Technical Serial numbe/vin relocation?
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Nov 19, 2018.
  1. the vin tag on my van is welded to the steering column.
    Is it ok to remove and relocate it?
  2. squirrel
    Talk to a lawyer...not guys who fix cars.
  3. Students asked me that question and I didn’t have an answer
  4. partsdawg
    partsdawg
    from Minnesota
    Lot easier to see as opposed to being stamped on the frame.
    Why do you want to move it?
  5. Changing the steering column
  6. Luckily I live in Bama and this van is 60+ years old
  7. squirrel
    Have the students do some research into the state laws about tampering with vehicle numbers.
  8. I would ask your local DMV via email or Mail so you have a record
  9. Out of all the old junk I have built I have never had to remove one.
    I like the student research idea
    6inarow and chryslerfan55 like this.
  10. Jalopy Joker
    Jalopy Joker
    what year is it?
  11. 57 Chevy / Gerstenslager
  12. squirrel
    I have a 55 Chevy bread truck with the serial number on the column.
    Corvettes had the same thing from 53-62. Might look into the issues they have...
    chryslerfan55 and anthony myrick like this.
  13. Forgot about vettes. Thanks
    A friend of mine builds those
    I know a lot of those have columns changed so normal sized people can drive em
  14. F&J
    F&J
    tag removal/or relocation is not legal in my state of CT, except if the DMV officer does it for reasons such as if replacing a rotted truck cab being replaced with a donor cab that must also has legal paperwork. In those cases, a State Issued number is put on the cab by that Officer, not the old tag. Each State must have their own Statutes on such things.
    If it were me, I'd re-use that part of the original column, even shortened, or modified as needed, but not removing the tag itself....but I am not a you. Checking in person, with your own DMV officials is the best way IMO
  15. RmK57
    RmK57
    The way I understand is your not supposed to use a vin plate to register a vehicle. Lots do and get away with it but a serial number on the frame is what my dmv wanted to see.
    I know on 60's and later fords the door plate or sticker even says ' not for ***le or registration'.
    I ran into all sorts of problems with this when the door on my 65 Falcon was replaced.
  16. squirrel
    There are lots of different types of VIN or serial number stamps or tags on different vehicles. There are 50 different states in the US, each with it's own laws and regulations. It's not likely that many of us will know the details of what you can and cannot do on every type of vehicle, in every state.
    The 57 chevy truck should have a partial serial number stamped on the frame, near the steering box. It would be missing the first two characters, which tell what model vehicle it is (not a big deal, since you can tell just by looking at the frame what model it is).
  17. I may be able to use the tube from the steering column
    When I had my bus tagged, the officer looked at the tag on the glove box lid and made sure it matched the paper work. That was super easy. I want the van to be the same way
  18. Yep it’s there and students have been told to stay away from it
    I clipped my bus but saved the frame section with the vin in case there were any issues
  19. topher5150
    topher5150
    what if you don't have a VIN on the car
  20. lonejacklarry
    lonejacklarry
    Nowhere? In Missouri you would now own a big lawn ornament.
  21. s55mercury66
    s55mercury66
    from SW Wyoming
    Here in the US, that is considered the warranty plate, and that number on that plate does not neccessarily have to match the VIN, or in older cases, the serial number, even though all the ones I have looked at do. Those plates call that number the "Warranty Number".
