Projects Cheap ass 34 pick up
Discussion in 'Traditional Hot Rods' started by dumprat, May 31, 2015.
  1. Nailhead A-V8
    Nailhead A-V8
    Model T column with gas lever ;) or Hemi? ...tough choice ...plus that leaves you with an engine you have to build another car for lol
    nunattax likes this.
  2. dumprat
    dumprat
    from b.c.
    Here is the issue. I can't get the throttle, and brake pedal far enough away from me to make it driveable. The width of the six bellhousing with starter nose makes it impossible.
    I am thinking of building an adaptor plate to mount something much smaller like an ax15 trans or something with a p***enger mounted starter. I don't like the idea of a modern trans. And I will burn the truck before I put in an auto like most guys do.
    tb33anda3rd and slo-dat like this.
  3. Six Ball
    Six Ball
    from Nevada
    I see the dilemma. The whole point is to be able to enjoy driving it. Solving these kinds of issues is what we take pride in even if most people who see the car will ever know what it took.
    If you replace the bell housing would a stamped steel one like a Lakewood be a good starting place. It would be easy to modify cut-weld etc. How much of the problem is the transmission itself? I agree with the modern and auto trans stand. My roadster build will use a Borg Warner T-86 3 speed over drive with a T-90 floor shift top plate. From a "54 Stude. T-86s are not as strong as some but served well behind Studebaker and Ford V-8s. There is also the much stronger T-85 but it is a side loader and not as floor shift friendly. I'm a big inline fan but if it a ****-load more work to use a less powerful engine what is the gain? Being different just to be different usually doesn't have good results.
    Atwater Mike likes this.
  4. dumprat
    dumprat
    from b.c.
    Well after a busy summer of beaches, bikinis, ****ies and booze I am finally back at working on my truck.
    Fixed my very old louvered hood. It had been welded to the hinge sometime in the past and the hinge was broken. I separated it from the hinge and had some 16g angles bent up and I welded them on the inside. This straightened out the center of the hood and gave me something to attach the new hinge too.
    The other side is done, I just ran out of primer. Tomorrow the truck truck starts to come apart to finish the frame and sandblast the cab! IMG_2707.JPG
  5. Six Ball
    Six Ball
    from Nevada
  6. Good job. Nice to get back at it?
  7. Mmmmm, the 4 "Bs"
    Tim and micamountain like this.
  8. falconsprint63
    falconsprint63
    from Mayberry
    This part is a real pain trying to preserve foot room for the pedalm here's my early stage effort 20181007_172729.jpeg
    Sent from my SM-G950U using The H.A.M.B. mobile app
  9. dumprat
    dumprat
    from b.c.
    My current thought is if I can get the starter to the p***enger side and drop the engine down a small amount I should have enough room.
    Tim, falconsprint63 and Stogy like this.
  10. falconsprint63
    falconsprint63
    from Mayberry
    After working on the second section I'm considering s****ping the round tunwl and going to a boxier approach like you have. It's pretty tight on the pedal as is 20181021_234456.jpeg
  11. Schwanke Engines
    Schwanke Engines
    Why not move the steering column up? would that work? replace with a different column, and move it up?
  12. dumprat
    dumprat
    from b.c.
    It's not the column, it's the width of the foot well. It is very narrow.
    falconsprint63 likes this.
  13. dumprat
    dumprat
    from b.c.
    IMG_2725.JPG So in feed my current hemispherical perversions (no not ****ies this time) I picked up a sweet deal on an a833 and hurst super shifter this week. The trans and shifter kinda blows my legit late 50's vibe but for overdrive and brute strength I can live with that. Ya can't see the trans anyway. The price tag of $180 for trans and shifter makes it easier to swallow as well.
  14. the oil soup
    the oil soup
    from Tucson,AZ
    Now that is a sweet deal!
  15. Boryca
    Boryca
    from Detroit
    OD is a must if it's a driver, in my opinion. Can't tell you how nice it is to have a Columbia in the '35 on the highway.
  16. nunattax
    nunattax
    O.D.is the way to go .don't cut off your nose to spite your face
  17. dumprat
    dumprat
    from b.c.
    Linkage is all done. Hardware store shafting and link ends from a rowing machine at the dump. Just my style.
  18. Stogy
    Stogy
    Looks Awesome...:rolleyes:
  19. CURSED GEARS
    CURSED GEARS
    Looks beefy and serious. Ought to do well.
  20. dumprat
    dumprat
    from b.c.
    IMG_2795.JPG IMG_2796.JPG More fitting and screwing around. Swapped out a couple of bad caps and hand fitted replacements. And 426 hemi studs. Bores are round within .0005 but still need honed. Rear cap is big in one direction by .001.
    And the 354 oil pump fits with a little grinding.
  21. dumprat
    dumprat
    from b.c.
    IMG_2813.JPG IMG_2814.JPG Well the six is out and the hemi mock up block is in place. Hard to believe this fits better. It's twice the size. It has to move up about an inch. And the exhaust is still going to be tight to the steering box.
  22. Stogy
    Stogy
    :rolleyes:...just like that...Cool...its the shuffling of the issues but the new hand may be better does it help the pedal deal?
  23. dumprat
    dumprat
    from b.c.
    Yes it fixes the pedal problem. The floor becomes almost flat.
    I am going to order a front cover to accept a Chevy water pump. It should allow me to push the engine forward an inch and still run a solid mechanical fan.
    Nailhead A-V8, Stogy and Runnin shine like this.
  24. akoutlaw
    akoutlaw
    I think that you will like the hemi just a little bit better than the six! :)
  25. Runnin shine
    Runnin shine
    I hope you make headers just as cool as the six and what about air cleaner/ers?
  26. Dick Stevens
    Dick Stevens
    The hemi raises the hot rod cool factor by 1000%! :D
    BradinNC and Nailhead A-V8 like this.
  27. dumprat
    dumprat
    from b.c.
    Hmm not sure about headers yet. Might run manifolds and single pipe exhaust with just a baffle. Drivers side head is super close to the steering box.
    Air cleaners and six headers and going to get bolted to the flatty six and painted up nice as shop art for now. Going to keep an eye out for a 20's dodge roadster body.
    Yes the hemi is pretty cool. Especially at the dollar I have invested.
    But the price of nice Chrome desoto plug wire covers is staggering. And I don't want finned aluminum.
    Nailhead A-V8 likes this.
  28. Six Ball
    Six Ball
    from Nevada
    I'm big on inline engines and think the Flathead six is way cool but it was causing problems that you solved with a bigger, better fitting, and very cool engine. That's what it's all about. You know ...You put the Hemi in...You pull the Flatty out .....You get the pedals workin' and you drive it all about.....:)
  29. dumprat
    dumprat
    from b.c.
    IMG_2817.JPG IMG_2818.JPG Was concerned I didn't have enough iron in my diet. So I thought I would try and see if I can use a Chevy short pump with a heavily modified desoto timing cover. Black booggers tells me I am likely up to my daily recommended intake.
    Stay tuned...
  30. Six Ball
    Six Ball
    from Nevada
    You damn hot rodders, you just can not leave anything alone. :rolleyes:
    greaser likes this.
