Projects Cheap ass 34 pick up
Discussion in 'Traditional Hot Rods' started by dumprat, May 31, 2015.
  1. dumprat
    dumprat
    from b.c.
    IMG_2821.JPG Trans bolted up tonight and looks like I can go up about inch and back about 3/4" . This will require he least amount of firewall butchery. And still give me lots of clearance to everything but the steering box, but even that should work. Note how much more interior room I have.
  2. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Really glad you opted for a hot rod mill instead of a boat anchor.....happy motoring
    Nailhead A-V8 and jvo like this.
  3. Six Ball
    Six Ball
    from Nevada
    Definite improvement to the interior room. You made a good choice. The "boat anchor" was a good choice until the pedal issue came up and a good deal on a Hemi came along.
  4. Tim
    Tim
    from KCMO
    I must have missed it and didn’t see when I scrolled back a few pages but what hemi is that? Considering a hemi/a833 combo for a future build so it piqued my curiosity
  5. 32deucecoupe
    32deucecoupe
    from Denver
    Great progress, enjoy following this thread..
  6. dumprat
    dumprat
    from b.c.
    The hemi is Desoto 330 fire flight engine
    Tim likes this.
  7. Tim
    Tim
    from KCMO
  8. dumprat
    dumprat
    from b.c.
    Seriously considering crushing this pile of **** and taking up macrame. No room for the starter or clutch linkage.
    Okie Pete and kidcampbell71 like this.
  9. Stogy
    Stogy
    Sorry the end to 2018 is a solid brick wall you will I confidently believe bust through. Happy New Year to You and Your Family @dumprat Thanks for sharing the journey good and bad...;)
    Toms Dogs, Outback and kidcampbell71 like this.
  10. chessterd5
    chessterd5
    from u.s.a.
    Well it's not cheap anymore.
  11. Itchy-Pit
    Itchy-Pit
    Step away. Take a break come back with new perspective. You'll figure out a plan! Happy New Year
  12. dumprat
    dumprat
    from b.c.
    I think I have a cheap solution to the problem. Stay tuned.
    rkkoehler, Runnin shine and Stogy like this.
  13. Dick Stevens
    Dick Stevens
    Hydraulic clutch and?
  14. dumprat
    dumprat
    from b.c.
    No hydraulic clutch.
    It won't fix the starter and steering box bing in the same spot.
    Runnin shine likes this.
  15. Six Ball
    Six Ball
    from Nevada
    This is why it's called a build instead of an ***embly. You can figure this out. Swap sides with the starter?
    Woogeroo and Runnin shine like this.
  16. Runnin shine
    Runnin shine
    Make it right hand steering. Don’t you guys drive on the wrong side of the road anyway? No wait that’s across the pound.
    OahuEli and Stogy like this.
  17. dumprat
    dumprat
    from b.c.
    Glad to see you are back Wyatt!
    And yes I am trying to put together a traditional type set up to move the starter to the right side where it belongs.
    Stogy and Runnin shine like this.
  18. Jethro
    Jethro
    How about running the starter off the blower snout like the top fuelers.....you are running a blower right?.....it is a Hemi
    Happy new year Matt!
    Stogy, brEad, kidcampbell71 and 2 others like this.
  19. dumprat
    dumprat
    from b.c.
    IMG_2998.JPG Still ****ing with small things and trying to sort out the correct combination of worthless junk parts to make the trans fit.
    I built a new mount for a hurst shifter I got for $20 to push the shifter handle forward quite a bit.
  20. dumprat
    dumprat
    from b.c.
    IMG_3014.JPG Finally finished the firewall and cut down the throttle.
    Okie Pete, Stogy, Tim and 1 other person like this.
  21. RDR
    RDR
    Enjoying your fantastic build ! Keep up the great job !
    Can totally relate to 'Cheap ***'!?! build. Back in the 90's I told my teenage son we were going to build a roadster for 500 bucks. Bought a V8 Vega project for 200, stripped every usable part, a clapped out A coupe ******* body for 200, used the frt and rear axle from my 34 pickup teardown...Well, long story short...that $500 ended up $ 2,500 and blew our budget. But of course this chrome piece got added, the tri power got added,...you know what happens. Did have years of fun and many miles in that thing though !!
  22. Tim
    Tim
    from KCMO
    Dig that throttle, can we see the other side?
  23. rd martin
    rd martin
    from indiana
    looking good! cant wait to see it done!
  24. dumprat
    dumprat
    from b.c.
    Tim, the throttle is a 40's something truck pedal cut to a 32-34 shape. Nothing terribly special
    Stogy and Tim like this.
  25. Tim
    Tim
    from KCMO
    Does it only have one mounting point/ Heim type joint?
    I cut up 46 ford ones for everything lately and am trying to figure out this latest one and like how you did yours.
    Stogy likes this.
  26. dumprat
    dumprat
    from b.c.
    It has one mounting bolt and the little tin cup hold the other end and seals the hole for the pedal to p*** through.
    Stogy likes this.
  27. dumprat
    dumprat
    from b.c.
    Still plugging away. Slowly. Scrounging parts and figuring out the right combination.
    I just bought a house, so things have been upside down for the last month or so.
    The hemi is at the engine shop, rough bored and align honed. Waiting on a crank grind number to order the engine kit. But summer is here and the CJ has plates on it, so I get my open car fix for a while...
    ratrodrodder, Stogy, Outback and 3 others like this.
  28. Six Ball
    Six Ball
    from Nevada
    Thanks for the up date.
    Outback likes this.
  29. dumprat
    dumprat
    from b.c.
    I scored a hot heads right side Chevy adapter plate and a Chevy ****tershield at the local swap a couple of weeks ago, for $150 !
    So cleaned up the back of the ****tershield and turned the dodge 833 input retainer down to fit. I have to weld new lugs inside to match the trans bolt pattern but this should work. IMG_3257.JPG
  30. sloppy jalopies
    sloppy jalopies
    Memory says ford's s**** pedals were in '32 to '36 cars and '32 to '39 trucks...
    they then went to a ball on each end of the pedal ***embly, the inner ball plugged into the back side of the rubber pedal...
    Woogeroo likes this.
