Technical Blown flathead - streetable?
Discussion in 'Traditional Hot Rods' started by bhemi, Nov 16, 2018.
  1. bhemi
    bhemi
    I just bought a 1950 Mercury 8 coupe. I have been puzzling over what to do with the engine. I prefer hot rods over customs. I have no great urge to alter the body much but I want it to handle better, brake better and go faster. If I take the stock 255, bore it out and add a 4-71 or a SCoT blower on it with after market heads what is a realistic result for power and how drive-able would it be? If I can't take it a few hundred miles down the road I don't want to go that route. No way am I putting a Chevy engine in it. If the Flathead won't work out I will put another Ford engine in it.
  2. town sedan
    town sedan
    An early hemi, or Cadillac OHV would motivate it down the road nicely too. That is if the Merc isn't enough for you.
    -Dave
  3. roseville carl
    roseville carl
    put over 30k on this one and tow my race car with it, about 200 hp and very streetable ford 9" with 3.0 gears 65 at 2400
  4. ol-nobull
    ol-nobull
    You may be aware of this but if your question is will it still be streetable because of the blower you should have a clutch on blower drive where you can disengage it when all that power is not needed by using a push- pull switch.
    Jimmie
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Have the perfect rebuilt engine for sale for that car.
  6. town sedan
    town sedan
    I thought that only worked in Mad Max movies...
    -Dave
    classiccarjack, squirrel, Tim and 7 others like this.
  7. seb fontana
    seb fontana
    from ct
    Actually there are blowers with electric clutch in some small Japanese cars but a rather intense manifolding/byp*** valve arrangement..I have seen some Aussie engines with a by p*** but not the electric clutch..
    chryslerfan55 and gimpyshotrods like this.
  8. Bandit Billy
    Bandit Billy
    Brethren, let us all turn to the good book for the answers to which we seek
  9. Eaton M90s have said byp***. Been a few ran on flatheads with good success. Do imagine with a carb set up to be run draw thru supercharged if you disengaged the clutch it'd run pig rich N/A. Probably best EFI with that arrangement.
  10. Montana1
    Montana1
    I've run carbureted street blowers for decades and they are VERY reliable! Over 200,000 miles on the current one. No need for a clutch, just keep it simple and run it!
    PoTaToTrUcK, Tim, Hombre and 2 others like this.
  11. Bandit Billy
    Bandit Billy
    I built my flathead to the numbers as Joe Abbin load them out. I am still breaking the motor in but it is powerful and quick from the fun I've has with it so far. Idles nice, revs fast, sounds mean, what's not to like?
  12. mad mikey
    mad mikey
    If you go blown you will find boost to be addictive. ;):)
    Montana1 likes this.
  13. Montana1
    Montana1
    Of course that is on a Chevy! lol :rolleyes::D
    nunattax, GuyW, jaw22w and 2 others like this.
  14. RichFox
    RichFox
    In truth the after market (finned) heads are counter indicated in a blown engine. No good reason to up the compression when you can use boost to increase compression pressure. And an iron head looses less heat than an aluminum head. But I expect the bling factor will overcome all that. Clutch on the blower drive is fantasy for the most part. If the throttle plates arn't open, as in cruising, the blower can't make boost with air it doesn't get.
  15. Ebbsspeed
    Ebbsspeed
    The clutch thing doesn't make sense to me. At partial throttle you don't have boost anyway, so why clutter up the engine compartment with useless hardware and added complexity? Drawing through the blower at partial throttle building no boost is a benefit anyway as the mixture gets stirred by the rotors and atomizes the mixture better.
    flatford39, Montana1 and mad mikey like this.
  16. mad mikey
    mad mikey
    Right. If the blower is not spinning your not winning.;)
    Montana1, akoutlaw and Bandit Billy like this.
  17. mad mikey
    mad mikey
  18. Flat Roy
    Flat Roy
    2X what Carl says. 4-5 lbs. boost. at full throttle. use recirculation valve to get 12-18 ins of vacuum cruising . 15-18 MPG cruising, in my 1950 F1
  19. Atwater Mike
    Atwater Mike
    Everything in moderation, Gr***hopper.
    Texas Webb and Bandit Billy like this.
  20. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    10B0D48C-3986-4382-951E-76491D3CDCA9.jpeg Your blower does NOT need a switch; it just needs a moderate amount of boost(5 pounds or less for a flathead) and it will be plenty of fun. You start applying more boost and as boost goes up,so do the modification necessary in the “built” for it to survive. It is practical for a blown flathead to have 200-225-250 h.p. And be streetable and a fun, reliable driver but don’t expect to attain these figures on the cheap side. Pic is of Pontiac 4 banger at Pomona on the street with a GM blower in a model a roadster on 32 rails.
    Tim, Montana1, Texas Webb and 2 others like this.
  21. I wonder how a blower, with tri lobed, helical rotors and teflon seals, would work in the mystical Mad Max scenario? If the blower isn't spinning, how can the vacuum, created by the pistons, draw the charge through the said blower and into the combustion chambers? Movie Magic???
    Montana1, Hnstray and chryslerfan55 like this.
  22. gimpyshotrods
    gimpyshotrods
    It was hollow, set over a carburetor.
    In the garage scene, there is no fuel line hooked up, and the engine is running.
  23. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    ^^^^ Your A BUZZKILL! LOL!
  24. Bandit Billy
    Bandit Billy
    Max must have been in Portland a summer or two back cuz I spotted his car at a Wednesday night cruise in at PIR. That blower still didn't look operable nor did that pistol grip ****ter gun on the dash.
  25. DDDenny
    My old high school pal knows the guy that owns that contraption.
    mad mikey and chryslerfan55 like this.
  26. If blown flatheads are the idea then this ought to get ya excited [​IMG] enjoy.
  27. choppedtudor
    choppedtudor
  28. Texas Webb
    Texas Webb
    Cool,and nice copper work.:D
    mad mikey likes this.
  29. krylon32
    krylon32
    from Nebraska
    Back about12-14years ago I built a FH powered deuce roadster with a mild performance motor, nothing radical and one of Joe Abbin's 172 Weiand blowers. We were only doing between 4&5 lbs of boost on 8 to 1 compression but with the 5 speed trans and 3.78 gears it ran like a scalded dog. After I drove the car for a year I sold it to a customer in Portugal and have heard nothing since.
  30. Ebbsspeed
    Ebbsspeed
    The vacuum created will spin the blower when there is no belt.
    I've never seen any Mad Max movies but suspect that there are plenty of ******** scenarios regarding the vehicles.
    Texas Webb, mad mikey and Montana1 like this.
