1957 Chevy Step Van build or do you want to see my Gerstenslager
Discussion in 'The Antiquated' started by anthony myrick, Aug 7, 2018.
  1. woodbutcher
    woodbutcher
    :D Ahhhhhhhhhhhhh.Ok,thanks for the info.
    Good luck.Have fun.Be safe.
    Leo
    The 472 jumped timing
    Looks like the plastic coated gears gave up a long time ago. Students will replace it and we will see what it will do.
    lothiandon1940 and OahuEli like this.
  3. Fired up the 472. Runs pretty good
    We may go with it.
    Having this much torque means we can run a regular rear gear ratio like a 308 and cruise without having to use an OD trans
    345/490 is a lot more than the 235 it was born with
  4. OahuEli
    OahuEli
    from Hawaii
    Wow those teeth look pretty hammered. When you said you had low but even compression on all 8 I remembered running into this years ago. Glad you can use the Caddy. As always if you and your students would like to see their ideas in Photoshop I'm down for it. Eli
    brEad and anthony myrick like this.
  5. The 472 may end up in the roadster. Things change fast here sometimes. I might have inherited a rebuilt set of 462 heads.
    lothiandon1940, OahuEli and loudbang like this.
  6. Students want the big engine in our other project. A friend was cleaning out his shop and gave me a 283 power pack long block. Stored indoors and turns.
    Also have access to a 250 inliner.
    Another friend gave me a TH350 trans
    Decisions decisions
    lothiandon1940 and loudbang like this.
  7. warhorseracing
    warhorseracing
    from cameron wv
    It is a '57 so the 283 would give it more power than it ever had and would be correct for the year.
  8. I had a set of 462s built for a friend.
    He decided to go another rout and does not need em. They are 194s. New springs, guides, hard seats and a valve job. I know it will lower the compression over the PP heads but it may make it ****py gas compatible
    loudbang and chevy57dude like this.
    we had a geometry lesson today
    we set up the ch***is at ride height and rake
    students learned about why establishing this is important for caster
    our ch***is will have a 2 degree rake but where our front suspension mounts will be set at zero which will keep the donor suspensions geometry correct
    brEad, OahuEli, Okie Pete and 3 others like this.
  10. Engine test fit
    Okie Pete and loudbang like this.
  11. simplestone
    simplestone
    Interesting build. What a great learning experience for the students! I'm watching.
  12. we got a drive line angle lesson today
    I teach body work but I like projects like this to expand beyond that
    the math and problem solving skills are something that will help in any occupation they may end up at
    OahuEli, loudbang and lothiandon1940 like this.
  13. lothiandon1940
    lothiandon1940
    .................Only makes sense that with a name like Gerstenslager they would create a Weiner mobile.:D;)
    loudbang and anthony myrick like this.
  14. Geez, I wish I had you for my High School shop teacher! You guys do nice work!!
  15. thanks
    When you teach at a career center, you have students from different schools bused in. Today was a day where 1/2 my students were not here due to scheduling and athletics. I use days like today to work on these types of builds.
    This does cover math,suspension technology and geometry which fits my curriculum.
    Our automotive students will build the transmission, engine, and brakes and handle the wiring.
    When we finish the ch***is, students from both cl***es will perform the alignment.
    I also use students from our welding and machine cl***es to help build parts.
    I drive the projects to shows and businesses to promote our school.
  16. 59Tele
    59Tele
    If you're not aware of them, Mill Supply is THE source for stepvan parts. I ran '80 Grumman (built on a P-30 Chevy ch***is) for a work truck and they had pretty much anything I needed over the years like steering shaft U-joints, heater core, steering box, brake parts, wiper motor, etc. Worth checking out their on-line catalog.
    anthony myrick and loudbang like this.
  17. Thanks. Gonna need some door hardware
  18. 59Tele
    59Tele
    Yep, door and window hardware, too. Your hoopie is pretty old, you may want to call them if something isn't listed. You may have to adapt some newer parts based on the pictures of parts they provide but these trucks are the easiest things in the world to work on. When you get to the wiring aspect, making good grounds for the lights are paramount because of the aluminum body. When a light doesn't work it's always the ground.
  19. Man I wish this rust bucket was aluminum. But I probably would have not got the opportunity to get if it was.
    Aluminum and copper is tough where I live
  20. BamaMav
    BamaMav
    from Berry, AL
    Yeah, the Walker county meth heads would have done toted it off, piece by piece, if it were aluminum.
  21. students made me a shopping list for the thanksgiving holiday next week
    we will probably slack off a little on this as we study for ASE exams
  22. OahuEli
    OahuEli
    from Hawaii
    They're pretty close in looks...
    brEad, loudbang and anthony myrick like this.
  23. loudbang likes this.
  24. OahuEli
    OahuEli
    from Hawaii
    Yeah it does, kinda like Droopy the dog. Maybe French the headlights to get away from that "bug eye" look?
  25. Wonder what a chop would look like?
  26. our diesel students visited today, so I took some time to explain the ch***is set up. We discussed caster, camber, toe, drive line angles......
    explained why ride height was important and did a basic pattern for boxing the frame at the rear axle notch location.
    loudbang and warhorseracing like this.
  27. BamaMav
    BamaMav
    from Berry, AL
    A lot of work:D:D:D
  28. Students cleaned and buffed some of the old paint
    I think this is the look we are after
    OahuEli, brEad and loudbang like this.
  29. flyin-t
    flyin-t
    That's a Gerstenslager.
