Projects You got to start somewhere!
Discussion in 'Traditional Hot Rods' started by Tooth, Nov 18, 2018.
  1. Yes
    41 vote(s)
    48.2%
  2. No
    20 vote(s)
    23.5%
  3. Other
    18 vote(s)
    21.2%
  4. 31
    19 vote(s)
    22.4%
  5. 32
    7 vote(s)
    8.2%
Multiple votes are allowed.
  1. Tooth
    Tooth
    from Missouri
    I guess you could call this entertainment like going to a movie only getting in for free?
    Ric Dean and Rehpotsirhcj like this.
  2. Are you talking to me? If so I'm not sure to what parts you refer?
    If you're ever near Lawrence give me a shout and I'll give you the nickel tour!
    Jet96, Tooth, Countn'Carbs and 4 others like this.
  4. Wheeliedave
    Wheeliedave
  5. Countn'Carbs
    Countn'Carbs
    from CO
    image.jpg @cactus1 is right on with the ****ie Flippen coupe - Mike knows what's cool for sure. Here is an earlier version which is pretty darn cool too imo.
    I had been watching that coupe body on Craigslist and glad to see a Hamber got it. Congratulations man and keep the updates coming.
    Tooth, kidcampbell71, cactus1 and 4 others like this.
  6. rtomss
    rtomss
    Congrats on the Coupe! I'm a little partial but I love the Chevy styling. You have a ton of options on what direction to go with at this point but the body looks pretty solid considering there isn's any wood left. Budget, time line, outsourced help ect. all play into the end result. You've come to the right place for help and ***istance thought. Just be careful when asking for opinions. BTW - Thirtytwo may not specialize in CAD made parts, but I've yet to find even a bad weld on what he's done for me. He knows his ****...
    Fast Eddie 27 and kidcampbell71 like this.
  7. Tooth
    Tooth
    from Missouri
  8. Tooth
    Tooth
    from Missouri
    Thanks for your advice, I'm just like a biscuit ****ing up the gravy!
    I may of found a 29 chevy frame to m***age...
  9. rtomss
    rtomss
    Have you seen it? 29's only had 4cyls. Does it have shorter rails than the 6cyl frames?
    Sent from my SM-G950U using The H.A.M.B. mobile app
  10. paul55
    paul55
    from michigan
    I think the WB on '29 was a few inches shorter.
  11. wheeldog57
    wheeldog57
    Hey Tooth, I have most of a 33 Chevy frame. It has the front suspension and steering still on it. It is cut behind the seat area. You can have it if you want. PM me
    Hombre and Nailhead A-V8 like this.
  12. sloppy jalopies
    sloppy jalopies
    way 2 go Ron !
    I have the front half of '28 bowtie. frame... cut at the kick ups....
    also free.... I will keep the good working shocks for my project...042120
    will be frozen in hard soon, as we have had 3 plowable storms already....
    Nailhead A-V8 and tb33anda3rd like this.
  13. bct
    bct
    29 was 6 cyl. 28 was 4 but built longer to anticipate the six . You can tell from the long front cross so that they could put the 4 in
    rtomss likes this.
  14. rtomss
    rtomss
    For reference here's a pic. of the 31'/32' frame we started with for my 32' Sedan. 32' Chevy Frame.2.jpg
    Tooth and Countn'Carbs like this.
  15. Tooth
    Tooth
    from Missouri
    I have a lead on a 29 frame, thanks for your offer and I will keep it in mind. Thanks
  16. Tooth
    Tooth
    from Missouri
    I have not seen it yet, I should know tomorrow how much he wants for it and I'll go take a look at it it's not far from here. I know 31 and 32 truck and car are the same. I think there's some measurements for 31 Chevy somewhere in the hamb. Thanks!
  17. sloppy jalopies
    sloppy jalopies
    so the cut frame is '28... and full length is a '30-'31... is that right ? DSCN3260.JPG DSCN3265.JPG
  18. Tooth
    Tooth
    from Missouri
    I guess you could measure the hood on a 29 and the hood on a 30-31. That would tell you if there's a frame length difference!
  19. Tooth
    Tooth
    from Missouri
    You know I can't tell you how much I appreciate the offers that everyone is giving me, I really do appreciate all of the input. I got my rodders journal today and it is about a 31 Chevy build. And I got this information from a HAMBer. All you guys ROCK!!!
    rtomss likes this.
  20. rtomss
    rtomss
    Great issue...[emoji12]
  21. bct
    bct
    I believe your cut frame is newer than the full frame . I do not think it is 1928 . not like the two 4 cyl. 28 frames I have. they are closer in appearance to your full frame.
  22. bct
    bct
    plus the crossmember at the tailshaft area of your cut frame dates it later. late 20s chev frames had the tailshaft hanging in the breeze and it started to cause them trouble.
  23. sloppy jalopies
    sloppy jalopies
    as one of henry's boys, I never looked into the bowtie stuff... took 'em in trade.
    thank you !
    bct likes this.
  24. paul55
    paul55
    from michigan
    The uncut frame is a '31 and the other is earlier.
    Tooth likes this.
  25. rtomss
    rtomss
    Agree....I'd hold out for a 31' frame.
  26. Nailhead A-V8
    Nailhead A-V8
    Check out a car called "Mr. S***ches"....use the '29 frame and stock parallel leaves for the g***er look but go with Ford crossmembers/transverse spring suspension if you want it low and a 302 Jimmy or a 261 Jobmaster for power...if V8 then a nailhead, olds, cad, or pontiac... pls try to ignore the sbc crew when they crawl out of the woodwork;)...
  27. Tooth
    Tooth
    from Missouri
    I had a 57 Buick special that had a nail head in it and I should have kept the motor out of it when I sold it. There's a guy about 4 hours from me who has a 29 2 door sedan frame he wants $100 for it but the frame rails on 137 in long and on 31 32 Factory frame is 151 and a quarter long frame rail. There's a lot to think about I like the 6-cylinder idea though. Did you know that Don Garlits used a 31 Chevy frame for the swamp rat configurations on all of them? Thanks for the information in the ideas I appreciate it!
    31chevymike and Nailhead A-V8 like this.
  28. Tooth
    Tooth
    from Missouri
    The cool thing is I've been offered several different 31 frames for free I just have to go get them, maybe I need to take a vacation! I definitely need to figure out a plan I do like the parallel leaf spring idea. The cars handle better and ride a little bit better just harder to find some parts but the 54 Chevy front end stuff works and the steering box and all that so? I happen to have a 54 Chevy pickup.
  29. mlagusis
    mlagusis
    Glad you got that issue. It has helped me big time. Got grab one of those 31 frames!
    I need to start a build thread for my 31. I am using the rear spring and mounts from a 52 Chevy truck. I am using the front spring, steering box/column and axle/brakes for the front end from the same 52 Chevy truck, I found a guy here who put a mustang 2 front end and got that parts pretty cheap. I tweaked a few things though to get the car to sit where I want it. Hopefully I can take time in the next week or two to start the thread. I will let you know when I do. I plan to use all Chevy parts
    Countn'Carbs and Tooth like this.
  30. mlagusis
    mlagusis
    While searching for parts, if you stumble across a set of 31 doors (sedan or coupe) please let me know. I need a set for my build.
    Tooth and saltflats like this.
