Projects Just Another Model A Build
Discussion in 'Traditional Hot Rods' started by Konan1184, Nov 23, 2018.
  1. Rehpotsirhcj
    Rehpotsirhcj
  2. Konan1184
    Konan1184
    Rehpotsirhcj-That's exactly what I need! If you could let me know where to find those panels I would be forever in debt to you!!!
  3. The37Kid
    The37Kid
    Nice project, looking forward to following the updates. I collected 80% of the parts to build a 1937 Harley just like the one my Dad bought new, good to see you building something like your Dad would have built. Bob
  4. Konan1184
    Konan1184
    Thank you, Bob. That's really cool that you built a bike like your Dad's. I would love to see that bike. My Dad was also a biker and my brother still has his Harley that the Old Man adored. In a way it's like they live on through the cars and bikes that they loved!
    winduptoy and bct like this.
  5. supernut
    supernut
    F6AF0781-A125-433D-A7AD-A531477EF510.jpeg 22DB1E62-F748-4C67-9160-97F699EB6DC1.jpeg 532F4978-51F8-467F-8874-DACCF3E4B420.jpeg F6AF0781-A125-433D-A7AD-A531477EF510.jpeg Here’s a picture of a firewall I just flipped it’s a lot of work
  6. Konan1184
    Konan1184
    Thanks for the photos. That's exactly what I would like to do.
  7. Konan1184
    Konan1184
    Did you clean all that steal with a media blaster or did you use a grinder?
  8. Konan1184
    Konan1184
    Also, how much of the front side of the gas tank did you have to remove?
  9. supernut
    supernut
    EB8A5F7E-F2D1-4069-B998-F15BEA92A3D1.jpeg I removed 4 inches of the gas tank , I used a 36 grit 4 inch disk to remove some of the paint and to clean the the welds. Took a phishing hammer to help straighten out . Still not perfect but it will do as I’m putting a hood on this coupe. I used air craft paint stripper on the rest of the car.
  10. supernut
    supernut
    I love the look of it reversed and not having to worry about the distributor being so close and not being able to run a mechanical fan. I ll cut the tunnel in it will I fit the body to the frame.
  11. Konan1184
    Konan1184
    Great info. I think I want to attempt that as well. I want to run an HEI distributor and that distributor is about as big as they come so Ill need the room.
  12. Konan1184
    Konan1184
    Totally unrelated but saw this this awesome 57 ford pickup.
    Nicholas Coe likes this.
  13. Konan1184
    Konan1184
    This is the shop truck at SDHQ in Chandler:)
  14. The37Kid
    The37Kid
    Very nicely done, and I did notice you took the time the cut out the center and keep the bead work facing forward, nice work. Bob
  15. Konan1184
    Konan1184
  16. AHotRod
    AHotRod
    Hot Rods RULE !!!
    If you need any bad ideas, let me know ;)
  17. sloppy jalopies
    sloppy jalopies
    mikie likes it... after seeing your's I am gonna reverse the firewall in my '30 coupester project...
    I may not re-reverse the beadwork... I can live with them being innies…
    that is my '30 sleeping in the back... and a rrrrrrrrrr snowblower in front...
  18. Rehpotsirhcj
    Rehpotsirhcj
    Okay, for the life of me I can't find the thread showing a belt line repair. Maybe someone will post a link if they run across it.
    I found the patch again on Snyder's site here:
    https://www.snydersantiqueauto.com/belt-line-patch
    It's not exactly plug and play but better than nothing. I also considered scabbing the bead from a rear sedan door. Can't give them away and the bead looks to be the same.
    -Chris
  19. sloppy jalopies
    sloppy jalopies
    I bought some of those beltline strips... they are not crisp enough... the beads are rolled not stamped...
    larger bead was way too shallow... but... better than nothing at all.
    Rehpotsirhcj and shadetreerodder like this.
  20. classiccarjack
    classiccarjack
    This happened to me, don't worry, save it with loc-n-stich.
    I just got it bored, and somehow overlooked it. The machinist missed it also.... But after the repair, 8 years later, it's still good!
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
    Calcraft likes this.
  21. Konan1184
    Konan1184
    Nailhead coming together
    Aaron D. likes this.
