Projects 1949 Shoebox Ranchero Build
Discussion in 'Traditional Customs' started by jakesbackyard, Nov 28, 2018.
Hinge covers??
Poll closed Sep 29, 2021.
  1. Left
    35 vote(s)
    89.7%
  2. Right
    4 vote(s)
    10.3%
  1. jakesbackyard
    jakesbackyard
    from ND
    I guess I should start a build thread on my project.
    After I finished my Model A and had it on the road for 2 summers I needed a project. I wasn’t looking for quite this big of a project, but it was just too good to p*** up.
    This post shows what I brought home May 1st. Ch***is was done with brakes, lines, Granada rear, fresh SBF never run yet, lowered and pretty much done. Body on rotisserie, with most parts and some extras. Floors, inner/outer rockers pretty tough.
    Lots of work with hopes of having the body mated to the frame by the end of Oct. and then start the conversion to a Ranchero custom.
    B8E538D8-BD55-4317-8D46-9B9DE42AE3D0.jpeg 7D109D3D-4AB1-4B05-B9AE-BC3EEB4B9C0C.jpeg 9CA286A8-DA1A-4BF2-8B4E-60B1AADAD0F5.jpeg C55652CF-2536-4C7C-B362-6E9CD715819B.jpeg B4979C1B-01F9-42F4-940D-26CCBD0A705B.jpeg
  2. Peanut 1959
    Peanut 1959
    Subscribed! I love unusual kustoms!
  3. manyolcars
    manyolcars
    Those front tires are so wide you could pave roads! They will be difficult to steer too. I love the 'Ranchero' idea. I have been driving my 50 Ford for about 21 years crestlinerskirts.jpg
  4. jakesbackyard
    jakesbackyard
    from ND
    43F9D2CB-1485-4580-A5F3-087CAE1A4B45.jpeg 310CDC15-E77F-4860-BB42-F050659C2D0D.jpeg 5BDB645B-1BC0-4716-8818-0C64B9DE4422.jpeg 7301A9E4-D3B5-423B-8A19-F1FC770C0F61.jpeg E9C02D97-EA70-4511-B6C5-FDE7C21D458F.jpeg B7DA7879-377C-4C12-A22D-B9F5EA3113D7.jpeg 7B75450B-6071-49F5-8C12-3C3E092AE8AC.jpeg A8CD6252-E703-4DFB-AFE1-6426C202B932.jpeg 7B5D45D1-A465-4CC7-9C78-F88C19BB77C3.jpeg A1F29F6C-E58A-402D-8A6D-CD98E8364218.jpeg 7B75450B-6071-49F5-8C12-3C3E092AE8AC.jpeg So the first order was to beef up the homebuilt Rotisserie that came with the project. None of the underside seams had been welded. Took apart, welded, and beefed up. It was time to fix the body rust. EMS outer rockers and a 4 x 8 sheet of 18 gauge steel for inners, floors and patchin would do the trick.
  5. jakesbackyard
    jakesbackyard
    from ND
    Not sure why it doubled up some of the pics and put the text in the middle...oh well.
    Unkl Ian and loudbang like this.
  6. jakesbackyard
    jakesbackyard
    from ND
    So by the end of Sep it was ready to blast, epoxy, and Raptor.
    For some reason the pics don’t post in the order I load them either...
    5EF1B076-FB39-4C52-B0B8-A63D9DE5C1BC.jpeg 546610F3-D60F-429C-BA4F-1C1995FBDEC1.jpeg FE86C5A1-2DC0-4EE2-8EBE-7B47525F665B.jpeg A8C0DD2C-0A7C-49C2-8479-71C356C812DF.jpeg EABBB452-099C-4CEA-8C87-102679CB86AC.jpeg 0DFD11CB-72B8-4E52-AF07-8392C0B84ACD.jpeg AD3F135A-8EDD-4368-9EA3-87C04362C752.jpeg
  7. jakesbackyard
    jakesbackyard
    from ND
    On Oct 2nd the body got mated to the frame. Done by myself making stilts for the front and leaving the rotisserie on the rear, rolling the frame under the body and using my cherry picker to ease the body onto the frame. It’s about time to figure out the plan to cut it up...
    66240575-FF7A-471E-B10B-60C46A85B1B7.jpeg DC3DA3F6-2BCF-4190-8E2A-2F3C688A405F.jpeg E0158A53-D00C-46AF-B0A5-4EFB01764900.jpeg 81A2928E-9C87-4262-A6B3-C3CDF0EA3F70.jpeg 93FDF9E3-6E45-46D2-9103-52FECEF12CCC.jpeg 66240575-FF7A-471E-B10B-60C46A85B1B7.jpeg DC3DA3F6-2BCF-4190-8E2A-2F3C688A405F.jpeg
  8. jakesbackyard
    jakesbackyard
    from ND
    This is getting serious now. I decided to chop the top without tilting the pillars and door frames in...
    7032CC85-09FB-4972-8930-E0E0AA59B335.jpeg 06902B2C-7E65-4B69-8CFC-B5C09198118A.jpeg 63846FCB-4429-4AE1-A069-4E941783A450.jpeg A9C8CEBA-E6A5-46C1-B783-CA8356E4DEC9.jpeg
  9. jakesbackyard
    jakesbackyard
    from ND
    I put the word out that I needed a 53-56 F1 rear top clip... a friend called and said he had a few cabs and I could have one! Free! I decided to chop the 49 4” to make the windows line up with the F1 rear window...
    05B75429-DF17-40BF-84FD-41A607E57B4B.jpeg 2DE61D14-E4E7-419F-AE71-125C64F504A6.jpeg DD620C53-C742-43D2-81CB-712844436981.jpeg 696166E0-BE2D-4524-BEA1-70571FF76B13.jpeg 0E8C5184-C5C1-4ABE-AE14-495487131A5A.jpeg
  10. T&A Flathead
    T&A Flathead
  11. Squablow
    Squablow
    Looks very well thought out so far, looking forward to seeing more.
  12. jakesbackyard
    jakesbackyard
    from ND
    To leave the rear window the original size I chopped 3” out above and beside it bringing the F1 roof down to blend with the car roof.
    2B16BD6E-5350-4E93-92D4-6323765163CA.jpeg 7652AECB-1A81-4E4B-A5BC-6F3756B16488.jpeg BAF6E41C-553F-45BC-8E4B-66B1E234A90D.jpeg CF52FC36-EF89-4CB4-8D7C-0BFB26295D07.jpeg 7C05111E-FE5F-494F-8362-3BD14FEDB212.jpeg 69383BFD-E60C-48BD-AB65-A71D41F85851.jpeg
  13. jakesbackyard
    jakesbackyard
    from ND
    I looked around for some way to make the bed rail tops not slope down to the rear and settled on Ford Ranger bed rails. Found a cheap box and cut away...
    76CB176C-0B00-4969-B3F1-6F94C28AE332.jpeg 12185B29-BEEF-4688-AB37-48B163497550.jpeg 9EB5A045-F3AF-49FD-9739-A44C81FCEC93.jpeg EC9F649B-D14C-4F7D-A201-6761830A5F1E.jpeg 2B2CAF20-33CF-4C0F-BC54-C94F177B71ED.jpeg
  14. chaddilac
    chaddilac
  15. hank100
    hank100
    from san diego
  16. Texas Webb
    Texas Webb
    Yeah,that's quite a project worth watching.
  17. jakesbackyard
    jakesbackyard
    from ND
    I am dead set on a working tailgate and that has been the toughest part of the build thus far. I started with the lower section of deck lid, but it bulged out too much in the upper center. Split the inner and outer lid sections and used the inner lower and upper skin reversed and I think it’s going to work. Hinges were difficult. I’ve settled on stainless straps in lower seam for now at least. 2 1/2” exhaust tubing stiffens up the top with a homemade filler.
    D6F9DC1D-AFA9-42A8-B70D-8CFA0FF4562D.jpeg 930F4E50-EE44-4CC2-9C00-B231D185D49B.jpeg C17F718C-7573-4AD0-830D-FC85C49105B5.jpeg
    MO_JUNK, Randall, j-jock and 16 others like this.
  18. Dick Stevens
    Dick Stevens
    Subscribed! This is looking like an interesting build to watch.
  19. jakesbackyard
    jakesbackyard
    from ND
    And this is how it looks today. Next is make the fillers between the bed rails and tail lamps. Then it’ll be a whole lot of welding.
    DD758B3E-2E3E-4858-88AB-D7AD43A215B1.jpeg FA3DF51E-DA2A-490E-8A7A-E326388EF6DD.jpeg
  20. loudbang
    Good progress. Are you planning to keep it FE powered?
  21. jakesbackyard
    jakesbackyard
    from ND
    It’s a 302 and it will stay. Fresh - never been fired yet.
  22. mgtstumpy
    mgtstumpy
    Love what you're done to date, here's an OEM Ford Australia rendition. A 5 window coupe utility for some inspiration
    [​IMG][​IMG]
  23. slim38
    slim38
    from Sudan TX
    Subscribed! You are crazy my friend but it's looking cool.
  24. bobss396
    bobss396
    SUBSCRIBED !!
  25. mr.chevrolet
    mr.chevrolet
  26. GordonC
    GordonC
    I think the proportions are looking great. I wouldn't have figured the cab from a 56 would work but you did it! A question/suggestion. Are you going to do anything on the tailgate surface? Trim pieces in the middle or roll some accent lines into the skin or maybe emboss a FORD into it? To me it looks to wide to leave without some kind of detail on it.
    Unkl Ian, jakesbackyard and loudbang like this.
  27. Cliff Ramsdell
    Cliff Ramsdell
    Cool build, subscribed.
    Cliff Ramsdell
  28. rusty1
    rusty1
    neat project and you have a good eye for proportions,...here's a shoebox they should've made along with a ranchero type unit....ps, yours will be so much better lookin than those utes.
  29. Yes! I like what your doing, your approach plus and the over all look. That's all going well. As with all Automotive projects you'll get many comments and some "why didn't you??". I'm kind of one of those guys that says in my head, if only. From my view it's the house door hinges on the tailgate. In my head I'm saying go look at a 57 Ford wagon lower gate and work from there. It's not a knock by any means, just the rest of everything is so clean the hinge pins jump out and seem out of place. I'll go back where I came from now.
    The Wizzard
  30. the-rodster
    the-rodster
    I'm diggin' the **** out of it...
    Rich
