Unable to post pics
Discussion in 'Questions & Suggestions' started by jackalope, Nov 11, 2018.
  1. jackalope
    jackalope
    Anyone else having issues with the mobile app? I am no longer able to post pics. Doesn’t even show as an option. I am only able to post comments.
  2. rob-redm
    rob-redm
    my mobile app hasn't worked at all for some reason... get some kind error message.
  3. pprather
    pprather
    When I have trouble with the Android app, I uninstall it, then reinstalled from the Google play store. Sign in and good to go.
    Try it, see if that helps.
    Phil
  4. jackalope
    jackalope
    I deleted it and reloaded but problem persists. I also shut phone down and all of the other basic tricks. Still no luck.
  5. Stogy
    Stogy
    Are you logged in?
    Truck64 and chryslerfan55 like this.
  6. Stogy
    Stogy
    I'm on my phone (android) using Goggle Chrome and I use this Hamb connection below...I just login every time and it works for me.
    https://www.jalopyjournal.com/forum/
    Perhaps you can use this till you figure out what's going on.
  7. squirrel
    when I have problems with the android HAMB app, I go to Settings, then Apps, then click on the HAMB app, then "force stop". Then open it again, and it always seems to work.
    Mostly I only have problems with it when I have poor phone service, because I'm in an area with lousy signal.
    But I doubt this has anything to do with your image problem. You could try it, just for fun, who knows.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    Stogy likes this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    maybe shut your phone off and re start it? I am going to move this thread to questions and suggestions. Maybe someone can help. but it seems like it is your phone..
    jackalope and lothiandon1940 like this.
  10. jackalope
    jackalope
    Thanks Moriarty! Yeah, I’ve tried everything. What is weird is it let me load one pic yesterday before I posted this and ever since, no bueno. It only let me load the one also.
  11. jackalope
    jackalope
    Only way I can add pics is by going through Web View[emoji53]
  12. Stogy
    Stogy
    @jackalope I posted a link to the Hamb above. I use it with my phone. Click on that link, log in and go to this thread and see if you can load a picture...if you can then you know it's the app. This post was done on my android phone...(Samsung)
  13. Stogy
    Stogy
    You can delete the app and reload it as an option. Try loading pics on other apps that you post pics on.
  14. jackalope
    jackalope
    I’ve tried everything. Just deleted the app again and reloaded. Nothing. I can send pics in all other apps too? What is weird is it was working fine and literally stopped working yesterday when I started losing pics. It loses one and then something happened and the icons to post pics disappeared.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    maybe @Ryan can fix it?
  16. jackalope
    jackalope
  17. lothiandon1940
    lothiandon1940
    ......Click on @Ryan in Mark's post above. Or here.
    lothianwilly71 likes this.
  18. Ryan
    Ryan
    ADMINISTRATOR
    Man... it sounds like a memory issue with the phone. What version of the app are you using?
  19. jackalope
    jackalope
    The latest I believe. I deleted it and then downloaded from the cloud and no luck. It’s a brand new iPhone Xmax and latest iOS software too.
    Again, it was working the other day and then stopped mid useage.
  20. jackalope
    jackalope
    Here’s what my screen looks like when I try to reply
    Remember, I am in the web format to post this image shot.
  21. Stogy
    Stogy
    This is the non app version of the Hamb below I use on my phone...have you tried this?
    If you can post pics using this method it potentially confirms an app conflict...
    Note: You must login to reply or post same as on desktop version.
