Projects An Amateur Chops a Brookville Coupe & More
Discussion in 'The Hokey Ass Message Board' started by Bcap55, Nov 26, 2018.
  1. Bcap55
    Bcap55
    from PA, USA
    We've all been watching Flop's threads on how a master metalworker chops a 32 three window coupe, this thread will show how an amateur learns how to chop a top for the first time. I've always liked the looks of a chopped 32 Ford coupe. Thanks to people like Flop and others on the HAMB and the internet, I was able to gather enough information to feel confident that I could get it done. I found this site http://rideinsteel.com/update1.html that shows how they chopped a Brookville coupe. I used this as my guide. Let's get started.
    New coupe body, hot off the presses from Brookville
    This is going to be a 2 1/2" chop which is conservative, but it will be easier for me to put everything back together and lined up. Also here in Pennsylvania they allow a minimum of 7" windshield height, and this will give me about 7 1/4". I'll be stretching the roof to line the A pillars up rather than leaning the posts.
    Here are the cut lines for the rear window. I measured carefully and found where the horizontal dimension of the window opening at the upper and lower cuts would match.
    This is the outer skin piece that will be removed from the A pillar to give access to the inner structure to be cut. This was bigger than the 2 1/2" needed for the chop. With the larger piece removed I will be able to fully weld the inner structure after cutting.
    Here is the the sale panel area that will be removed and reinstalled after the top is chopped.
    Well that's a start, I'll be cutting some metal next starting with the rear window chop.
    I'll post more photos tomorrow. Stay tuned.
    harpo1313, nunattax, clem and 19 others like this.
  2. indyjps
    indyjps
    Hold my beer and watch this.
    Just foolin, looks like you got a plan, Ive never done one, post as much detail as you can
  3. Rickybop
    Rickybop
    I'll likely never have the chance to use the knowledge...at least on a '32 specifically...but I think I wanna watch this real close anyway. Looking forward to it.
    indyjps and loudbang like this.
  4. brokedownbiker
    brokedownbiker
    +1 on what Rickybop said. I've always been interested in chops and how/where the cuts are made; half the time I can't figure why some cuts are done like they are but I learn a little more each time.
    loudbang and Texas Webb like this.
  5. captain scarlet
    captain scarlet
    from Detroit
    Glued to this one :)
  6. choptop40
    choptop40
    That's not a chop....that's a scalping.....gonna be sweet
  7. krylon32
    krylon32
    from Nebraska
    Check out waldenspeedshop.com He's on part 16 of how to chop a top on a 3 window coupe. While much of what he's showing does not apply to your chop I think you will still find it interesting.
  8. continentaljohn
    continentaljohn
    More then one way to skin a cat always great to see new ideas
  9. DDDenny
    I'll hold the pucker while you cut!
    -Brent-, winduptoy and Budget36 like this.
  10. Hemi Joel
    Hemi Joel
    from Minnesota
    I'm for sure watching this! Good luck with it.
  11. loudbang
    Looks like you are going at your first chop in a first rate manner. :rolleyes:
    Dino 64 and brady1929 like this.
  12. watching intensely , with beer in hand .
    Vic
  13. brady1929
    brady1929
    Good luck. Looking forward to this.
  14. rd martin
    rd martin
    from indiana
    You hold my beer! And you put this cork in my ***!!! Good luck with it, it's only metal.
    scotty t likes this.
  15. jaw22w
    jaw22w
    from Indiana
    If that was me, never having done a chop, when I started cutting into that beautiful $20K Brookville body, my ***hole would be so tight you couldn't drive a red hot spike in it.
  16. Happydaze
    Happydaze
    Tagging along here!
    Chris
  17. Bcap55
    Bcap55
    from PA, USA
    Before I get started with more progress pictures I got to let everyone know that I finished the chop earlier this year. What I'm showing is a condensed version of a 10 month project. I'll be posting a lot of photos and showing details that needed to be addressed to get to an acceptable finish. There is to much to put into one nights post, so I will be updating with more progress pics every night for the rest of this week.
    Thanks for the link to the Walden videos Krylon, I don't think the videos were available back when I was working on my car. I'll still watch them and probably see things that would have helped.
    Ok more progress pics.
    I started with the rear window chop. I cut the spot welds holding the rear center section to the sail panels. I cut the window opening at the lower line. It was easier to cut the upper line with the piece off the car.
    The time to take good measurements and proper planning paid off. The window opening lined up perfectly. Very little metal work was needed to true up the body lines. I clamped the pieces in place and tacked them together. I won't fully weld anything until most of the top is fit and tacked and looking good.
    Here is the sail panel area cut out. No turning back now.
    continentaljohn, hfh, brEad and 9 others like this.
  18. brigrat
    brigrat
    from Wa.St.
    If your gunna cut one cut a nice one!
    kidcampbell71 and loudbang like this.
  19. Bcap55
    Bcap55
    from PA, USA
    That's exactly how I felt when I started this project. I would go out to the shop and circle the car like a shark with a die grinder and cutoff wheel for weeks until I got up the nerve to finally make the first cut. After the rear window fit so nice I stopped being nervous and just moved ahead one step at a time.
  20. brigrat
    brigrat
    from Wa.St.
    I sold a beautiful '36 3/W just because I wanted it chopped and didn't have the heart or "your size balls" to do it. Get her done before your balls shrivel up.........................................
  21. BigO
    BigO
    Nice work. I chopped a chopped coupe once.... Just saying.
  22. mickeyc
    mickeyc
    It appears you have a well lit and nicely appointed shop to
    work in. I would think that would instill a good degree of
    confidence as well. The chop looks well planned and executed
    to the point shown. Good job!
    BigO, kidcampbell71 and loudbang like this.
  23. Rickybop
    Rickybop
    The chop is already done?
    You mean...no more sitting on the edge of our seats?
    No more puckered sphincters?
    Still cool. Still watching.
  24. HotRod-1
    HotRod-1
    Trying to find the courage to do the same to my Brookville. Nice planning, nice cuts. Looks professional to me.
  25. j hansen
    j hansen
    Drinking beer and watching intensely,,,,subscribed. Skärmavbild 2018-11-28 kl. 17.17.41.png
    brEad, mgtstumpy, 54reno and 2 others like this.
  26. looking great so far
    Vic
  27. Bcap55
    Bcap55
    from PA, USA
    The first cut is the hardest. What helped me the most was seeing examples of other 32 Fords being chopped. The Ride In Steel website link I posted earlier really helped me understand the steps needed to chop a top. Be sure to look up all of Flops threads here on the HAMB, he has lots of great info to share. I printed all the photos from his posts and used them for reference all through this project.
    Just remember, that car ain't gonna chop itself. Good luck.
    50 customcoupe likes this.
  28. Bcap55
    Bcap55
    from PA, USA
    Abro 73 ? Is that the official HAMB watching beer of Sweden.
    Thanks for subscribing.
    j hansen likes this.
  29. Bcap55
    Bcap55
    from PA, USA
    Ok let's do some more cutting. This is the area on the A pillar that needs to be removed to get to the inner structure.
    Here is the inner structure and where I'll be making the 2 1/2" cuts.
    IMGP0223.JPG IMGP0224.JPG IMGP0225.JPG IMGP0230.JPG IMGP0227.JPG IMGP0228.JPG
    Here are the cut lines at the door hinge area.
    The big moment. Off with it's head!
    The 2 1/2" have been cut out, and the top clamped back in place. Looks ok to me. From this point I worked mainly on lining up the A pillars, the windshield opening, the front door edge and the inner structure. The back of the roof section was dealt with after the cut for the roof stretch was made.
    BradinNC, brEad, mgtstumpy and 6 others like this.
  30. Mr48chev
    This is getting interesting. I'd say that we can use some of the info on any chop we do on a somewhat similar body to get a better chop.
    Dino 64 likes this.
