Technical 1950 Chevy Starter help
Discussion in 'The Hokey Ass Message Board' started by Devin1950, Oct 27, 2018.
  1. Devin1950
    Devin1950
    from Howell, MI
    I need to pull the starter out of my 1950 216 Chevy deluxe. I've located the two bolts and I'm having trouble getting a wrench into the top bolt location. Very small opening to the bolt. Anyone have any tips? Thanks
  2. gimpyshotrods
    gimpyshotrods
    Socket, two extensions, ratchet.
    6inarow and Devin1950 like this.
  3. Devin1950
    Devin1950
    from Howell, MI
    Ok thanks I'll try that.
  4. Wesa
    Wesa
    from Finland
    It was pain on the ***, but you can do it.
    Devin1950 likes this.
  5. Devin1950
    Devin1950
    from Howell, MI
    I got the starter out and replaced the starter drive, got it back in. A socket won't fit in there, there's an offset, the nut is kinda behind the starter body. Anyhow, I grinded down the sides of an 11/16 wrench so it would fit and turn and 30 min later, success! She starts great now. Thanks for the nudge.
  6. Mr48chev
    Back when changing those in a shop was a daily occurrence "starter wrenches" were pretty common. I'd go with what Devin1950 Suggested and modify a wrench to do the job and then stash it in the box so you have it if you need it again.
