondog13, kiwijeff, Bleach and 19 others like this.
  29. fiftyv8
    fiftyv8
    from CO & WA
    kiwijeff and chryslerfan55 like this.
  30. noboD
    noboD
    Olsen Gaskets should have any of the gaskets you need. Love your travel tales Squirrel. Always an adventure.
