Hot Rods Does anyone know of any good central Ohio radiator shops ?
Discussion in 'The Hokey Ass Message Board' started by Tin Lizzie, Nov 13, 2018.
  1. Tin Lizzie
    Tin Lizzie
    from Ohio
    Hello everyone,
    Does anyone know of any good radiator shops in central Ohio ?
    Thanks,
    Mark
  2. BillSchmid
    BillSchmid
    from Ohio
    Cincinnati Radiator in Fairfield does good work.
  3. Atwater Mike
    Atwater Mike
    I worked a couple of days with a radiator man here, (Livingston, 6 miles North) he showed me the 'flow', or 'float' of the top shelf, where the tubes all come thru...the tank is a 'cakewalk' after that, but to 'set up' to do my T would defeat every corner of the A.D.D. that has ahold of me!
    My former 'B' Teamrace partner Doug and I got to designing and building our own tanks for the .29 C.I. racing engines in the Control Line race planes we also built.
    No 'solder mess', every joint was done with a minimal amount of solder, then wiped as clean as when we tinned it.
    But full size radiators? I'll look for a 'radiator man', although they are an endangered species! Either too old or dead!
  4. Petejoe
    Petejoe
    from Zoar, Ohio
  5. Tin Lizzie
    Tin Lizzie
    from Ohio
    Thanks everyone for your help !!!
