Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    There's more info available from that wika something site.
  2. foolthrottle
    foolthrottle
    Hispano Suiza ( Sway-zah)
    Garpo, tinsled, davidvillajr and 9 others like this.
  3. Deuces
    Deuces
    Love the way it gits rubber.... :D
    loudbang, seb fontana and 1947knuck like this.
  4. warbird1
    warbird1
    Indian Rotary aircraft engine, built by Hendee Manufacturing, c. 1909. One of two known to exist... indian3.JPG indian1.JPG
    loner2, Stebo27, loner1 and 6 others like this.
  5. sliceddeuce
    sliceddeuce
    loner2, Stebo27, loudbang and 2 others like this.
  6. sliceddeuce
    sliceddeuce
    1 rotv.gif Since you asked
    Stebo27, loudbang, RMR&C and 2 others like this.
  7. Ned Ludd
    Ned Ludd
    I think the instinct of most on here would be to swap the intake/compression strokes and the power/exhaust strokes – effectively supercharging the engine.
    loudbang and 1947knuck like this.
  8. Deuces
    Deuces
  9. plym_46
    plym_46
    from central NY
    Instead of thinking four strokes, think instead of four cycles. Still ****, squeeze, bang blow, just accomplished in 360° instead of 720.
  10. 1947knuck
    1947knuck
    Experimental 2-Stoke engine tested in various cars during WWII including Chevrolet & Oldsmobile. gm8.jpg
    TBirdGirl26, loner2, Stebo27 and 6 others like this.
  11. 1947knuck
    1947knuck
    How about a little story with this engine picture. The engine is a 1908 JAP air cooled overhead valve and is one of only four surviving examples of this engine, this engine is the actual prototype V8 engine. It was construted around the remains of what was originally a belt drive pre-World War I GNV-twin using only original parts. I think it is as cool as can be. gn2.jpg gn3.jpg gn1-1080x650.jpg gn12.jpg
    TBirdGirl26, loner2, Stebo27 and 14 others like this.
  12. Deuces
    Deuces
    ..... And it's a straight axle car... :cool:;)
    1947knuck and loudbang like this.
  13. loudbang
    OHC conversion
    FORD SOHC experiment
  14. foolthrottle
    foolthrottle
    Sitting directly over a bunch of chains and sprockets spinning at high speed....... eh, what could go wrong?
    ClayMart, Deuces, XXL__ and 2 others like this.
  15. Fordors
    Fordors
    Englishman Rudolph Ackerman received a patent on the Ackerman principal in 1818, but it appears the JAP organization never got the memo :eek:
    Deuces and loudbang like this.
  16. Fordors
    Fordors
    Thanks for posting that @loudbang, it's the refined Riley design I had mentioned.
  17. That's an old myth. British drink beer at room temperature, which is about 38 degrees F:D
    j-jock, loudbang, 63fdsnr and 2 others like this.
  18. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Now that thar's funny.
    loudbang and Deuces like this.
  19. 1947knuck
    1947knuck
    I'm not sure if this is a unique setup. It looks like it could be. Is it an old SOHC with a belt drive? 02267b04dfa12c030a4e47173aacb2bb.jpg
  20. Deuces
    Deuces
    Yep! As long as the valve timing holds up....
    That would **** if one of those belts let loose... :confused:
    loudbang, 1947knuck and XXL__ like this.
  21. SR100
    SR100
    So Lucas made heaters?:rolleyes:
  22. ClayMart
    ClayMart
    Ahhh. Lucas furnaces. :rolleyes:
    Speedwrench, loudbang and 63fdsnr like this.
  23. khead47
    khead47
    Thanks ! I needed that ! Also---how did you know I am old enough to remember steam locomotives ?
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Deduction via ratio. You see I'm young compared to most here. So if I remember, unless let's say you've lost all your faculties, sum says you experienced it and remember. :)
  25. loudbang
    Part of that OLDS development package DOHC
    loner2, Stebo27, loner1 and 2 others like this.
  26. sliceddeuce
    sliceddeuce
  27. seb fontana
    seb fontana
    from ct
  28. Caprice89
    Caprice89
    That's warm to me...
    Sent from my hand held online shouting device.
    Speedwrench, VANDENPLAS and loudbang like this.
  29. VW engineered by the late, brilliant Jim Feuling
    loner2, Stebo27, wicarnut and 6 others like this.
  30. Zebedee
    Zebedee
    Lancia Fulvia motor. 10, 11, 13 or 20 degree shallow angle V4.
    Ford Es*** V4. As used in European Fords and Saabs in the 1960's.
    A bit outside the box.
    ****el rotary as per Mazda and NSU.
    loner2, Stebo27, wicarnut and 4 others like this.
