Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. Blue One
    Blue One
    from Alberta
    I took it to Crystal gl*** at south common.
    Gary the gl*** guy there has done lots of hot rod stuff and knows what he’s doing.
    loudbang and 26 T Ford RPU like this.
  2. tfeverfred
    tfeverfred
    Looks great, man!
    Blue One likes this.
  3. brEad
    brEad
    Really love your truck! You set the bar so high!
    26 T Ford RPU and Blue One like this.
  4. Blue One
    Blue One
    from Alberta
    My 4 5/8” hot rod series speedometer returned home to me from Cl***ic Instruments.
    It will better suited to life in Canada now :cool:
    tfeverfred, Stogy, loudbang and 3 others like this.
  5. Stogy
    Stogy
    :rolleyes:...@Blue One, if you max that out you get a special hat...:D...:rolleyes:...oops naw its in km's... false alarm...it would still be quite the experience even at that...
    Do you plan on running it down the strip for a thrill at all?
  6. Blue One
    Blue One
    from Alberta
    The strip ? That remains to be seen, I'm sure I will have my share of fun and thrills with it.
    All testing will be on a closed course with a professional driver. ;) :D
    brEad, brad2v, Stogy and 2 others like this.
  7. K13
    K13
    I've seen your driveway. The testing won't be that impressive.:D
    brad2v, Stogy and loudbang like this.
  8. Blue One
    Blue One
    from Alberta
    :D It is a little on the short side isn't it. That's Ok, it's plenty big enough when you consider removing snow from it :D
    brEad, loudbang, brad2v and 3 others like this.
  9. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    And what about this 'Professional Driver'?
    loudbang, porkshop and Stogy like this.
  10. Blue One
    Blue One
    from Alberta
    Have you ever heard of the Stig ? ;) :D I do get some time off you know :D:D:D
    brEad, loudbang, bobbytnm and 2 others like this.
  11. Blue One
    Blue One
    from Alberta
    Well **** :D
    The windshield is finally on the car now after I broke the first one :oops: :mad:
    How you might ask?
    Well there’s a rubber strip that goes into a groove in the bottom of the windshield frame to seal it to the cowl and it was tight before chroming and even tighter with the plating.
    I should probably have had the gl*** guy put it in the first time but I forgot and in the process of getting it into place I pulled too hard on the frame and cracked the gl***.
    So,live and learn, back to the shop for windshield #2 and we haven’t even seen the road yet :D
    Lesson learned :D
    0D8A77FC-4C33-4550-A676-18C62452F7B0.jpeg F274F9B0-F779-4968-B02F-7E0959EBDD5F.jpeg 8545729D-1BCB-405F-8957-50A257644BF1.jpeg 2B5BEF01-0EBC-4482-A259-042839851D3B.jpeg FD80DDEF-FFDF-4836-9A1C-CE05CCC154A2.jpeg
  12. tfeverfred
    tfeverfred
    Stuff happens. Good recovery.
    Stogy likes this.
  13. bobbytnm
    bobbytnm
    Bummer on breaking the 1st one.
    It sure looks amazing with the gl*** in place
    Bobby
    loudbang and Blue One like this.
  14. 26 T Ford RPU
    26 T Ford RPU
    Looking real good, Larry. :cool::cool::cool::cool: JW
  15. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    The windshield makes it a whole new car.
    Very Nice!
    Blue One and loudbang like this.
  16. hotrod fozzie
    hotrod fozzie
    Very awesome build, getting ready to start my own roadster pickup build!!
  17. rusty rocket
    rusty rocket
    Looks GREAT!
  18. brEad
    brEad
    Looks fantastic, well done!
  19. Blue One
    Blue One
    from Alberta
    Before I dive into wiring I had to mount my coil so I found a spot behind the carbs at the back of the engine and used a couple of threaded holes in the block.
    Made a little bracket and welded it to the bottom of my coil cover tube.
    So it’s mounted nicely tucked away and ready to go :cool:
    1E8E01E4-E2BA-4412-9FAD-479A990A3693.jpeg DD61DD84-C799-4E9B-ABC0-04C2F7F6FEA6.jpeg F3A629B0-B527-45FA-9456-BC2AA244A5FB.jpeg 9EBB5629-1B97-4474-900B-40D3F6D5B532.jpeg FBA9612C-D8CD-47D0-8A5B-9DAAAC75DE07.jpeg
  20. Dick Stevens
    Dick Stevens
    Nice and tidy solution!
  21. tfeverfred
    tfeverfred
    Man.....you're killing me with the details! Am I taking notes? Yes.... yes I am. While my build is not loaded with chrome or fancy paint, I'm paying attention to details and your build is VERY inspiring. Thanks and carry on, man! For instance... the boot you used for the throttle arm through the firewall is neat! After a bad experience with a shredded cable, I switched to similar solution, but without the boot. Your boot is in my notes.;)
  22. Blue One
    Blue One
    from Alberta
    Thanks Fred more to come yet.
    That boot was listed on eBay as a Studebaker Avanti throttle boot.
    I think I should have ordered a spare, not sure if they’re still listed.
    Edit:
    I found one Fred if you’re interested.
    Pretty cheap too so I ordered a spare.
    http://studebakerparts.com/studebakerparts/store/s/agora.cgi?cart_id=&p_id=0210&xm=on
  23. tfeverfred
    tfeverfred
    Right click.... saved. Thanks!
  24. TurboRider
    TurboRider
    It's looking great! Seems like only just a few parts missing such as the wheel flares. Nice work!
    brEad and loudbang like this.
  25. Blue One
    Blue One
    from Alberta
    Thanks.
    o_O Wheel flares :confused: Don't be a smart ***. Or would that be more like don't be a dumb *** ? :p:D
  26. Blue One
    Blue One
    from Alberta
    Wanted to mount a panel to place all of my electrical wiring stuff on the inside of the firewall so I used 4 existing bolts and made an aluminum panel that bolts to them on the firewall on 1/2” thick feet / spacers.
    Once I get the wiring stuff figured out I’ll paint it white.
    7DE656DF-460C-4805-A4C6-076AC81FA901.jpeg 9119110A-5D51-46F1-9727-B352298D687C.jpeg
    olscrounger, AndersF, brad2v and 5 others like this.
  27. bobbytnm
    bobbytnm
    Good thinking! Well hidden and no extra holes in the firewall.
    I'll probably copycat you once I get that far.
    Bobby
  28. Tim
    Tim
    from KCMO
    So the stand offs are 4.5? Doesn’t look that tall in the photos, Curious to see this come together.
  29. K13
    K13
    I am pretty sure he means 4 feet that are 1/2" each.
    Sent from my SM-G950W using The H.A.M.B. mobile app
    loudbang, Blue One and Tim like this.
  30. Tim
    Tim
    from KCMO
    ^ yeah I think your right
    olscrounger and loudbang like this.
