Hot Rods Did I just lose the clutch plate on my 1959 Rambler?
Discussion in 'The Hokey Ass Message Board' started by slim tempo, Oct 24, 2018.
  1. slim tempo
    slim tempo
    Just as I was leaving the Stafford Springs Speedway parts swap meet this past Sunday, my transmission started making noises. Actually, the column shifter was hesitant to go into first or reverse. When it did go into first, I creeped forward a little at a time and there was a s****ing sound, then a rattling sound, then a chirping sound. I drove the 18 miles cautiously by using second and third gears. Today I checked the linkage, checked the fluid and drove it slowly down the street. It would emit a chirping sound like there was something rattling around. When the clutch was pushed in, the sound stopped. Second and third gear were fine. Is it a blown clutch friction plate? 023.JPG
  2. BJR
    BJR
    Sounds more like the transmission to me.
  3. RichFox
    RichFox
    How is it in reverse? Sounds like a bearing in the first gear has given it up
  4. 50John
    50John
    Hard for me to tell from your description. Clutch failure usually means slipping. If you give it gas the engine will rev without the corresponding acceleration.
  5. slim tempo
    slim tempo
    The sound seem to be coming from the bellhousing area and not the ******. Like something is rattling around. Plenty of friction, no slippage, goes into reverse and backs up fine.
  6. F&J
    F&J
    I can come look at it. (You know me, I sold you a white 74 bug..)..I think you moved after that, so where in Coventry now? PM me or call nights.. Frank
    tb33anda3rd likes this.
  7. Atwater Mike
    Atwater Mike
    Look at T.O. brg., sounds like it began to 'freeze up', (dry inside?) and tore off one or both spring fingers securing brg. to the fork.
    Probably right on the other side of fear. (Love that, Frank!)
    flatford39 likes this.
  8. I'm agreeing with A****er Mike, sounds like it's throwout bearing related.
  9. slim tempo
    slim tempo
    Frank, I'll call you Thursday evening. Thanks for your help. I loved that VW. With a dual carb setup and lowering spindles it was a fun ride. It went to a friend of mine, so it's still in good hands.
  10. slim tempo
    slim tempo
    In order to get it home, I drove it all the way up Lewis Hill Road in Coventry, CT in third gear with no lugging of the engine or slippage of the clutch. That hill is 7% grade for about 1/2 mile. The problem only occurs when in first gear.
  11. slim tempo
    slim tempo
    Rebuilt engine. Pulls really nice.
  12. slim tempo
    slim tempo
    Ran the car back and forth in the driveway, 1st and reverse. Lots of clutch shuddering, some clunking noises. I will check the motor mounts as soon as I can find someone to sit in the driver's seat and cycle through the gears with the brake on.
  13. F&J
    F&J
    I will call tomorrow, and then come over. Raining too much right now.
  14. 57 Fargo
    57 Fargo
    Along with the engine mounts also check the transmission mount, it is possible to have clutch chatter without it slipping, if it’s been overheated or if one of the torsional springs is broken. The torsional springs are the ones in the center of the disk, they can rattle as well if they are broken
  15. s55mercury66
    s55mercury66
    from SW Wyoming
    That's pretty cool of you, Frank. I just realized where you guys are, my youngest number one son lives in Willie. I'd tell him to give you a hand, but his automotive expertise only goes as far as gl*** installation.
    F&J likes this.
  16. slim tempo
    slim tempo
    Checked the sound this morning. Engine running, trans in neutral, clutch engaged, some whirring noise from ******, not too loud, but audible. Sounds like input shaft bearing.
  17. ken bogren
    ken bogren
    I know nothing about your clutch troubles, but I sure like your car!
  18. Wrench666
    Wrench666
    Not sure if you have hydraulic clutch. I had same type of symptoms from bad slave cylinder on an OT ****box. Thought it was the clutch, changed it and same problem. Then found it was the slave.
    Just a thought
  19. I say look at the disc or cover springs carefully. Your going to have to take it apart anyhow, look at everything and replace the t/o bearing just to be safe. I did have an issue with my flathead recently trying to mix a different cover and disc......so stay with the same manufacturer on both.
  20. F&J
    F&J
    Ok, I did get to Steve's place late this afternoon. We need more help with anyone who knows these T96 closed drive, NON-O/D 3 speeds. (BTW this is a closed drive...if it was conventional open drive shaft, I would just pull the trans at this point)
    -Clutch pedal feels 100% factory mint. No noises as he worked the pedal while the engine is running.
    -Car not moving, engine idling quietly, trans in Neutral, clutch pedal released...you can tell for sure that the input bearing race is pitted. It is steady fainter noise like from pitted race, but not a growl like when the ball bearings are flaking apart. That noise stops with the clutch depressed.
    -Steve drove it only around the block. As soon as we took off, (First gear only)there was a very random tinny noise like something loose and moving around/hitting something? then stops instantly. He did get into 2nd, no noise. It did the same thing at the next stop sign, first gear. He did not want to drive it any further.
    -the trans oil was only down "a couple ounces" when he checked earlier this week. At the swapmeet, he had parked on a steep embankment, and when he went to leave, the trans would not go into 1st/rev at first.?? Now it shifts fine?
    Looking at a transmission exploded view I found on a Stude parts website:
    ^^^ Take a look at the input main bearing (6.040-1), it is a ball type bearing...then look at the oil deflector behind it(6.040-2). Perhaps the "cage" that holds the input balls aligned, is coming apart, and hitting that tin deflector?
    Ok, we both thought the noise perhaps might be something hitting in the engine compartment, so I did get a good yank in both directions on the motor, and the motor is not moving around like bad mounts. It was very cold/damp, and this was my second stop in town helping with a car ...so I left to go look at a book before jumping the gun.
    So if any of you know these T96 transmissions, add a comment. It has to come out at some point this winter, as the input bearing won't last forever as is, even if the weird random noise is not related. The car is not used in winter during body work, etc.
    It is a very cool car...pics for you Hambers below : BTW..Not much rust for a M***achusettes car! Love that rear tailgate window crank LOL
    DSCN1962.JPG DSCN1964.JPG DSCN1965.JPG DSCN1966.JPG DSCN1967.JPG DSCN1968.JPG
    Oh, Steve wanted to video my car as I started it up.....big mistake... I had just said ''I don't go nuts anymore"...but...an easy 1/3 throttle burn out for his neighbors.. I just can't help it..:oops: ........Coventry is one town you don't do that chit...and sure enough, as I was heading to Willi minutes later, they had a cruiser doing radar on RT 31 south.. but I already knew they sit there...:cool:
    tb33anda3rd and s55mercury66 like this.
  21. slim tempo
    slim tempo
    003.JPG 007.JPG 009.JPG 024.JPG 122.JPG 004.JPG 018.JPG View attachment 4078120 060.JPG 027.JPG 019.JPG nash salt.jpg View attachment 4078127 Thanks for stopping over and lending your knowledge Frank. I'll let you know what it looks like when I pull it. Here's some more photos plus a photoshopped version from HAMB'er with a lowered stance.
    tb33anda3rd, Bleach and F&J like this.
  22. 34fordjay
    34fordjay
    from Mass USA
    Frank
    That was very nice of you to go over and help a fellow HAMB'er.
    TrailerTrashToo and F&J like this.
  23. slim tempo
    slim tempo
    I really hate not driving this car. Last weekend I took it camping at the Somerset, VT abandoned airfield up on National 002.JPG 008.JPG 010.JPG Forest Rd. 71. Slept in the back just like it was designed.
    s55mercury66 likes this.
  24. slim tempo
    slim tempo
  25. bobss396
    bobss396
    How about a loose starter drive as the noise source?
  26. slim tempo
    slim tempo
    I will check out the starter today. Also draining the ****** lube and fishing a magnet inside the ****** housing today. Later on, I will cut an access panel in the ****** hump to pop off the top of the T-96.
  27. Bearings in the cluster gear! In the drawing part # 6.167-1
    slim tempo likes this.
  28. slim tempo
    slim tempo
    I drained the transmission oil today and fished a magnet around the ****** case. This is what came out. I believe Frank is right about a disintegrated input carrier bearing and oil deflector. 005.JPG 003.JPG
    F&J likes this.
  29. oldolds
    oldolds
    Time for a rebuild. Hopefully you don't need more than bearings and a couple thrust washers.
  30. F&J
    F&J
    I think it won't be too much damage because the trans sounded normal until that random "tinny" clashing happened at certain times in first gear.
    Hopefully just the main input bearing oil deflector was that noise? I'm glad he used a ruler there.. it looks too big to be from a cluster shim? What do you think?
