Projects Fry's Model A coupe build RECAP
Discussion in 'The Hokey Ass Message Board' started by Fry, Nov 5, 2018.
  1. Fry
    Fry
    from SK, Canada
    I finished the body wood kit and chopped all the mouldings.
    95C46484-16AA-4055-BD03-1099E1CD1D8E.jpeg BB0FAEFC-A5A9-4E6C-BC07-40EB4ECB8CB2.jpeg
    I also finished up installing door latches and some body work.
    I gave it a second coat but didn’t like the results, so I wet sanded it and tried to polish out the scratches. Then I rubbed it down with some comet cleaner to try and dull it again. Kind of ended up with a cool look.
    I really only have a few small items to tend to and send the window templates down. I think I’m going to have a break from the car for a couple of months and finish it up in the spring.
  2. 3banjos
    3banjos
    from NZ
    Friggin' cool hotrod. Great vision.
    loudbang and Fry like this.
  3. Fry
    Fry
    from SK, Canada
    Thanks!
  4. Mike Colemire
    Mike Colemire
    Love it, you nailed the color.
  5. brady1929
    brady1929
    Looks great
    Fry and loudbang like this.
  6. Fry
    Fry
    from SK, Canada
    Thanks guys, I appreciate it.
  7. Fry
    Fry
    from SK, Canada
    Minor update,
    I had this old windshield frame, it wasn’t bad other than the bottom was rotted out.
    I made a new bottom channel, chopped it and cleaned it all up nicely.
    Made a template and just couldn’t get gl*** in there without cracking. So out of frustration I bought a new frame.
    Once chopped and fitted I made a template had my gl*** cut and it fits like a glove. I really wanted to save the old frame, but it’s just tweaked enough.
    I’m not sure if I should polish the aluminum or paint it. I’m leaning more towards trying to trying to polish it, though it might stick out as there isn’t much bling on this plain brown car.
    On a side note, all the rest of the gl*** is getting tempered and should be here next week. After the gl*** is in there isn’t much on the to do list.
    32BFEF69-CCE0-41FC-838B-CAA4A4DD4159.jpeg 13A0919A-AA61-4A05-AC0C-93A2074EB49C.jpeg C38545FD-671E-43EB-ADB5-E32B6A943810.jpeg CDA95A3F-4091-4383-82B9-7C2DC1D0CD1A.jpeg 9897AA0F-0031-471C-800E-8FE411ACDD4A.jpeg E5B8B2EF-E44E-4B79-B3E8-632747113668.jpeg
    Kan Kustom, loudbang, bct and 4 others like this.
  8. AndersF
    AndersF
    You could leave it semipolished to break out from the brown without to stick out to much.
    Fry and brEad like this.
  9. Tim
    Tim
    from KCMO
    Great hot rod man. Out of curiosity did you brace the firewall at all for the hanging pedals?
  10. 41rodderz
    41rodderz
    from Oregon
    I appreciate the build threads. That's how I learn and get smarter every day. :D
    Fry, loudbang and bct like this.
  11. Blue One
    Blue One
    from Alberta
    That’s going to be a really nice little coupe :cool:
    Fry, loudbang and ROADSTER1927 like this.
  12. ROADSTER1927
    ROADSTER1927
    Great thread Thanks for posting! Gary:):):)
  13. Fry
    Fry
    from SK, Canada
    Sort of, I made a piece the same shape as the M/C to get it out from the firewall bead. The inner ***embly bracket for the pedals is fairly big, so once sandwiched it’s pretty firm. Seems ok so far. 1B7FB0AE-2D9C-4AD7-B7A3-379008861348.png
    Kan Kustom, earleg, Stogy and 2 others like this.
  14. Fry
    Fry
    from SK, Canada
    Thanks for the replies guys!
  15. Tim
    Tim
    from KCMO
    Cool thanks for the reply. I’ve had more than one car with firewall mounted masters/pedals end up flexing the fire wall and cracking it.
    Once I thought it was the clutch going out so I finally brought it to the shop and they called be
    Back laughing that the the clutch was fine but that the fire wall was moving when I pushed the peda not the pedal itself moving. Granted that thing was pretty damn rusty but I’ve always been kinda paranoid about it after that
    loudbang, Fry and kidcampbell71 like this.
  16. Fry
    Fry
    from SK, Canada
    It’s something to keep an eye on, I had thought about beefing it up, but never came to fruition.
    I usually tend to keep adding metal even when not needed so took the less is more approach. Might bite me later. haha.
    Stogy and loudbang like this.
  17. Fry
    Fry
    from SK, Canada
    Got the windshield installed today.
    Polished the frame but not to a crazy shine. Looks ok.
    4B4CCEE6-1C8B-473A-907D-BB22846F9FCD.jpeg 396DA5F3-2228-447F-AB59-48567762FAA2.jpeg 9C724257-0CB5-4A29-B1AF-A023034AA2E1.jpeg
    Kan Kustom, ClarkH, Blue One and 10 others like this.
  18. 392
    392
    Very impressive build and it looks spot on. Great job.
  19. HotrodHR
    HotrodHR
    I've read through your build a couple of times... work is great! I don't think you need to pull it apart and have "pro" fix anything. You have a lot of great ideas for folks to "borrow" from.
    One thing did bug me as read through your build... all the great pics where you left the stickers on the tires! LOL, just one of my issues I need to work on...
    Fry, kidcampbell71 and loudbang like this.
  20. Fry
    Fry
    from SK, Canada
    Thanks.
    I burned those off the rear at least pretty quick. Haha.
    loudbang and Tim like this.
  21. 42˚18'N 83˚09'W
    42˚18'N 83˚09'W
    Congrats on a job well done. I'm sure you and your family will look back fondly on these memories as the years p***. Be proud of this accomplishment. Now go put some miles on it...
  22. 50John
    50John
    Just found your thread today & read through the whole thing. You nailed it in all aspects. And double kudos to you for doing it yourself in your own garage. Very inspiring and thanks for sharing the journey.
  23. nor6304
    nor6304
    from Indiana
    Really good build Enjoyed the thread
  24. Nice "A" Bone.
  25. Fry
    Fry
    from SK, Canada
    Thanks guys!
  26. sodas38
    sodas38
    Very cool, you've done a great job, project looks awesome!!
  27. Fry
    Fry
    from SK, Canada
    00E22DB3-FE83-45F4-8839-7B8DD5574118.jpeg 3D67A0CB-EE7A-4E2A-B0F6-437573642DBF.jpeg 44C1BCB3-DB30-4BD7-8F45-0B464EB360D8.jpeg Got my tempered gl*** back and installed. A bit of monkeying around for the rollup windows but they go up and down marginally well.
    The shifter position was bothering me so I found a old hurst Indy shifter on my shelf and modified it to fit. Apparently it’s quite a bit different than the comp plus so it took some welding and grinding to combine both. Heated it and bent it to get it better centred in the cab.
    Feels great now.
    Surprising I just used a propane torch and didn’t wreck the chrome heating it up, worked great.
    I had this shift knob for awhile. My buddy who got me into hot rods bought it for a hot rod I tried building that didn’t come to fruition like 10 years ago. Thought I’d try running it. I liked the all business hurst ball, but a few skulls here and there never hurt anyone.
    Sometimes I try to hard to separate myself from the rat rod crowd that I try not to keep the car low key without accessories, but I’ll let this slide.
    Kan Kustom, Stogy, brEad and 3 others like this.
  28. Fry
    Fry
    from SK, Canada
    Also wanted to say thanks to everyone for the positive comments and following along. I set out when I started to prove to myself that I could build something and follow through to the end. Not just be the guy who talks about what he wants to do, or living vicariously through everyone else’s builds.
    I also didn’t want to build a show car or a polished beauty. It’s pretty much how far I want to take it right now. A little rough around the edges but well built, over built and reliable.
    I sat in it today after finishing up some small stuff and thought I can’t believe I built this.
    Hope it’s an early spring.
    I’ll update the thread as we go and really get some miles on her.
    I’m sure I’ve said this earlier in the thread but the plan is taking it out to deuce days in Victoria, British Columbia, at the end of July. About 2000 miles round trip crossing the Rockies. Hopefully that happens. Fingers crossed, as I’m already registered for it. Should be an epic trip.
    Stogy, Tim, brEad and 9 others like this.
  29. brEad
    brEad
    Car looks great. You deserve to feel proud - it’s quite an accomplishment!
  30. Tim
    Tim
    from KCMO
    Looking forward to the trip posts :)
    Fry likes this.
