Hot Rods Cadillac Engines, post a pic of your 331,365, 390.
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Nov 26, 2018.
Tags:
  1. Roothawg
    Roothawg
    I am always wanting to see pics of other guys Caddy power plants. So post away!! Mine is in pieces, so it's not really worthy.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
  3. Moriarity
    Moriarity
    SUPER MODERATOR
  4. Hank37
    Hank37
    My Caddy , ain' IMG_2215.JPG t pretty but she's fast !
  5. bonesy
    bonesy
  6. fiftyv8
    fiftyv8
    from CO & WA
    Still deciding on a future for my 365.
    I just got it mounted in an engine running stand so I hope to hear it run soon.
    They sure are a wide motor across the shoulders...
  7. pkhammer
    pkhammer
  8. Roothawg
    Roothawg
    Keep em coming!!
    loudbang and Deuces like this.
  9. Blake 27
    Blake 27
    Not mine but I've always liked Caddys!
    My first exposure was around 1956, my cousins friend had a 53 Stude with a Caddy motor. A rubber burning son of a gun! DSC01102-001.JPG DSC01837.JPG DSC07243.JPG DSC08096.JPG IMG_4369.JPG
  10. Interesting headers on the triple offyed intake engine.The one with the red leads.
    A lot of work gone into the mounting flange bolt areas,look like s/steel also
  11. seabeecmc
    seabeecmc
  12. Roothawg
    Roothawg
    Nice. Any better pics of your pcv setup?
    1morecarIpromise! and loudbang like this.
  13. paintman27
    paintman27
    from new jersey
  14. fiftyv8
    fiftyv8
    from CO & WA
    From what you have shown, it looks to be a good deal.
  15. fiftyv8
    fiftyv8
    from CO & WA
    What is the preferred fuel pump to use on these engines???
    I think mine is a 1957.
  16. loudbang and Roothawg like this.
  17. Deuces
    Deuces
    Very cool pictures guys!!!:)
    I love this early morning eye candy..... o_O:D
  18. 24C8A971-B9B4-483B-A236-A538BE5472D3.jpeg FA41BA41-56BB-4896-87F9-6CF0C6A38F39.jpeg 57 365,A long way to go yet,
  19. pkhammer
    pkhammer
    I have been advised that rebuild parts for these engines is hard to find and expensive. I agree with the expensive part but it looks like Kanter, Egge, and even sources on ebay (Falcon) have basic. master, and deluxe overhaul kits kits available. Have any of you Caddy guys had trouble getting parts such as pistons, rings, valves, guides, etc.?
  20. Roothawg
    Roothawg
    The pistons are pretty much ****, but most of the gasket sets are decent. I have talked to a lot of the piston mfg and they are happy to build a set of custom forged aluminum slugs. The price tag is around $800-1000.
    Isky, Howards, Comp and Steve Long still grinds cams for them. Just make sure the cores are available. Apparently there is one supplier of Cadillac cam cores.
    Here's a thread I started that has a lot of other threads covering Caddys imbedded.
    https://www.jalopyjournal.com/forum/threads/lets-talk-cadillac-331s-365-and-390s.1015067/
    loudbang, Deuces and bonesy like this.
  21. Hank37
    Hank37
    Piston rings on a 4.000 caddy are the same as 4.000 327 chevy . Chevy valves can be machined to fit in caddy , worn valve guides can be knurled to specs. I used 327 vette solid lifters in my caddy with Smith adjustable push rods .
    rod1, ls1yj, loudbang and 1 other person like this.
  22. Bleach
    Bleach
    Here was my original 331 at home in the 51 Cadillac that the factory installed it in.
  23. HOLLYWOOD41
    HOLLYWOOD41
    Nice to see all the weight being put to good use.
    Mine is a throw back with Isky roller, Jahns, Mallory Magspark, early shinny stuff with the exception of the O'Brian filter cover. T-5 makes long trips fun at 22mpg.[ Caddy in 37.JPG P1010032.JPG Cab at Ty-Rods front.jpg
  24. Roothawg
    Roothawg
    Looks like it was made for it.... :)
    loudbang, Bleach and Deuces like this.
  25. Roothawg
    Roothawg
    Whose ****** adapter did you use?
    outlawracer and loudbang like this.
  26. birdog
    birdog
    from Monroe, UT
    Here is one I built a few years ago! 4DAE81D7-6F90-497F-9A00-8FD1F7581EE9.jpeg
  27. Hubnut
    Hubnut
  28. HOLLYWOOD41
    HOLLYWOOD41
    To answer Roothaug, I used an adapter from Bentsen Transission Center, Ham Lake, MN 55304. 1-763-767-4480. Comes with hi torque starter. Also used a GM truck bellhousing with the throwout arm on the p***enger side with a hydraulic slave cylinder so I could use the stock 1940 or so brake pedal ***y. Bellhousing 15562385, clutch slave 15616089, fork 12385352, TO bearing 15613306
  29. seabeecmc
    seabeecmc
    This should be enough to figure it out. Ron
  30. Roothawg
    Roothawg
    ls1yj and loudbang like this.
