Folks Of Interest The Glory that is the Hemi, picture thread
Discussion in 'The Hokey Ass Message Board' started by Flogknaw, Sep 11, 2018.
  1. classiccarjack
    classiccarjack
    Kinda like the experimental all Aluminum slant six? They made a few, ran them, then s****ped them?
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
  2. Hemi Joel
    Hemi Joel
    from Minnesota
    I saw this at the long beach swap meet, January 2013.
    loudbang and 1947knuck like this.
  3. Deuces
    Deuces
    Looks like it needs plenty of machining.... Hope he's got the blueprints....
  4. slayer
    slayer
    Not exactly experimental at 50,000 units produced in 1961 and 1962. More like a not so good design in terms of longevity as few exist today. Here is one Hot Rod built in 2003. Sorry for the O/T content. 155_0303_six_1_z.jpg
  5. gimpyshotrods
    gimpyshotrods
    No.
  6. classiccarjack
    classiccarjack
    You are correct sir!!!
    I should have been more specific...
    Sorry..
    I have seen those engines at the Spring Fling and other swap meets. Those blocks, although not the best, can be found. They had cast iron cylinders cast into them(or maybe pressed in). But like you said, they made quite a few. Those came with a cast iron head.
    They made a few that were solid aluminum with Nikasil-coated cylinders that were not usable after the Engine ran it's course. They came with Aluminum Heads...
    I have searched for one, mostly because I wanted the head... LOL.
    But my slant six obsession is finally over... Now I am obsessing over Flathead Chryslers and Hemi's.
    slayer and loudbang like this.
  7. Jalopy Joker
    Jalopy Joker
  8. Flogknaw
    Flogknaw
    from Texas
    AAAAHHH!!! just kidding, nothing wrong here just make sure a car from 2003 doesn’t show up
  9. Deuces
    Deuces
    Too bad..... :(
    loudbang and 187sickboy like this.
  10. 1947knuck
    1947knuck
  11. 1947knuck
    1947knuck
  12. loudbang
  13. Bandit Billy
    Bandit Billy
    Chrysler HEMI, GM alternator, 2000 WTF and an electric fan to top things off. Like a Warhol Painting.
  14. foolthrottle
    foolthrottle
  15. loudbang
  16. 1947knuck
    1947knuck
  17. gimpyshotrods
    gimpyshotrods
    Deuces, Hemi511 and loudbang like this.
  18. 1947knuck
    1947knuck
  19. Deuces
    Deuces
    I like that Cammer in the background..... :)
  20. Deuces
    Deuces
    No problem knuck!!! :cool:
    1947knuck and loudbang like this.
  21. 402BOSSMAN
    402BOSSMAN
    Lil'Alb, loner2, Stebo27 and 10 others like this.
  22. HemiDave
    HemiDave
    from Austin, TX
    Was this one meant for the induction thread or is there a Hemi in there somewhere?
    Dave
    Deuces and 1947knuck like this.
  23. willys36
    willys36
    Gotta question for the hemi experts out there. Why aren't truck heads the rage for dragster engines?
    • they are big port, big valve heads.
    • they don't have those bothersome water X-over ports
    • they don't have those bothersome heat X-over ports in the two inner exhaust ports
    • they have hardened exhaust valve seats
    • Seem almost ready to bolt on and go fast.
    They of course have a couple minor problems that are easy fixed. They use hot water and tall narrow X-over ports on the intake manifold flange for preheating intake manifolds so those have to be brazed closed. No biggie. Second, they have odd sized valve guides for sodium filled exhaust valves but a valve guide change is good practice for any 60 year old engine rebuild.
    With the increasing rarity of 392 & 354 p***enger car heads, seems dirt cheap truck heads would be a great option. What am I missing?
    IMG_0802.JPG IMG_0803.JPG IMG_0804.JPG IMG_0805.JPG IMG_0806.JPG IMG_0807.JPG
  24. 1947knuck
    1947knuck
  25. Hemihead_NHRA
    Hemihead_NHRA
    Lil'Alb, loner2, loner1 and 5 others like this.
  26. Hombre
    Hombre
    Willys36, Here you go and talk about the Truck Heads and there no water ports and up jumps a car with just those. Are you getting physic ? zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzZZZZZZZeevvcg.jpg zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzeevvc.jpg
    loner2, cruiserjohn76, loner1 and 7 others like this.
  27. willys36
    willys36
    Well, I am wicked smart but probably not psychic. I am not so sure those aren't x-over heads. I don't see the water ports between the front two intake runners and it isn't clear what that thermostat block is sitting on. Looks like a dark X-over pipe? 331s had the no-X-over heads but generally have tiny round exhaust ports and 2bbl manifolds. Some later model 331 heads have the big ports and no X-overs and 4bbl manifolds but they are almost as rare as the Hope Diamond and cost more than the Hope Diamond. Here is the 4bbl intake manifold from one of those engines with the tell-tale thermo housing. Would LOVE to snag one of these! Trucks all had 2bbl manifolds so they are not good donors for those but the heads look like awesome nostalgia Fueler items.
  28. Hombre
    Hombre
    Yea I can see what you are talking about. That manifold is the Hot Heads tunnel ram with the 3x2 plate. That manifold does not come with the thermostat housing installed on it. it also bothered me some were it "APPEARS" the water is getting to the head, with out going to the center water port on the head. Maybe 2345. coupe will post some more pictures for us.
  29. Jalopy Joker
    Jalopy Joker
    loner2, cruiserjohn76, loner1 and 6 others like this.
