Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Working on rust removal on the bumpers of the '50 and trying to repair the drivers door latch. HRP
    Early Ironman likes this.
  2. classiccarjack
    classiccarjack
    Dude you're an animal!!!! That's bad***!
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
    Pinstriper40 likes this.
  3. classiccarjack
    classiccarjack
  4. classiccarjack
    classiccarjack
  5. classiccarjack
    classiccarjack
  6. classiccarjack
    classiccarjack
  7. classiccarjack
    classiccarjack
    It takes another Veteran to know where you are coming from... And truly understand how it feels.
  8. classiccarjack
    classiccarjack
    I put new Bearings in an Dana 70 and installed a Injection pump on a 5.9L 12 Valve ***mins...
  9. Hombre
    Hombre
    Got the old hot Water six out of my 53 Ford and building a roll around stand for the damn thing so that I can get it out of the way. Any one need one of these six's give me a shout will be glad to see it go to a good home. FREE too by the way...
  10. patzfab
    patzfab
    from Canada
    5A97F283-61ED-4CDB-80E2-7C79442754C9.jpeg 35C31A27-FDDC-46F4-BCA9-57668B39091B.jpeg 64E3F33C-397F-4283-866F-EDB17419B90D.jpeg 5B913C0C-D62B-4066-A89B-A25E41B3AC67.jpeg Put some new studs into a couple of 34 Roadster top wing nuts. From NF to NC The fancy chrome one is a repro. The builder likes the patina ones.
    RICH B, UNSHINED 2, bobss396 and 2 others like this.
  11. scotts52
    scotts52
    1464931585462.jpg 1464931565289.jpg Finished unearthing this from it's grave. I may actually collect parts and try to build it. I love odd rods. I believe it to be a 22 Dodge. IMG_20181119_140519067.jpg IMG_20181119_140456083.jpg
    Old wolf, UNSHINED 2, 34 GAZ and 4 others like this.
  12. lumpy 63
    lumpy 63
    Finally tore down the 409 today. Been in storage since the early 80s. Was bought as a crate motor in 62 and installed in a 60 Biscayne. All date matching , appears to have never been apart , standard GM bearings etc. Even had the dual steel shim head gaskets in place. Factory Hi Po heads and all. Very pristine engine ,still had cross hatch in the bores . Good day in my book:cool:
  13. DesertRat#1
    DesertRat#1
    I need a rolling welding table so I can move the welding process outside when needed. The last couple days I build one and tomorrow starts the painting process. When complete I will post a couple photos of the process. I an tooling up to start my 40 build but need to make sure all the tooling is ready first. There will be a couple more before I bring the frame in to start the rolling ch***is build.
    The37Kid likes this.
  14. NWRustyJunk
    NWRustyJunk
    I put disc brakes on my 40 Chevy and the reupholstered front seat in my OT Polara.
  15. gimpyshotrods
    gimpyshotrods
    Cut-and-pasted a rear seat base, to clear a taller, wider driveshaft tunnel, without disturbing the plane of the seating surface, although I wouldn't try sitting in the middle.
  16. zz29
    zz29
    Yesterday I removed the valve covers of the 27 Phaeton and masked them and put 2 coats of primer. Took forever to mask.
    UNSHINED 2 and swade41 like this.
  17. zz29
    zz29
    Simple stuff hu?
    gimpyshotrods likes this.
  18. bobss396
    bobss396
    Woke up my '59 Ford early this morning to go out and get a new battery for my 2012 Malibu that took a dump last night.
  19. Early Ironman
    Early Ironman
    I just mask the sides, prime everything, use a medium stiffness block sanding block wrapped in a rag with a little thinner and wipe one direction until the primer is clear of the fin tips. Repeat after you apply the topcoat.
    Hamtown Al, clem and saltflats like this.
  20. Got another student set up with an interview at a shop
    vtx1800, lumpy 63, swade41 and 3 others like this.
  21. ct1932ford
    ct1932ford
    swade41 and chevy57dude like this.
  22. The37Kid
    The37Kid
    Nice! Will you block that and buff it yourself or farm it out?
    grumpy32, stillrunners and j hansen like this.
  23. zz29
    zz29
    Put these recently painted covers on. And went to my wife’s PHD dissertation defense!
    UNSHINED 2, swade41 and Early Ironman like this.
  24. $um Fun
    $um Fun
    from Nor Cal
    I am jealous,I did nothing productive. Its raining cats and dogs here and hard to get motivated.
  25. junkyardjeff
    junkyardjeff
    Got the sunliner on stands hoping the trans issue was just a modulator/va***n issue but its toast forward clutches.
  26. lumpy 63
    lumpy 63
    Broke in a 403 olds on the run stand, And Took my daily driver 56 PU to a local park for a photographer to shoot Christmas card Pics . Had a blast watching the kids jump around in the bed and stand on the stepsides getting their pictures taken, the photographer set up sleds and a small Christmas tree in the back with presents. Good day in my book.:D By the way, not my kids ,think she must have shot 30 different families .Fun to watch all the youngsters enjoy the truck.
  27. whtbaron
    whtbaron
    from manitoba
    grumpy32 and Lil32 like this.
  28. brokedownbiker
    brokedownbiker
    Spent half the day working on my step-son's OT truck and the other half getting stuff moved into my newly enclosed shop. I'm one roll-up door and a heater away from being able to start wiring my '51 shoebox.
    swade41 likes this.
  29. seb fontana
    seb fontana
    from ct
    Put new big bearing ends on a 9" housing..Haven't heli arced that much in a looonng time..
  30. swade41
    swade41
    from Buffalo,NY
    Got my beam up and the walls out and more of the flooring up, getting closer to sliding the Henry J jn this space for warmer working. 20181202_160656.jpg 20181202_160340.jpg
    WB69, classiccarjack and UNSHINED 2 like this.
