Technical Removing Valve Covers Big Block Chevy
Discussion in 'Traditional Hot Rods' started by zz29, Nov 20, 2018.
  1. general gow
    general gow
    MODERATOR
    Did you buy that car from Russ?
  2. zz29
    zz29
    Yeah, someone or somewhere I read to not tighten the nuts much at all. The ones on it right now are barely snug.
  3. zz29
    zz29
    Yeah, the bolts I think have the star shaped hole to remove. I think removing them would be good before trying to pry the covers off. Lots of good tips, thank you.
  4. zz29
    zz29
    Blues4U likes this.
  5. big duece
    big duece
    from kansas
    I think using more of that existing color is going to start taking away from the traditional coolness that's going on now. Everything is cool as hell, but the frame color. But to each their own. A dark silver or charcoal in the ribs of the valve covers would be a nice complement to the rest of the bare metal build. Love seeing the bbc in between those narrow (cool) hood sides.
    swade41 likes this.
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    I'm surprised that no one mentioned that those covers could have been put on with silicone or " right stuff" without gaskets , either of which would make them a ****** to get off
  7. squirrel
    that's not a good sign....
    chiro, OahuEli, impala4speed and 6 others like this.
  8. zz29
    zz29
    Hmmmmm. So painting the covers is like making it fancy? I think my father in law (whom we inherited this car from) was going for a all metal, boneville racer look a bit. The interior is all aluminum, unpainted. Bomber seats are exposed with some cushions. Cushions **** so we’re getting nicer ones made but still show off the metal work of the seats. You got me thinking. I like the idea of a darker silver just as an accent. Hmmm.
    swade41 likes this.
  9. zz29
    zz29
    Ha ha!!! Totally. Got me there.
  10. zz29
    zz29
    I’m his son in law. I sent you a detailed direct message about it.
  11. timfarn
    timfarn
    Love the BBC in that machine!
    zz29 likes this.
  12. zz29
    zz29
    It barely fits.
  13. big duece
    big duece
    from kansas
    That is such a no nonsense T tub, I would leave the valve covers alone and change the frame color to red oxide primer. I really like it...
  14. big duece
    big duece
    from kansas
    Or paint it orange like my all time favorite 1/8 model kit... s-l1600 (7).jpg
    Deuces, zz29 and blowby like this.
  15. JOECOOL
    JOECOOL
    They look fine the way they are ,just my opinion.
  16. zz29
    zz29
    Gaskets are intact on the covers. They must be recent. I’m thinking I won’t even remove/replace. No cracks. I’ll clean.
    [​IMG][​IMG]
  17. Deuces
    Deuces
    Got one in my stash.... :)
  18. zz29
    zz29
    [​IMG][​IMG][​IMG][​IMG]
    Finished the job and put the covers on today. Cleaned the head and the cover gasket really well. Tapped covers in. Put bolts back in and tightened nuts in a cross pattern for fun. Snug but not tight. Ran the car for a minute and no obvious leaks. Thanks for the help.
    Blues4U and Larry T like this.
  19. squirrel
    You did a good job...how do you like the look, now?
    zz29 likes this.
  20. Ebbsspeed
    Ebbsspeed
    @zz29 Looks like you did a nice job on the paint. Did you mask off the fins and lettering, or paint it all and then remove paint from the Edelbrock logo and top of the fins?
    Did you ever get the supercharged flathead car figured out?
  21. Roothawg
    Roothawg
    I will never buy a cork gasket again. I love the FelPro one piece oil pan gaskets and the rubber valve cover gaskets with the steel insert. No more leaks and they are reusable. Not sure why you would use anything else honestly. I know I’m a little late to the party.....that’s the way I roll.
    Montana1 likes this.
  22. squirrel
    Leaks are traditional....and they give you something to do, fixing them on a quiet Saturday afternoon.
  23. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Good job on the valve covers and very good job on asking your questions. That's how you learn the right way. A lot of guys won't ask what they consider to be 'stupid' questions. Instead, they show up asking how to fix the mess they created by doing everything wrong.
    Keep going!
    Sent from my SM-G960U using The H.A.M.B. mobile app
    OahuEli, waxhead and Jim Bouchard like this.
  24. Roothawg
    Roothawg
    That they are. My driveway can attest to that.
    Max Gearhead likes this.
  25. Mike Colemire
    Mike Colemire
    I like the rubber and steel but only if you have a machined flat surface on the bottom of your valve cover. I put a set on a stamped steel set and they leaked, had to go to cork.
  26. squirrel
    They rubber/steel gaskets work with some stamped valve covers...they came on the LS-7 I bought in 1989, and they're still working after almost 30 years, no leaks.
  27. Truck64
    Truck64
    from Ioway
    Cork gaskets don't leak, and are reusable indefinitely, I don't know why cork gaskets get a bad rap.
  28. zz29
    zz29
    I do t know. I’m torn. Part of me likes the s****py all grey look; part of me likes the more colorful look. Talking to my brother in law who was working for my father in law at the time of the build, the car was never totally finished. The silver color is zinc primer. I don’t think we’ll ever paint the car. It looks sharp and I look at it as an evolution.
  29. zz29
    zz29
    I masked it all off, used cherry lip balm on the letters. Pain to do. The wiping might’ve been easier but seemed too risky.
    The supercharged is still at the mechanics and they haven’t had a chance to really look into it. They think it might be the newly rebuilt distributor misfiring. Their plan is put in another distributor and if that takes care of it, I’ll send the distributor back to Bubba for a check up.
  30. Your valve cover job came out excellent. You're learning fast. I remember the first time I removed a pair from a 53 DeSoto Hemi I owned. I was petrified. Had no clue what I was getting into. There was no HAMB back then to guide me through my questions.
    zz29 likes this.
