Projects You got to start somewhere!
Discussion in 'Traditional Hot Rods' started by Tooth, Nov 18, 2018.
  1. Yes
    41 vote(s)
    48.2%
  2. No
    20 vote(s)
    23.5%
  3. Other
    18 vote(s)
    21.2%
  4. 31
    19 vote(s)
    22.4%
  5. 32
    7 vote(s)
    8.2%
Multiple votes are allowed.
  1. Tooth
    Tooth
    from Missouri
    You got to start somewhere! Now to plan a build. I've always wanted a period correct Hot Rod! The research begins. Drove through a blizzard in Nebraska to fetch this one. 900 mile round trip all in one day...
    My only question is, is it a Cabriolet or 5 Window Coupe?
    Okie Pete, catdad49, Ric Dean and 6 others like this.
  2. HOTRODPRIMER
    HOTRODPRIMER
    Looks like a 1932 Chevy coupe. HRP
  3. 56don
    56don
    Why would you think it might be a cabriolet? A cabriolet is a convertible with roll up door windows.
    joel, HEMI32, upspirate and 3 others like this.
  4. Chappy444
    Chappy444
  5. saltflats
    saltflats
    from Missouri
    Coupe, and you better get your other projects done first. ;) :D
  6. shadetreerodder
    shadetreerodder
    WanatahHustler likes this.
  7. Mr48chev
    Well I'm with HRP, that isn't a Ford but it is a 5 window coupe. As the others said a Cabriolet has solid mount windshield, roll up windows and fold down top.
    This snagged off the net photo shows a 32 Chevy firewall on a pretty stock 32 Chevy 32 Chevy.JPG
    By looking at this the dash matches the 32 Chevy thing.. Hope you are real good at wood work. Photos got reversed when I added the dash photo. 32 Chevy dash.jpg 32 Chevy.JPG
  8. HOTRODPRIMER
    HOTRODPRIMER
    ct1932ford, HEMI32, kiwijeff and 2 others like this.
  9. Tooth
    Tooth
    from Missouri
    That's what I thought but a friend of mine notice the rumble seat and said he thought it might be a Cabriolet, I told him cabriolets had soft tops. Thanks
  10. Tooth
    Tooth
    from Missouri
  11. Tooth
    Tooth
    from Missouri
    I've got a lot of learning to do but this is the way I got it, and this is the way the guy I got it from got it, so not sure if the cowl is the one that originally came with it. Someday I hope mine will be as nice as yours! Thanks.
    wood remover likes this.
  12. Tooth
    Tooth
    from Missouri
  13. HOTRODPRIMER
    HOTRODPRIMER
    The firewall is correct for the body, it is a Chevy 5 window coupe. HRP
  14. Mr48chev
    Nothing wrong with having a traditional hot rod 32 Chevy coupe outside of they have a serous amount of wood. You don't have to listen to Ford guys ***** about your having a Chevy V8 in your 32 either lol.
  15. Tooth
    Tooth
    from Missouri
  16. Tooth
    Tooth
    from Missouri
    I'll make a note of that, DAD.
  17. HOTRODPRIMER
    HOTRODPRIMER
    I'm not a authority on Chevys so I am unsure if they built a Cabriolet, they did make a roadster. HRP
    Lil32 likes this.
  18. Tooth
    Tooth
    from Missouri
  19. Tooth
    Tooth
    from Missouri
    Could be a 32, I was told it was a 31 by the person I got it from. But I know the identification plate is by the p***enger side door seal next to the seat. And it's mounted on a wooden floor. Who knows where the tag is.
  20. Tooth
    Tooth
    from Missouri
  21. Tooth
    Tooth
    from Missouri
  22. Tooth
    Tooth
    from Missouri
    I guess I need to look up a 31 dash too see if there's a difference because it does look like this 32 - posted.
  23. Tooth
    Tooth
    from Missouri
  24. Tooth
    Tooth
    from Missouri
    Good point! I've certainly heard people say friends don't let friends Drive Fords! But I like all the hot rods!
  25. HOTRODPRIMER
    HOTRODPRIMER
    If it's a 31 and I suppose it could be the visor is missing, the firewalls for both years are almost identical. HRP
    thirtytwo likes this.
  26. Tooth
    Tooth
    from Missouri
  27. Tooth
    Tooth
    from Missouri
  28. Tooth
    Tooth
    from Missouri
    I have one of those!
  29. 28 Ford PU
    28 Ford PU
    from Upstate NY
    Put a 8BA Flathead in it and tell the Chevy guys “I thought it was a Ford when I brought it home”. [emoji23]
    catdad49, PugetDude, Randall and 4 others like this.
  30. Tooth
    Tooth
    from Missouri
