Hot Rods Building mistakes you won't repeat
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Nov 11, 2018.
  1. jbarker
    jbarker
    Learned it's sometimes better to pay someone else to do the work. I learned real fast I don't have the patience or skill for sheetmetal work involving anything past a stud welder.
    Getting impatient and half ***ing and going cheap on stuff just to get a car finished. I'm still dealing with that on my 87 turbo buick.
    It's cheaper to buy finished and then gut it to make it your own.
    Don't leave a rag in the engine. They don't care for that.
    Double check the marks on timing chains. Yup, chased my tail for over a year because of this.
    Don't tear down an engine before you find out exactly what's wrong with it. It's hard to fix what isn't broke.
    Using worm clamps on turbocharger piping isn't the best idea.
  2. greaser
    greaser
    I will never take a running car and blow it ALL apart, thinking that the needed changes wont take too long,,,, YA, RIGHT! Better to keep it running, and make changes systematically, one upgrade at a time.
    Saxman, leadfoot1000 and nightmoves like this.
  3. PHIL COOPY
    PHIL COOPY
    The next time I do a tall T I'm going to shop around for a better body. I'm 79 and wonder if I'll outlive the body work.
    Phil
    Fordor Ron, Rich B. and nunattax like this.
  4. LOU WELLS
    LOU WELLS
    from IDAHO
    Flames On A Deep Water Blue Sedan Delivery That Never Should Have Had Any...ETC... 26231528_1958553994468872_1433347531996413577_n (1).jpg
    jnaki likes this.
  5. Mike Miller
    Mike Miller
    Not keeping notes and do***enting a build. A mistake that's bighting me in the *** as I type this.
  6. Fuel to burn
    Fuel to burn
    Had the radiator out of an Oldsmobile, tried to move it into the garage, automatic transmission, ATF everywhere.
    Bought a T-Bird that had sat a long time, tried to start it without thorough inspection, valves stuck bent pushrods.
    Ralphies54 likes this.
  7. hotrodA
    hotrodA
    Letting your (now ex) wife and friends talk you in to a paint color.
  8. oldsfrench
    oldsfrench
    from France
    i was 18 yo , trying to fix a carb issue on my 1965 Renault 8...
    it was dark in the parent's garage , use a lighter to see what's wrong in the carb....
    booooommmm ...
  9. Gabby
    Gabby
    I know real hot rods don't have radios. However, never buy a radio for a car that is unfinished. It will be an antique before the car is built. Anyone want a signal seek c***ette / AM-FM radio, new in the box.
  10. Gabby
    Gabby
  11. nunattax
    nunattax
    bollox a radio is company on a long journey,weather updates traffic updates ferry updates.accident updates.radios are for people who travel long distances.no radio in your car probably never go far anyway.you can allways turn it off and listen to the motor
  12. nightmoves
    nightmoves
    With cellphones readily available, photograph Everything. Sometimes, I take longer than I should putting things back together...and tend to forget.
    Sent from my SM-G930V using The H.A.M.B. mobile app
  13. Rodders
    Rodders
    Yep following trends and rushing. I am not doing ether of that on my build now. All that matters is that I like it.
    nunattax likes this.
  14. rusty rocket
    rusty rocket
    Ha ha! I,m sorry!
  15. Yep. One of my biggest mistakes was loaning several uncommon tools on a Stude car club "tool loan ring" and never getting any of them back.
    ...Where they either quietly vanish or the borrower suddenly picks a fight for some goofy reason and conveniently feels "justified" in stealing my parts and tools.
    Never again have I loaned anything out trying to be a nice guy, only to be called a villain for the sake of free stolen parts.
    More than a few.
    WHY BE ORDINARY ?
  16. Dangerous47
    Dangerous47
    10 years ago I decided I wanted a "smooth firewall". Honestly one of the biggest regrets of any car I have built was welding up this poor firewall in my adolescence..
    Sent from my SM-N960W using The H.A.M.B. mobile app
    slim39 likes this.
  17. Chappy444
    Chappy444
    Not paying to have work done when I should have
    Paying to have work done when I shouldn't have
    And somehow still not learning when to know the difference
    Chappy
  18. HSF
    HSF
    from Lodi CA
    Been said a few times on this thread. Buying someone elses project and tearing apart perfectly good running and driving cars to never finish them.
  19. paintman27
    paintman27
    from new jersey
    Don't know which one was worse.............
    Welding in my front cross member 1 1/2" to far forward
    or
    painting POR15 without gloves.......................
  20. 41rodderz
    41rodderz
    from Oregon
    Here is my past mistake that I only let happened once:oops:. I was 16 at the time. I had '68 Pontiac with a 327 . Using oil and smoking like a campfire. Middle of winter in a barn and no heat. Guy in town had a '64 283 4 barrel engine with 60,000. Pulled the 327 , dropped the 283 in got engine fired up and took off for a quick test. 1/2 mile down the road. Hissing like a snake. Checked over , water coolant leak. Drove back to barn. Freeze plug let go. Of course right behind the engine mount:eek:
    VANDENPLAS and mad mikey like this.
  21. 41rodderz
    41rodderz
    from Oregon
    Second mistake later in life was dealing with bullchit artists. Life lessons in avoiding them like the plague. Now tell them to their face to go rub salt.
  22. hot-rod 33
    hot-rod 33
    not checking the rear axle fluid
  23. mrbeetle
    mrbeetle
    Not listening to those with more experience. Thanks for sharing fellas!
    WB69 and VANDENPLAS like this.
  24. Big Mistake - letting a build stall out, then selling off the parts instead of taking a break then restarting later.
    I wish I could restart an old project, but the parts have been sold. :(
    WHY BE ORDINARY ?
    VANDENPLAS likes this.
  25. Wire wheels, had them on a 53 Buick Skylark and on Ford roadsters, they bend and don't balance very well. Bad deal wheels.
  26. deathrowdave
    deathrowdave
    from NKy
    Trusting you have the foot clutch adjusted correctly on a hand jammer . One time and never again sit at a traffic light with a manual shift in gear ( car , truck , bike ) , clutch disengaged .
    trollst likes this.
  27. jnaki
    jnaki
    Hello,
    In looking back 59 years, one big mistake from our 40 Willys C/Gas coupe build that definitely would not be repeated in the next version was a B&M or C&O Stick Hydro instead of our LaSalle 3 speed floor shift transmission. At the time, our budget called for a heavy duty clutch, a very inexpensive LaSalle 3 speed transmission, and a two piece ****tershield. Our hopes were for the new stick hydro transmissions for our 40 Willys 671 SBC C/Gas Coupe. But, as time and money always play a part of a direction in any build, we settled for getting the 40 Willys up and running. We would save more money for the later purchase and conversion of the stick hydro installation.
    As budding hot rod/drag racers doing their first backyard build, we did not think anything of using that 3 speed transmission and clutch set up. We even bought a heavy duty, custom built, clutch from a highly reputable (other drag racers used this shop) clutch shop for our new clutch installation. A national sanctioned body approved ****tershield was purchased as a means of safety and protection as required by the rules.
    Once that 671 SBC fired up, all thoughts of replacing that 3 speed with a stick hydro went out of the window. The first drive down our neighborhood street and shifting into the upper gears made all other thoughts and ideas get placed on the back burner.
    It was thrilling at what we had done so far. It was something that we did together for the first time and the results were pretty good for a couple of teenagers. And that sound...wow, this was what a street driven race car should be...fast and loud. Our 348/280 hp Impala was impressive upon acceleration, but this 671 SBC in the Willys Coupe was the best...!!!
    Jnaki
    As anyone can do, thinking back to that moment in time, the cost of a stick hydro would have emptied our collective bank accounts. The Willys ran well, got close to the national record for our cl*** and the sound was outstanding! We were extremely happy with the current build status/results of the 1940 Willys 671 SBC coupe, until August, 1960.
    classiccarjack and Tudor like this.
  28. patterg2003
    patterg2003
    Buying a car with a misty eyed view that needs a lot of work before it can be driven. Having an old ride to drive while working on the other car may be my short term answer to driving something of age. Then sell the first car when the 2nd is a driver.
  29. Corsa
    Corsa
    My big mistake was listening to older builders who are more experienced and more skilled than I but who I later realize only know 80's and 90's Streetrods. Getting talked out of building the car I want because they think it's not how you build a safe, "proper" car. You know what I mean. Boxed frames, SBC, open driveline, t5, vega box, 4 link, coil overs, loads of catalog parts, etc etc. I worked hard on the car I was convinced to build to a point then I realized it wasn't the car I had ever wanted and I hated everything about it.
    I took a complete year off and ditched the near complete ch***is I'd built to that point. I grabbed another mint frame I had then came back to the project with a determination to built the car I always wanted. A completely traditional car with original period correct parts I'd been collecting from swap meets and cl***ifieds for years. The cars I loved from the early 50's magazines.
    Build the car you want whatever it is and don't let anyone convince you otherwise.
  30. Ralphies54
    Ralphies54
    Big mistake here was giving away a long time ago 3 SBC and 1 239 OHV ford engines in need of major rebuilds to fellow club members who expressed a desire for future projects of theirs, only to find out years later they sold the engines rather than p*** them on to some other needy rodders. I realize once you give something away they are free to do whatever but !!!!
    No more Mister nice guy. Ralphie
