I need a steel topped work/welding table that I can move around and outside for welding on my 40 build project. Knocked the table out in a couple days but 2 coats primer and 2 coats color, another four days. Our business fab shop has a 10' shear so I had them shear up some 10GA plate for the top and sides per my cad drawing and below is the finished product.
D.R#1, Nice looking cabinet work. I'll go out on a limb here and say the day will come when you will wish you had built it out of Steel Tube and larger casters instead of Lumber. The Wizzard
Thanks Wizzard, I appreciate the comment. I had a little time, no weldor and wood available so it was a make do deal. This one will be a multiple use table, my frame table will be all steel but I needed this one to build the frame table.
Since I am seriously "carpentry challenged", I went a different route; recycle/re-purpose/reuse. I have an old, solid wood, military desk. The thing's so solid and heavy, I actually have a vice bolted to it. Four large drawers, and a smaller, center drawer hold all kinds of stuff. The only "bad" thing about it is, when it's cold/wet outside, the drawers sometimes swell up, making it hard to get them out. An equally solid, metal cabinet, with two sliding doors, sits atop the desk. Most of my fasteners, solderless terminals, hose clamps, etc, are stored in it. My welding cart, is an old audio-visual, roll-around cart that's large enough to hold my Craftsman Buzz Box arc welder and supplies, a 110V MIG/a 220V MIG and supplies, and a small O/A torch setup and supplies. Several other recycled cabinets, and a couple of dressers have also been put to use. I am Butch/56sedandelivery.
That's a great idea. I just inherited some cabinets. One is a Craftsman and one is a big industrial so a set up like yours that's mobile would make shop life more useful.
Nice work!....you'll find it super handy......until it becomes a shelf like every other horizontal surface in my shop. you look pretty organized and tidy so that might not be a problem for you.
I understand how this all works with using what's on hand. Mobil work stations as well as equipment makes life a lot easier. Took me a while to grab onto the 2 drawer and 4 drawer cabinet idea but I finally saw the light. The Wizzard
some years ago I answered a CL ad for a "table". It was sitting upside down on top of another light-weight table. The woman's son and I struggled to get it down on the garage floor and upright, but as it turned out, glad I did. She threw in the Reed vise with it for $45 At first I thought the legs were just some cheapo steel tubing and would take hours to clean up, and then re-paint. After I got it home and started taking things apart, it became obvious that it was a darn good industrial table like from an ins***ution, and the legs were actually heavy wall galvanized tubing. Took quite a while to clean things up. Especially that decoupage **** that was once fashionable. (never understood the thinking there). After making new tension rods and re-gluing the maple top together, I took it to a lumber co and had it sanded down. Turned out nice. Welded up a lower shelf. Added casters. Now have a descent flat table to work on.
The teller cabinets were from a remodel at the local bank, the casters were a swap meet buy and the top is a 3 1/2 x 5 ft piece of 1/2 in steel that was the top of a sad welding bench bought from a going out of business welding shop. The only new things I had to buy was the steel for the frame and the receivers for mounting things on the ends of the bench like a saw table. Here is a pic of the sad bench that I got the top off of, good thing was the $50 price tag.
