Technical Spindle king pin issues. Adapter question
Discussion in 'The Hokey Ass Message Board' started by SMH, Nov 17, 2018.
  1. SMH
    SMH
    So I put a new drop axle on and the kingpin size is .81 the old kingpin are about .93. No problem so I just get new spindles. So now the brake backing plates will not go on the spindle. My question is there a bushing or a adaptor that will let me use my old spindles?
    Or are there some new spindles that will clear the backing plates on my old drums?
    Pic of new spindle with backing plate
    Pic of old spindle with backing plate
  2. SMH
    SMH
    Looks like if I had a bushing for the old spindles to make the new kingpins fit it would work.
    .93 od to a .81 id. Do they make such a thing
    clem likes this.
  3. X38
    X38
    Are those Lincoln brakes/spindles?
  4. No they don't make a bushing like you need that I know of. Were it me in your Fix I'd get a reamer that is .935 and open up the Axle boss to fit. They make adjustable reams for fine tuning a specific fit. Actually is not that uncommon in the Machine shop world.
    The Wizzard
  5. krylon32
    krylon32
    from Nebraska
    Most Lincoln Brakes or F250 brakes require some relieving of the top of the spindle for the backing plate to fit into place.
    gimpyshotrods likes this.
  6. SMH
    SMH
    I am not sure what the brakes or the spindles are off of. I cant find anything with a kingpin that size.
  7. gimpyshotrods
    gimpyshotrods
    Grind the spindles. It is a thing that is done for other brake swaps.
    Notch and plate backing plates, too.
    Pist-n-Broke likes this.
  8. SMH
    SMH
    They make these but it still doesn’t look like it will clear with those. The backing plate looks to deep. Not sure.
  9. SMH
    SMH
  10. gimpyshotrods
    gimpyshotrods
    Would you be so kind as to post a picture of the "business side" of the backing plate?
  11. F&J
    F&J
    .Grinding the spindle can't work if I see this correctly. If you grind, then the top of the new kingpin and boss will not clear the backing plate....and even if you cut a notch in the plate for the kingpin top, it would then be hitting the wheel cylinder body.
    spindle.jpg .
    And the repro spindles you show that already have a notch, probably won't work either and still hit the wheel cylinder.
    I would have bushings made to use the old parts.
  12. gimpyshotrods
    gimpyshotrods
    Any machine shop that can survive in this economy should be able to make you bushings in a snap.
  13. Fordors
    Fordors
    Those are '39-'40 Lincoln backing plates IIRC and naturally they fit the Lincoln spindles you previously had, but I don’t think they will work with early Ford spindles, and for sure not with the ‘37-‘41 style you bought.
    ‘32-‘36 spindles do have the same bolt pattern but the thrust bearing goes on top of the spindle on those and there is no clearance at the backing plate for it. Even if they did work you would still need to modify a set of ‘32-‘36 king pins by cutting off the brake actuator cup from the top of the k/p’s and welding on a strong washer, like a 1/4” thick to support the front of the car. The span between the yokes on the Linc’ spindles places the thrust bearing under the axle, but the ’32-‘36 Ford spindles have it on top of the spindle.
    I wish there was better news but I think the deep recessed ‘39-‘40 Lincoln backing plates might require the Lincoln spindles.
    lumpy 63, X38 and Pist-n-Broke like this.
  14. If the Spindle you started with works with your backing plate and all that puts a Kink in the package is the King pin size, fix the king pin issue. Have under sized i.d. bushings made to fit the pin that works with the Axle or bore the Axle to work with the pin that fits the spindle. This is all a very standard Hot Rod Mix-n-Match process. You won't be the first guy to have done either of the two choices. I personally have done them both.
    The Wizzard
    clem and RMR&C like this.
  15. X38
    X38
    I thought as much. Thanks for verifying my suspicions.;)
  16. krylon32
    krylon32
    from Nebraska
    In my comment I was referring to the MT or Wilson Welding Lincoln style backing plates. They are a close match to the F250's and not the original Lincoln's
  17. X38
    X38
    Earlier Lincolns have a deeper recess which basically prohibits the use of any other spindles. Later ones have a shallow recess which is OK.
  18. The Lincoln axel has a different camber inclination that Ford, so re bushing the Lincoln spindles will allow you to fit the backing plates to the Ford spindles, but it will not work like you would like it too.
    If you bend the Ford axel to correct the camber to what you need it to be, it could work.
  19. gimpyshotrods
    gimpyshotrods
    Yup, and if I remember correctly, there are three possible backing plate offsets in the early Lincolns.
    I am pretty sure that even if the hub fits on the early Ford spindle, the drum is not going to line up.
    I would just have bushings made, and keep the current spindles and brake setup.
    Camber can be fixed at a truck alignment shop.
  20. tb33anda3rd
    tb33anda3rd
    could the backing plates be rotated slightly so they could be ground/notched?
  21. SMH
    SMH
    Thanks!! Not all good news but it is my options.
  22. SMH
    SMH
    Lots of knowledge here I really appreciate all the input.
  23. SMH
    SMH
  24. SMH
    SMH
    So what is a good economical drum brake set up to use if I decide to use these spindles?
  25. alchemy
    alchemy
    If that is a cast iron axle you cannot bend it to change the camber. It will break.
    Might need to use the new spindles with the new axle and make some spacers to put the Lincoln backing plates at the right depth to use with some 40's Ford ( not Lincoln) hubs and drums.
  26. SMH
    SMH
    Yea probably stay with the new spindles. What are the options for front brakes with the new spindles.
  27. F&J
    F&J
    Can you add some info?... I read that as there was another axle you replaced on the car?...or did you get the Lincoln plates and spindles during a new build?
    BTW;
    I only use all original Ford parts. My avatar 32 has a 35 axle I dropped, then it already had 40 brakes and spindles on that axle with mint drums, and it stops fine with the big Olds Rocket engine. 55 olds rear brakes.
    mad mikey and tb33anda3rd like this.
  28. SMH
    SMH
    The Lincoln wider axle and all the brake stuff was on it. I relocated the axle back 12” and bought a drop axle.
    This is what it did look like.
  29. SMH
    SMH
    I lowered the bed. Redoing the front end where the axle is not way out front. Repaint put new gas tank under a wood bed and some other mods.
  30. lumpy 63
    lumpy 63
    Easy and cheap + self energizing = 53-56 F100 brakes.
    SMH likes this.
