28 Coupe Build
Discussion in 'Traditional Hot Rods' started by 51box, Jan 16, 2016.
  1. 51box
    51box
    from MA
    Thank you
  2. 51box
    51box
    from MA
    Thanks Ron
  3. NashRodMan
    NashRodMan
    Looking awesome Joe!!
  4. LUTHER99
    LUTHER99
    Just found this thread today , went through the whole thing , what a great build , your very talented , can't wait to see the finished product !.
  5. Mikel50
    Mikel50
    Paint !? I wasn’t informed of this ...
    kidcampbell71 likes this.
  6. scotti32
    scotti32
    awesome build, it will be nice finished.
  7. 51box
    51box
    from MA
    Thanks guys, have a couple things to ****on up on the ch***is and hopefully bolt the body on this week 0C0AA242-E10C-4B8E-A82C-3C5DC8918062.jpeg
  8. nailheadroadster
    nailheadroadster
  9. Angry Frenchman
    Angry Frenchman
  10. 51box
    51box
    from MA
    Last big step for a little while, @Mikel50 stopped over and helped me get the body set on, we even managed to not chip any paint 6F6A4CEA-9EA9-4043-853F-DCF198FCD236.jpeg
  11. 51box
    51box
    from MA
    Hoping to get back on this next week, need to paint the doors, trunk, dash and shell. Can’t wait to drive this thing and see how the big Nailhead runs down the road. 7DD40827-2A99-42D3-BBCD-0A4B337F32EF.jpeg
  12. dirt t
    dirt t
    Paint job looks great. Good job.
  13. brianf31
    brianf31
    That's looking real nice.
  14. greaser
    greaser
    Looks awesome! Congrats!!
  15. Dyce
    Dyce
    Great work on your coupe! I saw a picture earlier of the fuel tank you used and I was wondering where you got it. Thank you for sharing this build. It is a ton of work!
  16. 51box
    51box
    from MA
    Thanks guys, @Dyce the tank is from Tanks inc I believe it’s a 14 gallon. I have adapted a low pressure 5psi OEM in tank housing and pump for it that I only have about $60 into also. I will put up some pictures soon and part #’s.
    brEad likes this.
  17. Dyce
    Dyce
    Thank you, I've been looking for ideas for my model a. It looks right at home behind the seat there.
  18. 1-SHOT
    1-SHOT
    from Denton
    Be sure you mount it really good because you don't want it to come loose in case of a accident, the fuel alone in a 14 gallons tank weighs close to 130 lbs.+ the weight of the tank same for the Battery. You don't want either to become a flying object. Early movie star Tom Mix and Reta Hayward both were killed in different accidents from flying objects in their car.
  19. Andy Velders
    Andy Velders
    Awesome build! Love the Nailhead and stance you have going on. Really enjoyable read. Thank you!
  20. Fry
    Fry
    from SK, Canada
    Great looking coupe
  21. brEad
    brEad
    Car looks great! Killer stance. Looking forward to more pics!
  22. 51box
    51box
    from MA
    Sand blasted and primed the big pieces a few weeks ago 551D499E-72CC-4CA2-80E6-874E8DB077DE.jpeg Was able to body work and paint the rest over the last couple of weeks. Going to try and get this stuff bolted on soon 1BEEB528-2FC7-4186-BCC6-0FAA20A7183A.jpeg
  23. 51box
    51box
    from MA
    Figured some people would be interested in this and would share this info on setting up a OE reliable in-tank pump on the cheap.
    I called up Airtex who is a OE supplier of fuel pumps and asked if they had a low psi in tank pump they offered. The picture below is the part number and specs of what I purchased. C7C3F6E6-7D5F-494C-853C-1BE6C2EEB8D2.png
    This is what the ***embly looks like as purchased from eBay, you can buy them for under $50 . The gas tank is a Tanks inc universal 14 gallon. The hanger ***embly is shaped all wrong for this tank but is an easy fix.
    Basically I cut the bracket and hard fuel line about 2”s from the base. Next laid the gasket from the Tanks inc flange on the flange of the new pump to cut the OD down and drill the new bolt pattern, picture below tells the story.
    Next up I measured the depth of the tank and used a piece of 1 1/2”, 3/16” stainless flat bar for the new bracket and bolted it down. Make up a longer power wire and a 12” piece of 3/8” R10 submersible fuel line to finish it up.
    That’s about it, and if there’s ever a problem a replacement pump can be bought without buying the whole ***embly.
  24. gonzo
    gonzo
    That is one mean looking car. Can't wait to see it out next summer.
    kidcampbell71 and 51box like this.
  25. etboy97
    etboy97
    I think I might have to use your fuel pump idea.
    51box likes this.
  26. vtwhead
    vtwhead
    great idea on the Airtex.
    51box likes this.
  27. 51box
    51box
    from MA
    Had to mock up the dash quick to see how she looks. I almost did it gold like the horn ****on but glad I went this way seeing it together.
    Next I fit up the doors and deck lid, has some issues and chipped paint but the are working pretty good now. 29BF999F-9938-4EDD-9167-B357D4BC06DC.jpeg
    After the big pieces were all bolted on I went around and collected every part left on shelves and cabinets I could find and painted them black. 29A6F7D3-29ED-4D85-B923-342458EB602A.jpeg
    With that stuff done I then had some gl*** cut and started getting that fit up and bolting small stuff together. 40A9E8CE-EACF-44D9-951C-9B6B1B6360BC.jpeg 20BE41DE-06B9-4C1D-9291-EDF6ED4A9696.jpeg
    That’s where it sits now, working on finishing up insulation this week and then start on the wiring harness.
  28. JOYFLEA
    JOYFLEA
    Looks great , black is hard to make look great . You nailed it . Be proud. Blue
    51box and brEad like this.
  29. Mikel50
    Mikel50
    Looks amazing Joe. Beautiful hotrod [emoji1362]
    51box likes this.
  30. Aaron D.
    Aaron D.
    Cars coming out beautiful man.
    51box likes this.
