Projects Let me get this straight (axle). Streetfreak project!!!?
Discussion in 'The Hokey Ass Message Board' started by Firedup, Aug 7, 2018.
  1. Firedup
    Firedup
    from Oregon
    I believe so, no plaque or anything. It was given to my brother when grandpa p***ed. It does need to be rebuilt though. Leaks fluid. Have to add fluid every now and again.Not sure if we can find the parts to rebuild it.
  2. s55mercury66
    s55mercury66
    from SW Wyoming
    Yes, parts are available for those. I have a 1 1/2 ton version here, I think it weighs about that much.
    Firedup and Atwater Mike like this.
  3. s55mercury66
    s55mercury66
    from SW Wyoming
    The Garage Journal is a good place for advice on old floor jacks.
    41rodderz, Firedup and Atwater Mike like this.
  4. Firedup
    Firedup
    from Oregon
    A40BE89A-4EBD-4644-AB3E-9A2191707F50.jpeg C8BDBF61-DF05-4608-84BB-BA5CCF818990.jpeg Got the rear window installed today with the trim I got off the donor car. It went good. Only issue was trying to read the directions that came with the new gasket. Once my brother and I figured it out. It was installed in about 15-20 minutes. On to the front windshield. The gasket was a little harder to get on. The gasket also only had slits on the top and bottom of the windshield for the trim, where as the rear had a slit all the way around. So the trim I got from the donor car may not work. I may get a different gasket, or look for the correct trim for the gasket I got. Anyways today was a good day. Thanks for looking.
  5. Firedup
    Firedup
    from Oregon
    806E9A6A-2AE0-4A00-AACB-E980500B1BEC.jpeg 007A36DF-5C0C-4D4F-9DF3-53512AD7874C.jpeg Getting some windows in and trying to keep the wet weather out the best I can. Winter is around the corner and it gets wet around here lol. I don’t have a shop to put the ole girl into.
  6. raidmagic
    raidmagic
    Dang I didn't realize it was a 4 door until you posted the shot with all the doors open.
    Firedup likes this.
  7. Atwater Mike
    Atwater Mike
    AGGGHHH! The 'Parts Car' is a COUPE!!! Get ready to switch bodies!
    '52-'54 Ford Coupes are the Cat's ***!
    I have a '54 Coupe. 406 Ford, BW 150 3 speed, Jeep tower. (real floor shift; close ratio, big gears) My parts car was a 4 door customline...
    ffr1222k and Firedup like this.
  8. Firedup
    Firedup
    from Oregon
    I liked the looks of the car also but it was kind of a hack job. Floor completely rusted out also. I salvaged as much as I could and sorry to say the rest went to the s****yard.
  9. Firedup
    Firedup
    from Oregon
    Front windshield and trim installed. I got the correct gasket for the trim I had from Dennis Carpenter. Finished welding and installing steering u joints and shaft. Also put my windshield wipers on. I need to get some replacement wiper blades though. She is coming together nicely. 2772A842-2E5A-48E6-934E-2283B9F4C821.jpeg 6B94E29D-F3F5-42A2-B028-52374E242140.jpeg 8C2E14E6-2D13-41B1-99A1-8536D767AF88.jpeg
  10. RmK57
    RmK57
    Is there enough slack in that brake line ?
    lumpy 63 and loudbang like this.
  11. 59Tele
    59Tele
    It's a drag car, only needs to go in a straight line. Right? Looks like it might handle some left-hand turns: bonus. Real shame about s****ping the '54 coupe.
  12. Firedup
    Firedup
    from Oregon
    There will be. If you look close enough you can see they are not hooked up yet. They are just laying there. I will run all new brake lines. Need to install a new brake booster and master cylinder. Thinking about getting this one off eBay.
    oliver westlund likes this.
  13. Firedup
    Firedup
    from Oregon
    Yes I didn’t want to, but I didn’t have room or time for a second more intensive project.
  14. slayer
    slayer
    You should have saved all the parts (doors, pillars,front half of quarters) to convert your body to a two door.
    mad mikey and Firedup like this.
  15. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Normally 4 doors hold no interest to me. But this car reminds me of my buddy Lee's car back in high school in 1971. It was a 55 Ford plain jane 4 dr sedan, dark gray primer , chrome reverse wheels and he shaved the rear door handel's. But with a 390 , 4 speed and 410 gears that thing put so many so called Muscle cars to shame no one cared about the fact that it was his Grandmothers old car! lol I am not a big fan of the hood but otherwise this is a cool build. Larry
    Firedup likes this.
  16. Firedup
    Firedup
    from Oregon
    Yeah the hood. Lol. I have not finished the hood yet. I envisioned the hood to look like the very first pic in my thread except with a custom built stainless screen to let the air in and keep out the leaves, debris, etc. or this photo ^. I am thinking of weaving 1/8” + stainless tig welding wire and making a screen to cover the opening and somehow mount it so it is removable.
  17. Rocky
    Rocky
    Classified Editor
    Not to beat a dead horse but I can just see using the 53 coupe shell on the Merc frame with the Merc front sheetmetal. That would have blown everybody's mind! You're doing a nice job. Congrats
    indyjps and Firedup like this.
  18. Latigo
    Latigo
    Looks like you're located on the wet side of the mountains. Better work fast, the rain is coming!
    I like your build. Like the more-doors.
    oliver westlund, loudbang and Firedup like this.
  19. Firedup
    Firedup
    from Oregon
    327153FE-7D63-4566-8061-EDE297200AC9.jpeg 53875927-3F2A-4158-9B0D-DB6CB8D2653C.jpeg
    Rain for the next 9 months!!! I did keep the doors, side windows and some trim, etc. I feel like I’m turning into a hoarder. Lol. This is my first build. I don’t know if I’m ready for the cool **** yet.
  20. Firedup
    Firedup
    from Oregon
    0F64DE27-612A-4477-8346-1DEFE0A5A598.jpeg D25E6466-A437-40F8-B770-27233A2E7773.jpeg 63BACFBD-D5A2-41F0-B9AE-53D0BF1A0852.jpeg C435E6A6-874F-49B1-A774-A8C2420A7A7E.jpeg 133A4B1C-C092-471C-BC27-96A92D557576.jpeg Started mounting my radiator today. I had to notch some of the inner sheet metal to be able to move it forward for clearance issues with the steering box. I moved the radiator forward 2-1/2”, also in hopes of not having to use an electrical cooling fan. I will have some 2-1/2” o.d. channel formed up out of aluminum to attach to the radiator and radiator support. Now more issues with the Merc hood. Lol. I’m going to have to modify it, or leave the dam thing off. Well at least the radiator will work.
    oliver westlund and chevy57dude like this.
  21. Firedup
    Firedup
    from Oregon
    BE591128-E01C-4D32-8056-D1086FE31741.jpeg 8F302AEB-3B83-43C9-B14F-53826BAD12AA.jpeg It just looks so mean. I hope I can get this to come together.
  22. s55mercury66
    s55mercury66
    from SW Wyoming
    Would it be easier to modify the pan at the bottom of the radiator, and let it sit a little lower?
    Firedup likes this.
  23. Firedup
    Firedup
    from Oregon
    0D845050-0CC8-4F3E-8624-8F70530E173F.jpeg 06C6D2DC-97A6-475F-A6FF-D7F1D6E0922E.jpeg FD0C6739-9F3B-4C3B-BD92-923F768C8A1C.jpeg 2B68102A-9F8D-4D15-81DA-B839BBFE9332.jpeg
    Lowered it 2-1/2”. Now I have to modify the lower support brace. Have it tacked together for now. Need to add some metal tie it all back together and look nice. Hood clears the radiator by an inch now. That’s with moving it forward 2-1/2” and down 2-1/2”. Every time I touch something I double the amount of work it seems like. Lol. Do not need the channel formed up now. Moved the radiator support frame forward too. Now I can tie the inner sheet metal and support together with flat stock.
    oliver westlund and s55mercury66 like this.
  24. s55mercury66
    s55mercury66
    from SW Wyoming
    It looks like you cut the front crossmember in the pics. You might be able to fab a new one using some tubing in front of the radiator, and eliminate the stock one completely.
    Firedup likes this.
  25. Firedup
    Firedup
    from Oregon
    Got my brake booster this weekend. Looks like it is good quality. Tape measure for reference of size. Dam this thing is huge. Bigger than I was anticipating. I had to go to 3 local auto parts stores to find the right fittings to hook up the proportioning valve. Had it mocked up in the car. Everything lines up perfect. Needed to find all the fittings, so I’ll get this installed when I find some free time. 7499678C-2833-49E4-A3D1-482196240FC5.jpeg 712A88AB-2137-447B-9568-D9DDDFAAC9D6.jpeg
  26. Firedup
    Firedup
    from Oregon
    Found some time to work on my car. I got a few pieces of metal from work to do the rear radius wheel wells. It took me almost 6 hours to get both sides done. Labor of love I guess. They turned out pretty nice. I got the Lokar nostalgia 23” shifter for Christmas, so I will get to install that soon, along with my master cylinder and brake booster. C1995D46-DB82-4E83-A355-54F9BFBAF4B2.jpeg 0CBF1628-C1A4-4752-BA8E-918BE5E12C18.jpeg 973A74B9-38EF-4447-834D-AD53B92EBD62.jpeg
  27. Firedup
    Firedup
    from Oregon
    543B85F6-EF79-4409-A4FB-8502C816736F.jpeg E73BCC74-8230-4740-917A-E3D483C36CA2.jpeg F16DD4F7-77C9-412C-B025-93768BA48D7E.jpeg Pulled some door handles off the donor car doors also installed the key lock. I’ll need to order some new gaskets. I’ll probably order new shimlock for the keylock as one is on its last leg (starting to fall apart). I also need to get some new bolts for the door handles. Temporary for now.
  28. Firedup
    Firedup
    from Oregon
    I am going to have some parts burned out soon off our shop laser. Getting some brackets for some home made caltracs, and some front shock brackets. Pics when I get them.
    s55mercury66 likes this.
  29. Firedup
    Firedup
    from Oregon
    AC78EE28-2E48-46B7-A6B6-19D605D7ADA8.jpeg CEDCF2AF-CEBA-4255-A7F7-C004D9B3F9A3.jpeg 4D805232-9602-4CCB-BE91-696E14BE7E23.jpeg Got around to installing the lokar shifter I ordered. Cut a hole in the tunnel to make installation easier. I still need to finish setting up the neutral safety switch and final steps,wiring, etc. It looks pretty good. The only thing I do not like is that it shifts from D to 2 without having to push the ****on. I have read a few threads that cover tightening up the jamb nut on the right side of the shifter so that should fix the problem and I will cover that in my final steps of the install. I will have to make a custom tunnel cover to close off the hole as the shifter bracket is to close to the top of the tunnel. Also installed the brake booster and master cylinder. The brake pedal hole and booster rod don’t quite line up, so I am thinking about putting a stand off between the firewall and brake booster bracket. Should only need to be shimmed out about a half inch.
  30. Firedup
    Firedup
    from Oregon
    Pictures of the shock brackets and Caltrac brackets. Still need to order some pipe and heims. Turned out real nice on the laser. 1AC5FFE1-FA98-4E16-8BB6-FA48FD77D235.jpeg
    Greg Rogers, swade41 and Roadsir like this.
