Hot Rods riderightparts
Discussion in 'The Hokey Ass Message Board' started by silent rick, Nov 12, 2018.
  1. abonecollector
    abonecollector
    that axle looks better than a few others i've seen on ebay. There are a couple of sellers on there right now, selling what appear to be an ***embled axle. The spring boss' & king pin area's almost look like they are welded to the bar stock
  2. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    What knowledge of foundries and suppliers do you have that would help make a decision?
    Kan Kustom and Atwater Mike like this.
  3. gimpyshotrods
    gimpyshotrods
    The exact alloy makes a huge difference.
    Forged hard candy wouldn't make a good axle.
  4. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    True, but can't think of any axles that have this info available.
    Kan Kustom and 5window like this.
  5. bchctybob
    bchctybob
    I've never seen trace-ability data on anyone's aftermarket axles, not even Ch***is Engineering's. And finding out the origin of them hasn't ever been an exercise in transparency either. So I suggest you do whatever research makes you fell warm and squishy and pull the trigger. If aftermarket axles scare you then stick with original Ford axles. Of course you will know the origin and the entire history of each and every one of those, right?
    Sheesh. With all the single point failure locations on the typical hot rod that could conceivably cause a crash, how do you guys ever feel comfy enough to drive them?
  6. 5window
    5window
    Seems like the question was asked, and answered. And quickly. While a lot of Chinese made items are ****, they certainly have the technology to produce a high quality part for the right price point. The problem is that most of the time, "Walmart Auto Parts" wants quality tied to a price point-the wrong way to go. FWIW, there are, and have always been, plenty of **** products produced here in the USA. Not sure what country of origin will prove.
  7. mitch 36
    mitch 36
    Rick, why not get a hold of GREG32 and see if he's got an axle, might have an original then send it out for a drop. At least you know the quality and place of manufacture from the get go. Mitch
  8. Atwater Mike
    Atwater Mike
    Chrome Vanadium steel. Henry knew...so did the Dodge Bros., who ran his forging operations and made the Ford axles. (and their own, too!)
    They never gave out the 'formula'.
    Kan Kustom and gimpyshotrods like this.
  9. 5window
    5window
    Devil's advocate here. First, you need someone to not screw up dropping your original Ford axle. Second, I am no metallurgist, but I would imagine a re-worked dropped axle could have substantially different strength and other properties than a quality forging that was the right shape to start with.
    Kan Kustom likes this.
  10. alanp561
    alanp561
    If you look up Bous Performance Inc., you'll find that they import from Taizhou Hengxin Auto Parts Co. Ltd. so, yeah, they're importing from China, just like Speedway and a lot of others. The Summit brand intake manifolds have "Made in China" stamped right on them, the NAPA brake drums on my OT '95 F150 came from China, the packages of hardware I bought at NAPA and used to rebuild my 48 F1 brakes came from China. I'm pretty sure that the kingpins, bushings and bump stop bolts I bought from Speedway came from China. Jeff, from Bous, answered the question about whether or not their axles were forged steel pretty darned well. Myself, I'm using an original Henry made '48 axle because it already has a factory drop and I know where it was made.
    Kan Kustom and Hombre like this.
  11. gimpyshotrods
    gimpyshotrods
    Henry Ford's do.
  12. gimpyshotrods
    gimpyshotrods
    Vanadium is a cl*** of formulas.
    The scope is known.
    Cr 0.60%, 0.80%, 0.95%; V 0.10%, or 0.15% min.
    alanp561 and Ned Ludd like this.
  13. killbilly
    killbilly
    Alright Rick do you feel better now?They also have some nice Mustang ll front suspensions too !!
  14. Hombre
    Hombre
    OK gimpy so what are those numbers supposed to mean? That certainly is not a formula, as a matter of fact it is the symbol for two elements on the atomic table. One being CR which is for chromium, and the other V is for vanadium. Now they just may be in the formula for Old Henrys steel, but they alone do not by any stretch of the imagination make up a formula. So if the formula is known what is it?
  15. silent rick
    silent rick
    so pete & jakes is now selling this axle? i can't seem to get an answer from them. do you have their part number?
  16. silent rick
    silent rick
    i'd like to find an original 32 heavy and have it dropped. i never was a fan of the stretch dropped, some of them get down right ugly looking. i know you don't have to get the stretch drop and lose a little width. i'd be happy with another ch***is engineering axle.
  17. silent rick
    silent rick
    do you mean "mustang also" front suspension?
    as i mentioned earlier, looking at the bottom view, you can make out what remains of the wide parting line on the riderightparts axle.
  18. Chappy444
    Chappy444
    Regarding the "exact" formula for the steel Henry used in his axles.....
    Here is the NIST Standard Reference Material (SRM) for Chrome-Vanadium-Steel (SRM-663 *note FE Cr and V values are the same for SRM-363 as well*) this is a pretty EXACT alloy and it cost $525 for 5 very small rods (imagine buying this level of precision alloy on a auto manufacturing scale). I have made the major cons***uents of this alloy Bold. Many of the lesser cons***uents have greater levels of uncertainty and are introduced to the alloy from various steps in the production process such as the quenching material, production process, environment, etc... I.E. the contents of the water or oil used for quenching. This actually varies from location to location and country to country. It is possible to identify down to the foundry were a metal was produced based on the content % and ratios of certain lesser cons***uents. (My company was actually tasked with this job by the DOD to try and identify where the shrapnel used in IED's was coming from.)
    Add to all of this the fact that these cons***uents are being measured and mixed by the front end loader bucket fulls and you can see that there will be a large variation from batch to batch from any given foundry at any given time. the good thing is that of the major cons***uents the variation is usually confined to the second decimal place. Most variation of Chrome Vanadium steel are very, very similar to 8650, Chrome vanadium steels have excellent properties such as strength, toughness, and resistance to wear and fatigue in all alloy variations. the tighter you get with your % on the formula the more expensive the alloy becomes and we all know how Henry liked to keep the cost down on his production
    So, I think the exact formula that Henry used is actually a fairly large range and may not have been exactly duplicated from batch to batch, even if every batch came from the same shift of men working at the same foundry in the same month (which obviously didn't happen)
    Elemental Composition (m*** fraction in %)
    Carbon 0.57
    Manganese 1.50
    Phosphorus 0.029
    Sulfur 0.0055
    Silicon 0.74
    ****nic 0.010
    Tin 0.095
    Boron 0.00118
    Lead 0.0022
    Silver 0.0038
    Germanium 0.010
    Oxygen 0.0007
    Nitrogen 0.0041
    Hydrogen <0.0005
    Niobium 0.049
    Selenium 0.0001
    Tantalum 0.053
    Zirconium 0.050
    Copper 0.098
    Nickel 0.32
    Chromium 1.31
    Vanadium 0.31
    Molybdenum 0.030
    Tungsten 0.046
    Cobalt 0.048
    ***anium 0.050
    Gold 0.0005
    Cerium 0.0016
    Hafnium 0.0015
    Lanthanum 0.0006
    Neodymium 0.0007
    Praseodymium 0.00018
    Iron 94.4
    Antimony 0.002
    Bi****h 0.0008
    Calcium <0.0001
    Magnesium 0.0005
    Tellurium 0.0022
    Zinc 0.0004
    Aluminum 0.24
    Chappy.
  19. 5window
    5window
    The standard appears to be ASTM A-231. Chromium 0.08-1.10%, vanadium 0.18%, manganese 0.7-0.9%, 0.5% carbon, 0.3% silicon
    gimpyshotrods likes this.
  20. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Agreed. The only dropped Henry axles that look good are the 32's. Others usually look downright fugly, especially on a fenderless car.
    Good for Bous on posting the video. Gives us another forget choice along with the P&J (Ch***is Eng) axle.
    I'm running a very early Magnum axle, which I believe is forged?
  21. RICH B
    RICH B
    Talking TRJ#80 :( and the mailman hasn't even brought me #79 yet!
  22. Malcolm
    Malcolm
    from Nebraska
    BigDTexasKid and silent rick like this.
  23. Kan Kustom
    Kan Kustom
    Thanks for posting that. I haven't looked at their website for a long time. I am very glad to see they took on the Ch***is Engineering dropped steering arms. They have always been my favorite.
  24. Riderightparts
    Riderightparts
    Thanks for the feedback guys , I understand the concerns.
    We have sold a bit of these not had any returns or complaints. Also offer the axles in chrome drilled and non drilled and carry some perches, 4 link kits, bat wings, and lots more , please try not to base us off the web page its a work in progress but we need to keep the bills paid in mean time.
    Ill leave my contact info for questions 951-653-4114 Ill do my best to answer anything you need if I don't know give me sometime and Ill find out.
    Thanks again for allowing me to be part of your post.
  25. silent rick
    silent rick
    man, why did they have to go and add that super bell logo to it? looks like i'll be looking for an original ford axle.
  26. bchctybob
    bchctybob
    Yeah, I agree. I guess that's why God created a variety of grinders.
    alanp561, X38 and Hombre like this.
  27. 38Chevy454
    38Chevy454
    Thanks for the replies Riderightparts. It does help to have the real results. As the old HAMB Metallurgist, if you can provide more info it is always good. Just because Ford used Cr-V low alloy steel does not mean this is the only good material choice. I can provide even better for example a Ni-Cr-Mo alloy will have even better toughness. But at higher material cost of course. Ford used what was good for the application and met cost targets.
    Made in China does not mean automatically bad. China can produce very high quality parts, or very low quality parts. As the old expression goes, one good test is worth a thousand opinions.
    Guys on HAMB, he is trying to help answer the questions, and we should be thankful for the effort. Having more suppliers is good, ***uming they produce quality parts. Yes I know we tend to like original parts, and many have been burned with poor quality aftermarket parts as well. Let's try to have open mind while allowing for appropriate level of caution. Ultimately we all want safe and reliable cars.
    5window, dan31, Max Gearhead and 5 others like this.
  28. patsurf
    patsurf
    ok-from now on YOU get to be point man on these sort of things-you are calm and down to earth!-good on you--
    raven likes this.
  29. Beanscoot
    Beanscoot
    "why did they have to go and add that super bell logo to it?"
    I don't know much about these solid axles, but one catalog listing said the logo was on only one side, so can't you just flip the axle around to show the plain side?
